Arborwear
Author Topic: 12 volt drive motors  (Read 2825 times)
Offline ED B
« on: January 23, 2009, 09:54:07 AM »
Looking for a 12volt drive motor, I need to drive two rollers to make my project a one man operation!
Do It With WOOD!
Offline pineywoods
Re: 12 volt drive motors
« Reply #1 on: January 23, 2009, 10:00:58 AM »
Find yourself a junked electric wheelchair. The motors are 24 volt but they have plenty of oomp on 12 volts. Will have a built in worm gear reduction box...If you need to vary the speed try www.electronickits.com for cheap dc motor speed controllers. I use one for a home made autoclutch on my WM..
Offline beenthere
« Reply #2 on: January 23, 2009, 10:54:26 AM »
There is a 12v motor in my old treadmill....that I use without power.
Offline ED B
« Reply #3 on: January 23, 2009, 11:57:20 AM »
Are you willing to sell it?
Do It With WOOD!
Offline beenthere
« Reply #4 on: January 23, 2009, 02:49:53 PM »
Hadn't thought about it, as I still use the treadmill...to walk on and the motor is the drag. I'd need to fix up a way to add that drag if I removed the motor.
But, mentioned it as a potential source of a 12 v motor.
Offline ED B
« Reply #5 on: January 23, 2009, 03:09:00 PM »
one more source and a great idea. Thank you
Do It With WOOD!
Offline HOOF-ER
« Reply #6 on: January 23, 2009, 08:55:54 PM »
Surplus center if you are looking for new.
Home built swing mill, 27hp Kawasaki
Offline Polly
« Reply #7 on: January 23, 2009, 11:52:06 PM »
     ford 12 volt car starter motor is same as the one on my woodmizer hydraulic pump  :) 8)
Offline gibby
  • I was new here.
« Reply #8 on: February 02, 2009, 10:14:26 AM »
car door window motors
Offline Night Raider
« Reply #9 on: February 02, 2009, 08:29:43 PM »
I second the car window motors, I've used them on a project at work, running them at 30V to open truck roll up doors.
farmall cub 6 volt to 12 volt converson
Started by Polly on General Board
Last post May 15, 2009, 08:45:35 PM
by Polly
Comparison of Rim & Drum drive to Spur Sprocket drive system
Started by Jim Spencer on Chainsaws
Last post April 14, 2007, 03:13:48 AM
by joe_indi
Belsaw belt drive to drive shaft conversion
Started by Joe Lallande on Sawmills and Milling
Last post November 15, 2008, 06:44:27 AM
by bandmiller2
24 volt or 12 volt
Started by Mavis on Sawmills and Milling
Last post January 10, 2018, 08:06:23 PM
by Mavis
