Arborwear
Author Topic: Timber Harvest Methods & Equipment  (Read 907520 times)
Offline sawmillsi
  • workin hard
Re: Timber Harvest Methods & Equipment
« Reply #740 on: July 10, 2004, 06:40:06 AM »
whats with all the axels on the log truacks over your way??? ???
In Australia, standard log trucks have either single or double steer axels, bogie drives and tri trailor axels
simon
Offline slowzuki
  • Still learnin'
    • On the Farm
« Reply #741 on: July 14, 2004, 12:24:59 PM »
Quote
Zundel
Zundel as in Dr. Pierre?  Did some work for him on a  horse drawn grapple skidder project.  Usually dealt with his grad student though.
Offline SwampDonkey
  • Large Tooth
« Reply #742 on: July 14, 2004, 05:40:06 PM »
SwampDonkey nods  ;D
Dirty Harry
Offline Ron Scott
« Reply #743 on: July 15, 2004, 06:49:29 PM »
Some more log hauler names noted "on the road".
"Double vision
"Hello Darling"
"I Love The Money"
"Double Trouble"
"Who's Next?"
"Money Pit"
~Ron
Offline Cedar Eater
  • Eat cedar and be a regular guy.
    • Cedar Eater's Low Income Logging Photos
« Reply #744 on: July 23, 2004, 09:31:43 PM »
Quote
simon
I don't know which picture you're looking at, but I would guess the trucks with lots of axles travel on roads with a low peraxle weight limit. Most likely, that would be due to steep slopes or Winter and Spring road conditions. That's the case with gravel haulers, so I'm assuming it applies to logging trucks.
Cedar Eater
Cedar Eater
Offline Ron Scott
« Reply #745 on: July 29, 2004, 10:52:12 PM »
Logger's Pickup. Tailgate up.
Lee timber harvest; 7/04.
~Ron
Offline sprucebunny
  • Gender: Female
« Reply #746 on: July 30, 2004, 05:13:58 AM »
That's one a them fancy loggers pick-ups. Round here the loggers all got oil and dents painted on the tailgate.
Offline Ron Scott
« Reply #747 on: July 30, 2004, 05:39:35 PM »
Logger's Pick-up. Tailgate down.
~Ron
Offline Ron Scott
« Reply #748 on: August 11, 2004, 06:02:16 PM »
Timberjack 230A Turbo Forwarder. Loading pulpwood and firewood. Dean timber harvest; 7/04.
~Ron
Offline Ron Scott
« Reply #749 on: August 13, 2004, 06:25:59 PM »
Loading the Wood Hauler With Sawlogs For Jeff's Mill.
~Ron
Offline redpowerd
« Reply #750 on: August 13, 2004, 09:25:23 PM »
so those logs are goin to jeff_b?
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
Offline Ron Scott
« Reply #751 on: August 16, 2004, 07:52:04 PM »
Tightening The Binders Before "Hitting the Road". Yes, the logs will be going to the mill where Jeff is sawyer.
~Ron
Offline RMay
« Reply #752 on: August 16, 2004, 08:24:50 PM »
Ron what length is the logs on the truck , dose the log trucks have to have a wide load permit . ???
RMay in Okolona Arkansas  Sawing since 2001 with a 2012 Wood-Miser LT40HDSD35-RA  with Command Control and Accuset .
Offline Cedar Eater
« Reply #753 on: August 16, 2004, 09:31:56 PM »
Quote
I can answer that. In Michigan, the limit is 8' for not needing a wide load permit, but for logs stacked sideways, they allow 100" (8' 4"). That gives the mill a tolerance.
Cedar Eater
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #754 on: August 17, 2004, 04:41:59 PM »
I believe The actual width limit here is 102 inches but may be wrong.
Offline Ron Scott
« Reply #755 on: August 23, 2004, 06:37:08 PM »
Leaving The Landing For The Mill. On its way to the mill with a sawlog load. The sawlogs are in 100" lengths and within the 9 foot width limit. A wide load permit is not necessary. They must be loaded properly without excess overhang.
~Ron
Offline Ron Scott
« Reply #756 on: August 28, 2004, 07:53:18 AM »
Bucking Sugar Maple Sawlogs. Working in heavy foliage and ground cover. Can you see the "two" cutters at work? Lee timber harvest; 8/04.
~Ron
Offline beenthere
« Reply #757 on: August 28, 2004, 09:00:48 AM »
One on the right has an orange hard hat and the one on the left has an orange saw.  Had to brighten up the image to find them.  Looks like fun.  :)
Offline DanManofStihl
  • Cut em down Dan
« Reply #758 on: August 29, 2004, 05:39:05 AM »
That is a problem with heavy folage it does not make that safe of a working environment but as long as your care ful I had one guy that put his saw down next to him the chain still had alittle speed and it cut this other guys boot you have to be real careful. You can never have enough orange
Two Things in life to be proud of a good wife and a good saw.
Offline Ron Scott
« Reply #759 on: August 29, 2004, 06:25:54 PM »
Working in Heavy Foliage. Heavy foliage makes hard work for the cutters with added safety concerns. Often, all that can be seen is their "orange" hard hats and "orange" chain saws. The hill side work here also has added risks. Lee timber harvest; 8/04.
~Ron
timber harvest
Started by schambers on Ask The Forester
Last post May 02, 2014, 05:02:50 PM
by schambers
Timber Frame Layout Methods
Started by Jay C. White Cloud on Timber Framing/Log construction
Last post March 07, 2013, 10:27:40 AM
by frwinks
Timber harvest notification law
Started by finding the trail on Forestry and Logging
Last post August 28, 2016, 06:11:01 PM
by RHP Logging
Alternative Timber Frame Enclosure methods
Started by S.Hyland on Timber Framing/Log construction
Last post April 22, 2013, 02:21:41 PM
by ziggy
