Arborwear
Author Topic: Air Dried Bald Cypress - Amount of movement?  (Read 1509 times)
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« on: January 03, 2007, 10:55:03 AM »
How much "movement" (difference in width across the face of the board throughout the year) should be anticipated in 5/4 bald cypress flooring/decking if the lumber is properly air dried to 11% before use and if all surfaces are finished with an oil-based product prior to installation as t&g flooring on a covered (but not enclosed) porch? I'd like to use 6" wide boards but am willing to drop back to 4" if it will make a significant difference.
The location is in the Panhandle of Florida but not directly on the coast (approximately two miles inland).
Re: Air Dried Bald Cypress - Amount of movement?
« Reply #1 on: January 03, 2007, 11:07:33 AM »
Forgot to mention it will be flat-sawn...
Offline Don P
    • Calculator Index
« Reply #2 on: January 03, 2007, 07:36:48 PM »
http://www.woodbin.com/calcs/shrinkulator.htm
That link takes you to a good shrinkage calculator, there is a link there to an emc page also.
Narrower width doesn't change the overall shrinkage per foot but does reduce the gap per board. For me the 6" would be fine
Offline ellmoe
« Reply #3 on: January 04, 2007, 07:10:57 AM »
     I think that you will find that the moisture content in the lumber used in a covered porch will equalize to 12-15% over time. You should be in good shape.
Nice Bald Cypress
Started by WDH on Tree, Plant and Wood I.D.
Last post November 30, 2006, 07:56:09 PM
by WDH
nice stand of bald cypress. What to offer?
Started by DWM II on Forestry and Logging
Last post September 29, 2006, 08:37:33 PM
by DWM II
Solved: A Tree Leaf (bald cypress by Rusty)
Started by Tom on Tree, Plant and Wood I.D.
Last post August 01, 2003, 06:18:56 AM
by Tom
First Load of Solar Dried Cypress
Started by JackLeg on Drying and Processing
Last post June 15, 2008, 02:36:04 PM
by JackLeg
