Arborwear
Author Topic: How long & best way to dry cedar log?  (Read 6118 times)
Offline fmjohnson
« on: July 12, 2009, 03:23:58 PM »
I just cut down an Eastern Red Cedar, approx. 18" in diam. that I would like to split and use as a mantel on my son's fireplace. What is the best way to dry it? How long? When should I remove the bark? Any other tips would be greatly appreciated. Thanks in advance for your input.
Offline LeeB
Re: How long & best way to dry cedar log?
« Reply #1 on: July 12, 2009, 04:00:21 PM »
Leave the bark on for a while and let it set on the ground if you want the outside to have a worm eaten look after you remove the bark. You say you're going to slit it. Do you mean that literaly or are you going to saw it? I like my mantals sawn 3 sides and live edge on the front. With size log I would shoot for 14" x 6" and get some side wood out of it. You could also get 2 half rounds, actually more like 1/3 rounds. Cedar is naturally pretty dry. Should be dry enough for your purposes in about two months.
Offline fmjohnson
« Reply #2 on: July 12, 2009, 09:04:38 PM »
Thanks for the reply!
How long can I keep cedar logs ?
Started by Daren on Sawmills and Milling
Last post June 29, 2005, 10:18:40 PM
by Tony
Cedar Logs coming- Advice Needed-Sorry for long absense
Started by alpmeadow on Sawmills and Milling
Last post March 15, 2011, 08:44:34 AM
by alpmeadow
Cedar Cedar Cedar, I'm sick of freaking Cedar.
Started by dad2nine on Sawmills and Milling
Last post August 24, 2006, 11:03:38 AM
by Onthesauk
Been a long long time since I last visited
Started by Bothy_Loon on Sawmills and Milling
Last post August 08, 2011, 11:44:29 PM
by Bothy_Loon
