Arborwear
Author Topic: Husq 455 Rancher vs. 346XP  (Read 5979 times)
Offline GlennCz
« on: August 16, 2005, 10:01:12 PM »
I'm a private landowner with 60 acres of timber in Penna.  Right now we are logging and I'm cutting some small to medium beech.  Also doing some thinning of poorly formed 12" and helping out with taking cutting up some tops.  I use a Husq 55 and it does the job fine.  But I need another saw because my other spare got killed.  I would like to get the 346XP cause it is 2 lbs. lighterthan the 455(replacement for rancher) at 10lbs.   Does that sound like a good idea, is it just as powerful as the 455?   THanks, GLenn in the Poconos of Penna. - Having a BALL working with my logger everyday!
Offline David_c
  • treat people the way you want to be treated.
Re: Husq 455 Rancher vs. 346XP
« Reply #1 on: August 16, 2005, 10:16:49 PM »
Dont know anything about the 455. But i have a 346 and love it.
Offline barbender
« Reply #2 on: August 16, 2005, 11:47:07 PM »
The 346 has a lot of power for a small saw, I love mine for felling smaller stuff and limbing.  A lot of times I find myself felling bigger 20-24" stuff  (aspen) with it Instead of my 2171 Jred just because it's so much lighter to carry around.
Offline GlennCz
« Reply #3 on: August 17, 2005, 08:42:20 AM »
thanks guys. I think I'll go for the 346xp, glad to hear that it can do the job for such a light saw.   you guys have "the life", running around the woods cutting down trees all day, glad I can join you for a bit.
Offline fishhuntcutwood
  • I love the smell of two-stroke and wood chips.
« Reply #4 on: August 17, 2005, 01:48:44 PM »
The 346 is 3.4 hp @ 10.6 lbs, and the 455 is 3.4 hp @ 12.8 lbs.  The 346 is a professional grade saw, and the 455 is a homeowner's saw.  No brainer.  I think you'll be very happy with your decision.
MS 200T
MS 361
044
440 Mag
460 Mag
056 MII
660 Mag
Offline GlennCz
« Reply #5 on: August 18, 2005, 07:11:42 AM »
I got 346XP yesterday and went through a tank of gas last evening.  The saw is light as can be, yet cuts like a wiz! It has RPM's of 14,000 vs 12,000 for the homeowners saw and that makes it much quicker and active.  I think I made the right choice, esp considering the terrible terrain that I have to deal with these tops and downed beech, but the forest is really opening up.  About 25 yrs ago someone did some thinning of beech and TSI work on a few acres of my property and that area is now has some of the largest timber and without doubt is more beautiful because of it.
Offline sawguy21
« Reply #6 on: August 18, 2005, 08:46:47 AM »
I understood the 455 is replacing the Rancher yet the Husky literature calls it a commercial ???. Our distributor only brings the 346xp in on special order so have not had the chance to try one. The 357xp is a screamer though.
Offline SawTroll
« Reply #7 on: August 18, 2005, 09:16:10 AM »
What Jeff said. 8)
You no doubt made the right choise! :)
Information collector.
Offline OLD_ JD
« Reply #8 on: September 08, 2005, 02:56:51 PM »
i just bougth a 346 xp to replace my 254xp 8)but it's poring raine here >:(i will have to wait to tomoroy to try it ;)...just can wait to see if i made a good by :)
canadien forest ranger
Offline SawTroll
346XP vs. 254XP
« Reply #9 on: September 09, 2005, 05:53:35 AM »
OLD_JD, I am quite sure that you made a good buy!
However, if it will fully replace the 254xp depends on what you are using your saw for, as it is a smaller saw, with less power output.
Huskys replacement for the 254xp in their lineup is the 357xp, I think.
Offline OLD_ JD
« Reply #10 on: September 09, 2005, 01:07:53 PM »
sawTroll i have a 257 who it's close to the 254xp...the 357xp was not to replace the 262 ??? however i try the 346xp and i like it pretty much for some small wood and limp 8)
Offline jokers
  • Chainsaw Freak
« Reply #11 on: September 09, 2005, 03:25:11 PM »
naw, the 362xp replaced the 262, it is a real screamer if you can find one.
Russ
Offline SawTroll
« Reply #12 on: September 14, 2005, 06:06:34 AM »
Just to make this "replacement story" a bit more complete (within the cc range mentioned);
As Russ said, the 362xp replaced the 262xp,
359 replaced 257,
357xp replaced 254xp,
346xp replaced 242xp.
Truck Saw Husq 460 vs Stihl 310 or Husq 455 vs Stihl 290
Started by 333_okh on Chainsaws
Last post January 17, 2007, 09:15:53 AM
by tcsmpsi
Husqvarna 455 Rancher or 460 Rancher?
Started by redshift on Chainsaws
Last post July 31, 2013, 07:16:35 AM
by John Mc
husq 61
Started by BubbasDad on Chainsaws
Last post April 16, 2015, 06:25:29 PM
by BubbasDad
450 Husq vs 545
Started by JW IN VA on Chainsaws
Last post January 02, 2017, 06:58:04 PM
by Fishnuts2
