Arborwear
Author Topic: oak lap siding?  (Read 6294 times)
Offline samandothers
Re: oak lap siding?
« Reply #20 on: October 08, 2017, 08:48:05 AM »
I understand that Carpenter bees will not bore in Cypress either, so I have been told.
Offline btulloh
Re: oak lap siding?
« Reply #21 on: October 08, 2017, 09:07:38 AM »
I've had lot's of damage to ERC from carpenter bees.  Never seen them eat cypress though.
HM126
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
Re: oak lap siding?
« Reply #22 on: October 08, 2017, 11:43:35 AM »
Since they will eat right through treated lumber of any type, they must be eating without digesting, or chewing and spitting out. Paint and stain don't seem to stop them either.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oak lap siding?
« Reply #23 on: October 08, 2017, 04:13:47 PM »
Oh yes, they will definitely bore holes in Cypress.  They do not eat the wood.  "Sawdust" will be dropping from the hole as they bore and they reuse the holes year after year.
Offline MbfVA
Re: oak lap siding?
« Reply #24 on: October 08, 2017, 06:02:42 PM »
 I would also suggest plugging the holes after shooting some poison in them. They will reuse & expand them.
Offline MbfVA
Re: oak lap siding?
« Reply #25 on: October 09, 2017, 03:13:19 AM »
Comment on the woodmizer lap siding attachment: I have not used it but I have seen one and it is very large.  The owner commented that it requires heavy equipment to put on the sawmill bed.  It's also the most expensive of all the lap siding attachments I've seen.  The one for my Peterson is a small fraction of the cost of the WM unit, which is also a lot higher than for Norwood & some other band mills, but your mileage may vary since there are significant differences in what they can do.
 I'm not knocking its quality, just making objective observations.  I would say that the WM attachment is both the most expensive, and the most complex and probably productive looking one.  But recall that I have not used any lap siding maker.
There is a thread on this forum, possibly more than one, about doing lap siding boards without using an attachment.  It may boil down to a production/speed issue.   As with any attachment or add on, "how much are you going to use it"?
 ???  smiley_blue_bounce Kaswell type flooring comments, anyone?
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
Re: oak lap siding?
« Reply #26 on: November 12, 2017, 06:32:33 AM »
Funny that this blog should revive now. I've been off the forum for a couple of years, just checking in now and then, but recently started actively reading again. So I have several comments on issues raised here.
First, as to the siding I put up on several houses over the years (now four buildings total- three houses and a barn): still looks fantastic and I'm very pleased with the choice I m1ade back then. One key issue was carpenter bees which we have a lot of here in southern Mississippi. Everything I've read and experienced says that paint and/or stain plus seal will discourage them. My findings: it works about 95% of the time and is certainly better than nothing. Only had a couple places that clear seal didn't keep them out, and both were in pressure treated beams and posts- maybe the stain and clear coat didn't penetrate well? On lap siding: no indication of any holes anywhere, which says stain plus seal works.
Next question: do you need a lap siding accessory? Maybe if you have money to burn, sure, buy one. Never used one myself since I've cut all my lap siding as flat boards. Started with 1" nominal but recently dropped it to 3/4" for two reasons: more boards per log PLUS a lot lighter and easier to handle and install. Of course, drying is important and I sticker and stack to let them air dry. Not crucial if you want or need to put siding up wet but as stated above, wet boards drying in the sun will curl, maybe crack and check bad, maybe even pull away from nails/screws holding them up.
Let me load some pictures up to my folder (if I can remember how) and I'll show you some of what I'm talking about.
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
Re: oak lap siding?
« Reply #27 on: November 12, 2017, 10:37:03 AM »
Good to see you back on the Forum LJ!
Herb
Offline ljmathias
Re: oak lap siding?
« Reply #28 on: November 12, 2017, 09:07:57 PM »
Thanks, Herb; now on to a topic we all love to talk about: Carpenter Bees! Those lovely little non-stinging members of the insect world that bring such delight to anyone lucky enough to have them around... NOT!
I usually reserve the word "hate" for really evil, dastardly creatures such as fire ants that I'm standing in while I try to cut down a dead oak. But I find myself detesting these creatures that have no purpose I can fathom other than to destroy perfectly sound lumber. Sadly, they prefer wood that is in a building of some kind, not caring whether it is vertical, horizontal, or overhead. As long as they can fly up to or onto it, no piece of lumber is safe. Left unchecked, the eggs they lay hatch and fly away (to some distant corner of Hades) only to return to repeat their mother's infestation efforts.
The saddest part, and the part that really gets my goat (although my daughter has some, I actually don't) is that they don't care about the wood at all- it's not a food source, such as termites can be forgiven for enjoying, but just a place to lay their eggs. Problem is, they don't feel secure doing that unless they chew their way deep inside and tunnel far from the perfect circle of their entry point. Hate 'em! Sorry.
Pictures below show some of the damage to my pole barn- only some. They've now drilled tunnels in most of the rafters and many of the posts. I expect it to collapse any day now, releasing more hordes of newly-hatched bees that will seek new structures to destroy. And to clarify: the puffs of orange are spray-in insulation that I tried unsuccessfully to stop them from exiting; they just drill out somewhere else. And the extensive damage that looks like I tried using a chain saw to buzz them out was nature's way of doing so: woodpecker holes. Seems they can hear the lavae moving around and love the flavor.
Oh, well, there are solutions (and I really don't have time to BB gun them all, although that does sound like great fun). Turns out, you can build a "trap" that will catch them. They think they're entering an old bee tunnel but it's actually a short drill hole leading to the slippery sides of a discarded water bottle: they slide down inside never to threaten another building!
Next post will have pictures of siding that's 6 to 10 years old now and still worth looking at...
Offline ljmathias
Re: oak lap siding?
« Reply #29 on: November 12, 2017, 09:35:07 PM »
Now I'd like to respond to questions about siding. And do you need oak for this? Heavens no! Pine works great and actually looks better than just about any other wood you can mill yourself- if you stain it, that is. And why stain it? Protects the wood from decay brought on by sunlight and oxygen which not only turn pine gray and grayer over the years but cause it to rot away to nothing given enough time.
Let's start with the horse shed we built for my daughter and her husband. Oops, I mean for their horses. Couple pictures below show the two year old structure (or maybe three) from several angles. Nice thing about this kind of siding, which I saw flat, is that it's easy to make, easy to stain and put up, and then easy to clear coat to keep Carpenter Bees out (see earlier post).
Now my daughter's house, finished in 2012. This is the one I almost slid off the roof of while installing metal roofing and only saved myself from a 20' fall by grabbing the edge of the piece I'd just screwed down; finger working again, barely, after re-attaching muscles...
Several views of her siding, front, side and back of house. Not been touched since we stained it, put it up wet from stain, waited a month and then put on clear coat that is uv safe. Still looks great, to my mind.
Now on to my son's house next door, completed about 10 years ago. Same story here: still looks great after stain plus clear coat, even in the side with some direct sunlight. The red color in one of these is not the real color- took picture in the late afternoon with sun behind me, must have fooled the camera...
Now the latest efforts: we're building a house on the property for my other daughter. She's the oldest but it took her a while to see the wisdom of living nearby. Not wisdom for her, necessarily, but for me and the wife so we can know they're nearby in case of hurricanes and such. The boards you see were cut from a mix of older logs I'd stored in the pole barn (that the carpenter bees hadn't totally devoured) and some newer ones. Fresh cut lumber from fresh downed trees work best if you want clear, bright color. You have to sticker and stack with good air flow for air drying. Leave a month or so and they're ready to serve.
Two years ago I bought another trailer (which my wife was against but it came under the "easier to apologize for than ask permission" mode of operation I often use). I really did need it for something I can't remember now, along with lots of other things... Anyway, I had stacked the boards hot off the mill onto one of the trailers. We used the other to cart lumber over to the building site for footing forms and walls, and then for metal roofing (which we just finished installing yesterday). Brought that trailer back next to the first one for transfer: pulled boards from the top of the stack, stained them, restacked them on the other trailer. Worked great, and gave us the opportunity to find the best color boards for the front of the house. Once we had enough of those, hauled that trailer over to the building site for installation this week. I'll post pictures of the (shall we say "unique") combination of rusted tin and live-edge siding they wanted.
Enough for now- got to sleep some.
LJ
Offline fishfighter
Re: oak lap siding?
« Reply #30 on: November 15, 2017, 06:04:51 AM »
On my sawmill shack, I used water oak live edge. Some was installed at the beginning of the summer. Sun has hit it hard that turned it a nice gray. The boards were full cut from logs.
What I found out about using these boards and installing them wet is that the boards that came off the log close to center of the log checked. :( Now the boards that came off a good 4" away from the center didn't check. ;D No problem with the boards cupping. Used ring nails that are not pulling out.
Finished building that I am waiting for the eves to dry/gray out before I treat them.
Another trick I found out is that by taking two cuts per side and flipping the log over helped a lot.
Offline ljmathias
Re: oak lap siding?
« Reply #31 on: November 15, 2017, 07:09:52 AM »
Look great if you like grey. If you stain, it will protect the wood better from uv and keep color longer- just saying... plus if you have carpenter bees, they might find your boards very tasty.
Any advantage to using valuable oak for siding? Pine seems to work fine if stained and sealed (at least down here in Mississippi) and I use the oak I do have (not enough) for furniture and interior stuff. It's not look these are renewable resources or anything   :D
LJ
Offline fishfighter
Re: oak lap siding?
« Reply #32 on: November 16, 2017, 07:56:03 AM »
I will be treating it once everything matches. ;D Reason I use oak is that is all I have growing on my place. There is no pine at all. I have over 200ac of timber I can cut from. All bottom land off the Mississippi river. I do have cypress, but that is some what a no no to fell. My granddad would roll over in his grave if I fell one tree. :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oak lap siding?
« Reply #33 on: November 16, 2017, 09:39:14 AM »
It's so good to see you finally come up for air lJ.  Now please don't be a stranger.   :)
Offline PA_Walnut
Re: oak lap siding?
« Reply #34 on: November 17, 2017, 05:00:10 AM »
About to saw some siding for a building I'm putting up. Any comments about poplar for siding? I have plenty of it and it's ready to cut.
Thx
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline ljmathias
Re: oak lap siding?
« Reply #35 on: November 17, 2017, 06:18:27 AM »
Poplar has pros and cons, in my book. It's natural colors aren't all that pleasing to me, from white to pink and green to dark brown. Now the heart wood is fantastic, a beautiful chocolate brown that looks great without stain and just a clear coat to protect it. It's soft so you need something. I have a couple of desks made from poplar heart wood (100 year old tree my neighbor cut down- all but outer 2 inches of 40 inch diameter trunk). The desks look great and my wife and grandkids use them everyday.
I don't know about weathering-someone else can jump in on that. I do know it's pretty soft till it dries completely, then it's pretty hard. I use it often for trim around windows and doors on houses that I put live-edge pine on. 2X2 or bigger, stained with dark walnut and clear coat on top. Looks great, I think.
LJ
Online Don P
    • Calculator Index
Re: oak lap siding?
« Reply #36 on: November 17, 2017, 08:04:23 AM »
It is the most common lap siding here on old houses, 5/8x6. I've taken it off at ~100 years old and it looks like upside down bevel lap siding, the lower edge worn to almost a point. Those houses didn't get painted till much later, if at all. I think the good old heavy bodied lead paints did a good job blocking out carpenter bees. I used Kilz primer on the last job and they looked but I didn't see any bore. Poplar is a great paint grade or staining wood. A good finish man can make you think it is any of a number of woods. I have one embarrassing fascia I need to go repair. I used poplar for fascia behind a gutter that leaked. The gutter fell and the bottom of the fascia is gone, I think about 15 years. They wanted traditional galvy gutters which lasted about that long. White oak this time round, and a better gutter!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oak lap siding?
« Reply #37 on: November 17, 2017, 08:50:08 AM »
In my "neck of the woods" Tulip Poplar is very commonly used as Board & Batten siding.  I have sawn many thousands of bf for B&B, but never for lap siding.
Offline ljmathias
Re: oak lap siding?
« Reply #38 on: November 17, 2017, 10:25:12 AM »
So, MM, good to be back, hopefully for a long while.
Still the question of how the siding you sawed from poplar was finished: nothing? stain only? clear coat only? paint? Any idea that might help our questioner?
Making progress on my daughter's house- pictures to follow of siding I showed before installed on the front of the house...
LJ
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oak lap siding?
« Reply #39 on: November 17, 2017, 01:46:31 PM »
No finish, just bare Poplar.
2 Part ?? Siding attachment for mill & Is pine a good choice for house siding?
Started by Piston on Sawmills and Milling
Last post May 24, 2015, 12:19:50 PM
by Piston
ERC siding & siding in general
Started by TexasTimbers on General Board
Last post May 08, 2007, 07:28:26 AM
by Cedarman
ERC Siding
Started by Tree Feller on Sawmills and Milling
Last post November 18, 2012, 08:28:08 AM
by florida
lap siding
Started by kcbarnes on Sawmills and Milling
Last post November 13, 2001, 06:58:35 PM
by kcbarnes
