Arborwear
Author Topic: Homelite leaking bar oil  (Read 19424 times)
Offline ADAMINMO
  • Today is gonna be another one of those days!!
« on: June 17, 2009, 01:52:36 PM »
I have had for many years now a Homelite chainsaw(33cc) that I bought at Walmart.From day one it has leaked the bar oil out of it. I recently bought  a larger Homelite chainsaw (42cc) and it does the same thing. Any Ideas why they do it. It looks as if it comes out of the tank where the hose goes into through a rubber grommet and the to the bar hole.Makes me wonder if it is expanding due to heat and being pushed out ,as I dont notice it to do it in the winter time. It makes a heck of a mess and I get tired of having to clean it up in my truck bed or the shop floor. Any help or ideas are greatly appreciated.
Offline Sprucegum
Re: Homelite leaking bar oil
« Reply #1 on: June 17, 2009, 02:09:29 PM »
 :( I can't help you except to say "you are not alone"  ::)
I have a homelite, a Husky, and an Echo and everyone leaks worse than the last  >:(
Online beenthere
« Reply #2 on: June 17, 2009, 02:22:36 PM »
Adam
Does it make any difference if you crack open the filler cap/plug to relieve any pressure from the oil warming up?
Offline ADAMINMO
« Reply #3 on: June 17, 2009, 02:29:28 PM »
Not sure. They usually sit out in the shed for several weeks before I need to use them and I then find a puddle of oil or if I leave them in the truck bed for a few days(has bed cover on it).Guess I could crack the filler cap a little to see if it helps.
Offline ENTS
« Reply #4 on: June 17, 2009, 04:18:08 PM »
I know it's not a Homelite, but my Hq. 353 leaks all the time, since day one.  Asked the service dept. about it and they just said it's the nature of the beast.
Fred Henry,  Over Worked, Under Paid
Offline Ironmower
« Reply #5 on: June 17, 2009, 04:56:58 PM »
The only way I get mine to stop leakin is not to put oil in it.  ;D
WM lt35 hd 950 JD
Offline caz
« Reply #6 on: June 17, 2009, 08:25:15 PM »
Put a sadle bag on it, put some extra oil in it and call it your Harley Homelite
Offline mburrow
« Reply #7 on: June 17, 2009, 09:29:13 PM »
cracking the cap will not stop it, I have the z3300 and it does the same thing.it is the way the oiling system is made
Offline SouthernRumRunner
« Reply #8 on: June 22, 2009, 09:20:51 PM »
I always though that was normal for a homelite :D I just put some old newspaper under them.
Offline alsayyed
« Reply #9 on: June 23, 2009, 02:03:21 PM »
Hello Damini and hello to everybody. Do not panic I can tell you what is the problem with Homelite chainsaw oil leak. There is little procedure you have to go through.
Problem # 1 takes the oil out off the tank. Pour kerosene in the tank and start running the engine. After running the engine you will notice immediatly where is the leak is coming from the reason I have said that because kerosene is very light substance.
Problem # 2 checks the seal which is located under the oil pump sometimes it get broken.
Problem # 3 this is very important check the gasket which is installed between the   chainsaw bodies, it is like paper, this is very important sometimes oil is coming from that area if the gasket have damaged.
Good luck
Offline mburrow
« Reply #10 on: June 23, 2009, 05:37:43 PM »
here is a parts list
Offline ADAMINMO
« Reply #11 on: June 23, 2009, 05:58:04 PM »
#15 on the oil tank parts list is where both of mine leak at.
Offline John Mc
« Reply #12 on: June 24, 2009, 03:36:00 PM »
I had a Jonsered 2141, and now a 2152 that both leaked. I couldn't find the source (I have to admit I didn't look very hard). I did ask the dealer where they were purchased, and he said "it's just the nature of some of these saws". Got a used Husky 357XP and it never leaks. A friend with another 357 leaks as bad as my Jonsereds.
Alsayyed's post has me wondering if I may have messed up the gasket between the two halves of my case. I pulled some bolts from the front of the saw to replace the dogs shortly after I bought it. The oil tank may have been pressurized at the time, due to temperature changes. Wonder if I blew the gasket out at that time?
John McNerney
Offline mike_van
« Reply #13 on: June 24, 2009, 05:45:39 PM »
"it's just the nature of some of these saws". Boy, that sounds like a cop-out, huh?  I've got three 35 year old Homelites that get used most everyday & don't leak.
029 leaking bad
Started by tstex on Chainsaws
Last post November 10, 2011, 07:17:58 AM
by Al_Smith
Classic leaking?
Started by petefrom bearswamp on Firewood and Wood Heating
Last post January 03, 2014, 09:10:09 PM
by coxy
exclamation
Help, How do I stop oil leaking from behind bar !!
Started by Greenerpastures on Chainsaws
Last post February 23, 2017, 07:41:26 AM
by sandsawmill14
Leaking cistern
Started by Qweaver on General Board
Last post September 29, 2009, 10:13:51 AM
by Qweaver
