Arborwear
Author Topic: Husqvarna 570 stalling problem  (Read 2593 times)
Offline fstedy
« on: October 06, 2010, 07:21:18 PM »
I have a Husqvarna 570 that keeps stalling. When starting I can keep it running by pulling the choke out breifly when it starts to quit. Sometimes if you catch it in a fast idle it will take full throttle ( sometimes when doing this it quits after about 15 seconds, sometimes it will cut a log thru ). I cleaned the air filter changed the fuel filter and the spark plug was checked OK. Any suggestions where to proceed?
Timberking B-20   Retired and enjoying every minute of it.
Former occupations Electrical Lineman, Airline Pilot, Owner operator of Machine Shop, Slot Machine Technician and Sawmill Operator.
I know its a long story!!!
Offline Rocky_J
Re: Husqvarna 570 stalling problem
« Reply #1 on: October 06, 2010, 07:42:47 PM »
Sounds like it's running lean, perhaps due to an air leak somewhere. I'd check fuel lines as well as the impulse line. That's the quick easy possible cause, and quite likely due to the havoc caused by ethanol fuels. You'd think the manufacturers would have introduced ethanol resistant fuel system components before ethanol fuel was forced upon us.  :-\
Offline John R
« Reply #2 on: October 06, 2010, 09:26:19 PM »
That'd make way to much sense.
John
Sthil MS 361 20" Bar
Sthil MS 260 PRO 16" Bar
Oregon 511 AX Chain Grinder
Offline fstedy
« Reply #3 on: October 07, 2010, 05:36:35 PM »
Where is the impulse line? I'm not very knowledgeable about chainsaws.
044 ,weird stalling/idling problem, any ideas?
Started by skipster on Chainsaws
Last post September 22, 2015, 05:31:45 AM
by skipster
Husqvarna 359 problem
Started by Victor on Chainsaws
Last post July 02, 2008, 02:37:20 PM
by jokers
Husqvarna 365 problem
Started by Jonrfreeman on Chainsaws
Last post January 24, 2014, 01:22:12 PM
by Grandedog
Husqvarna rototiller - a potential problem
Started by jkj on General Board
Last post September 06, 2006, 05:34:56 PM
by Onthesauk
