KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Construction Question  (Read 76584 times)
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« on: September 13, 2005, 05:58:20 PM »
Tammy and I are putting up a 12 by 16 building.  We are using 2 by 6 rafters and a ridge board, for roof construction. The pitch we want is 6/12 or a simple 45% cut. My question is, is there a forumla to figureing out where exactly to cut the "birds mouth" where the rafters sit on the wall. We will be spanning the 16 foot direction. The ridge board will be a 2 by 6 as well. It would be nice to cut all of these pieces in advance.  So far we have our bearing walls up. Still need to build the gable end walls before we get to the roof.
Forestry Forum Founder and Chief Bottle Washer.
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
Re: Construction Question
« Reply #1 on: September 13, 2005, 06:32:36 PM »
Jeff,
If your rise over run is 6/12 then a cut of 45 is not going to work. That would be for a 12/12 pitch.
For a 6/12 I think you will need a 22 1/2 cut. If I understand what you are saying.  :D
A framing square is used to lay out the bird's mouth cut--held at 6" and 12".
Laying it out in AutoCAD would give you exact numbers but I don't have Acad on this computer. I suspect someone will have it for you before long though. If not, I will lay it out for you.
-Doug
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Offline DonE911
  • givme a minute, I'll think of something
« Reply #2 on: September 13, 2005, 06:34:22 PM »
Good question....  Last time I  did a roof I cut 4 rafters to death until I got one right...   then I put it down on the floor and made a jig so every one was exactly the same....  I still messed up a couple of em... no idea how that happened.
Offline mike_van
« Reply #3 on: September 13, 2005, 06:47:41 PM »
Doug is correct, a 45 will make the pitch 12/12.  Jeff, I use a framing square, they make 2 small brass knobs for it, on the outside edge you tighten one a 6" and on the long edge, one goes at 12".  Hold these against the edge of the rafter, you have your pitch angle. Works for stairs too.   There is a method for the length of the rafter called stepping off, I never learned it though. Easier for me was to cut the ridge cuts, lay the 2 rafters out flat with a piece as thick as the ridge board between them, then if your walls are 16' apart, lay a 16 footer across them, line it up good & even, mark the ends, thats where the birds mouth is.  The same angle set on the framing square will give you  both cuts for the birdsmouth.  Help any?????
I was the smartest 16 year old I ever knew.
Offline Gilman
  • !eliforp ym tide ot deen I
« Reply #4 on: September 13, 2005, 08:37:27 PM »
Here's a 6-12
here, I bolded the dim I think you are looking for.
Note: 2 x 4 walls
Here's a 12-12 Ski Lodge, 2 x 4 walls.
Let me know if you need any changes to wall thickness, etc.
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #5 on: September 13, 2005, 08:41:16 PM »
I cant read it. :-\    I can make out 144" but I need it for the 16 foot, outside to outside.  THe ridge beamd will be 1.5 inches thick.
Offline Gilman
« Reply #6 on: September 13, 2005, 08:48:54 PM »
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #7 on: September 13, 2005, 08:57:23 PM »
I'm pretty dense when it comes to that stuff, but I bet if I study this long enough I'll figure it out. :D
Thanks!  BTW, is it 22.5 degrees on my chop saw?
Offline woodbeard
  • Gender: Female
  • Sailors have sea legs, sawyers have board feet.
    • Dismal Guitars
« Reply #8 on: September 13, 2005, 09:04:14 PM »
Quote
Probably, but the angle is not going to be 22.5 deg.
You will have to lay it out the way Mike explained.
Then you can measure the angle, and set your chop saw to it.
Online Furby
  • Blurb....
« Reply #9 on: September 13, 2005, 09:06:34 PM »
Yup, ya need to double check with a framing square and set the saw to that. Remember the angle though in case ya need it later.
Offline Don P
    • Calculator Index
« Reply #10 on: September 13, 2005, 09:13:30 PM »
Jeff, a 6/12 is 26.5 degrees...5/12 would be 22.5 (half a 45)...which are you wanting?
Offline Gilman
« Reply #11 on: September 13, 2005, 09:25:08 PM »
Yep, it's 26.6 degrees
I like pictures  ;D
Offline Don P
    • Calculator Index
« Reply #12 on: September 13, 2005, 09:37:05 PM »
Try this calc out, I entered 95.25 (outside to outside 192" - 1.5" ridge) / 2.
http://www.ls.net/~windyhill/Calcs/raftercalc.htm
I then punched in 6...for 6/12
Then 0
0
0
and Show result
The plumb to plumb line length measured along the top or bottom edge is then given. It does give the same numbers as in a rafter table. Let me know if it doesn't make sense.
I like to make "yokes" to hold my ridge in place temporarily while I build the roof. Setting them at the right height was always a little tricky for me.
This calc will give the height to cut a prop under the ridge. It places the bottom edge of the ridge flush to the Bottom edge of the rafter's plumb cut. That's the "correct" location for inspector types.
Online Furby
  • Blurb....
« Reply #13 on: September 13, 2005, 09:39:43 PM »
Sorry, I'm just a simple framer..........it doesn't make sense. ;)
Offline DouginUtah
« Reply #14 on: September 13, 2005, 09:45:38 PM »
Jeff,
Do you want to have the inside open to the ridge or do you want to put a ceiling in so that you have a floor for an attic, with that additional storage space.
If you don't put a floor in, there is nothing tieing the bearing walls together. Weight on the roof (snow load) would try to squash the roof down and push out the walls.  The ridge board, supported at each end, will be all that is supporting the weight of the roof. It is only 12' but I doubt that a 2x8 would be adequate.
Now it's getting trickier. Attic floor joists would have to run the 12' direction so they wouldn't tie the walls together--just the flooring (OSB) would tie it. Maybe, this just being a shed, you could run the joists 16' but it would definitely be a spongy attic floor. Decision time!
-Doug
(I suspected that cutting the slope in half wouldn't make the angle half. Glad I said "I think you will need..." I always plot these out in CAD and dimension the angle.
-Doug
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #15 on: September 13, 2005, 10:03:36 PM »
Doug
  that could be solved with some collar ties .
   Marcel
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #16 on: September 13, 2005, 10:09:21 PM »
there is not going to be "attic" but there will be cross beams down about one and a half feet from the peak leaving a cathedral like ceiling.  I want a 6/12 pitch as that is supposedly what our house is.
Offline Don P
    • Calculator Index
« Reply #17 on: September 13, 2005, 10:14:03 PM »
Furby, try this one.
http://www.ls.net/~windyhill/Calcs/rftllclc.htm
It was an "earlier" model
If its still not clear give me stronger hints  :).
If those purlins are well supported in the endwalls and stout enough they can act as structural support and do the job just fine.
106.5" plumb to plumb, Jeff.
Offline isawlogs
« Reply #18 on: September 13, 2005, 10:17:04 PM »
  How many collar ties you putting in  Jeff  ???
   Marcel
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #19 on: September 13, 2005, 10:19:48 PM »
Rafters every 16 inches and coller tie on every rafter. Plan on insulating, and finishing with t and g pine at some point on the inside.
Construction question
Started by Dan_Shade on General Board
Last post August 21, 2015, 08:54:06 AM
by Raider Bill
New Construction Question
Started by CBRSLIDER on General Board
Last post December 04, 2004, 05:02:55 AM
by Norm
Quick question on crib construction
Started by CX3 on Timber Framing/Log construction
Last post October 21, 2010, 11:05:31 PM
by jander3
Question regarding use of rough sawn lumber for home construction
Started by brdmkr on Sawmills and Milling
Last post August 24, 2005, 08:11:20 PM
by Don P
