Arborwear
Author Topic: Timber Harvest Methods & Equipment  (Read 893989 times)
Cbown and 1 Guest are viewing this topic.
Offline wannaergo
  • Work while I'm young, sleep when I'm dead!
Re: Timber Harvest Methods & Equipment
« Reply #3160 on: October 23, 2015, 08:37:11 PM »
Demo'd Barko's new 260W harvester with a Southstar QS500 head. Here's a short video of Barko's demo operator cutting a 20+ inch hard maple.
2016 Ponsse ergo 8w
2014 Cat 564
Husky 385
Offline North River Energy
« Reply #3161 on: October 23, 2015, 08:48:34 PM »
Learned something nifty today. :laugh:
Quote from: mooseherder
If you take out the s from the https the video should show in your post instead of a link.
with the s:  ()
without the s:
I learned that tip from Furby.  ;)
Thanks both.  I've been trying to figure that one out for quite a while.
Offline RCBS
  • Mongo like candy!
« Reply #3162 on: October 24, 2015, 10:29:04 AM »
Behold...30hp of fury!  She's got more guts than she has ballast.  The bigger logs are at the limit with some brake steering needed to turn sometimes due to front end loft.  1/4 mile + skids to my firewood yard (thankfully, mostly downhill)
http://www.forestryforum.com/gallery/albums/userpics/34187/IMAG0270.jpg
http://www.forestryforum.com/gallery/albums/userpics/34187/IMG_20140927_124419700.jpg
http://www.forestryforum.com/gallery/albums/userpics/34187/IMG_20151004_153031340.
http://www.forestryforum.com/gallery/albums/userpics/34187/IMG_20141018_133041925.jpg
Echo CS-3400, 550xp, Jonsered 2166, L3130 Kubota, '78 JD 300 backhoe, Kubota RTV900, JD2305, lots of sharp stuff and several firearms
Offline 1270d
« Reply #3163 on: October 24, 2015, 03:18:28 PM »
Made a quick video this morning processing some hard maple.  Sorting pulp, bolts and saw logs.
Removing the "s" works like a charm, thanks for the tip.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #3164 on: October 27, 2015, 04:35:30 PM »
Seven fifties, two forties.
Offline 1270d
« Reply #3165 on: October 27, 2015, 06:57:12 PM »
Wow, nice load!   Is it white pine?
Offline brendonv
  • Arborist
    • www.VorioTree.com
« Reply #3166 on: October 27, 2015, 07:01:58 PM »
Nice wood!
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Offline Straightgrain
  • Like a kid in a candy store..
« Reply #3167 on: October 27, 2015, 07:06:48 PM »
So, I needed some type of brush attachment and I don't have the money for a grapple, a third function valve, or even a good set of debris forks...so I bought a 2nd set of used fork lift blades.
The "on/off" opening at the bottom-front of the Titan carriage was too wide for the blades to keep in the inner-most or center location, so I welded some 1/4" flat stock on both sides of the opening to provide keeper support for both blades.  I also welded a snatched hook on the inside-center of the carriage since I had the welder out....and the Titan warranty recently expired ;D
The only draw-backs I can see are the width of the blades and the loss of @ 115 pounds of the available 970 LB factory lifting capacity.
Will  try them out on slash piles this week end
"We fight for and against not men and things as they are, but for and against the caricatures we make of them". Joseph Schumpeter
    • My homepage
« Reply #3168 on: October 27, 2015, 07:17:09 PM »
Yes.
    • My homepage
« Reply #3169 on: October 27, 2015, 07:18:13 PM »
Nice wood!
Yeah, it's pretty good stuff.  Hard to find.
Offline thecfarm
« Reply #3170 on: October 27, 2015, 07:23:13 PM »
Straightgrain,I betcha that will work pretty good. Too bad you could not get one "finger" hooked up to hyds. That would keep the brush in place on rough land.
Offline g_man
« Reply #3171 on: October 28, 2015, 08:10:57 AM »
Nice work. That will be way better than doing it by hand. You will never see the lose of lift capacity with brush I don't think. But then again it is western brush so it is probably big  ;D
Sometimes I move brush/slash with my winch. I lay out a long chain/choker and pile the slash on it. A huge pile. Bring the choker up over the top and winch it up to the tractor. Drag it off to the burn or debris area where I can push it around with the bucket. Still a lot of hand work and you loose some on the drag.
gg
« Reply #3172 on: October 28, 2015, 08:33:39 AM »
Thanks for  the evals; scooting large heap of slash to the treatment areas is the best I can do, without that 3rd function.
If "things...." settle-down in  2017, I'll go off the deep-end and get a 3rd function valve and a grapple.
Offline Ron Scott
« Reply #3173 on: October 28, 2015, 12:51:09 PM »
Dave,
Are those fifty and forty foot white pine going into poles or cabin logs?
~Ron
    • My homepage
« Reply #3174 on: October 28, 2015, 01:36:18 PM »
Ron, they are being cut into 10" x10" and 12" x12". They are for a barn we are building at work. We got three cut this morning before it started to pour. About an hour each with two of us working.
Offline Ron Scott
« Reply #3175 on: October 28, 2015, 05:54:15 PM »
It's good that you had a project already planned for their use. Continue the pictures of their use in the barn construction.
~Ron
Offline thecfarm
« Reply #3176 on: October 28, 2015, 08:00:02 PM »
That mill seems to be getting longer every time I see it.  :)
    • My homepage
« Reply #3177 on: October 28, 2015, 08:33:28 PM »
It's probably done growing. For now. :D
« Reply #3178 on: October 29, 2015, 09:39:50 PM »
Nice looking beam.....beautiful actually.
Offline SFires
« Reply #3179 on: November 25, 2015, 07:22:30 PM »
Brush mower  chipping up some brush
A man can always use more tools, more space,more wood, and a whole lot more time.
timber harvest
Started by schambers on Ask The Forester
Last post May 02, 2014, 05:02:50 PM
by schambers
Timber Frame Layout Methods
Started by Jay C. White Cloud on Timber Framing/Log construction
Last post March 07, 2013, 10:27:40 AM
by frwinks
Timber harvest notification law
Started by finding the trail on Forestry and Logging
Last post August 28, 2016, 06:11:01 PM
by RHP Logging
Alternative Timber Frame Enclosure methods
Started by S.Hyland on Timber Framing/Log construction
Last post April 22, 2013, 02:21:41 PM
by ziggy
