Arborwear
Author Topic: Truss Design for 24' Free Span w/Attic Storage  (Read 3644 times)
Offline stilloggin
« on: November 08, 2006, 10:15:18 PM »
I'd like to get some suggestions for truss design for a shop I am planning.
I'd like the width to be 24' to 26' without any support posts.  But, I'd also like attic storage...nothing heavy (<2 psf).  I've looked at a King Post design using a 12/12 slope, but I think the struts would be too intrusive to be used for storage.  I'm reading up on Queen posts as they seem promising.
Should I give up on the storage and 'show-off' the King post/struts?
Thanks.
Offline Raphael
  • Willing and able to do a boring job.
Re: Truss Design for 24' Free Span w/Attic Storage
« Reply #1 on: November 08, 2006, 11:57:30 PM »
  I don't think simple queen posts will work in this application as they work in compression (propping up the roof) and do nothing to support the attic floor.  My engineer's barn has a very cool canted queen/scissors arrangement which allows clear span on the first floor and enough load bearing capacity on the second floor for his workshop.  I wish I'd got a couple pictures before they enclosed it.
  The king post works in tension holding up your spanning beam and giving your attic floor the support it needs.  As a majority of attic floor space is between the king posts the actual space loss isn't too excessive.
... he was middle aged,
 --Godley & Creme
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #2 on: November 09, 2006, 08:08:44 AM »
You can review the pictures of king post trusses at Fox Maple in the thread about king post, and Fox Maple pictures in my gallery.
You might need to have a king post truss with small queens as well.
Any design should be built for future use as well as current use. If you sell the property will the new owners know that the floor load rating is only 2 psf?
You maybe should build it to standard loads now, the right way or no load at all, and forget the attic storage idea......
Jim Rogers
Offline stilloggin
« Reply #3 on: November 09, 2006, 09:41:34 PM »
The Fox Maple barn looks like a real nice project.  It is similar to the Hall School Storage Barn described/built by Sobon and Martin in 'Timberframe Construction'.  This was sort of my inspiration.  It looks like the FM barn has two-piece tie beams, which would work better for me as I can only saw 20' on my bandmill.  It seems a bit wider, too.  Can you remember the dimensions?  Are these plans available anywhere?
You make a good point regarding the attic storage...do it right or make some pretty trusses enjoyed from the floor.
Thanks.
Offline Max sawdust
  • If it's got to do with making sawdust; count me in!
    • truetimbers.com
« Reply #4 on: November 10, 2006, 06:35:39 AM »
I am currently constructing a shed with splined tie beams.  Look at the thread on "tractor shed" and the thread on "king posts".  Personally I would be Leary to use a two piece tie beam if you are going to have any additional loads in the attic.  Then again the only way to know is do the engineering.
I would not let your band mill bed length be the limiting factor.  I have not done it yet but you can cut longer than you band mill bed by sliding the log down and making a second cut.  Do a search on the entire forum, you will find several posts on the subject.  Could be fun to try ;)
max
True Timbers
Cedar Products-Log & Timber Frame Building-Milling-Positive Impact Forestscaping-Cut to Order Lumber
Free span with hammer beam truss Qs
Started by Rooster on Timber Framing/Log construction
Last post August 17, 2009, 05:52:27 AM
by Mad Professor
truss design
Started by brdmkr on General Board
Last post November 08, 2006, 07:00:50 AM
by Patty
Truss design for carport
Started by bbaley on Timber Framing/Log construction
Last post December 16, 2017, 02:41:59 PM
by AlaskaLes
Round log truss design
Started by RMS on Timber Framing/Log construction
Last post January 30, 2014, 09:11:13 AM
by Thehardway
