EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: 4/53 Turbo  (Read 1011 times)
Offline Autocar
4/53 Turbo
« on: November 03, 2010, 02:11:26 PM »
 I'am not to far from rebuilding or replacing my detroit in my treefarmer. My question would you have it rebuilt or buy a remanufactured one ? I look it over and hear how easy it is to rebuild one but when I pull my book out and read about whats all required to get it all timed ect. it kind of gives me the willeys  :D Ive never been one who says it can't be done but at the same time you have to know your ability on some things. The back two cylinders are weak and now sence it has turn off colder when I get it started it is only running on two cylinders. Then after a minuite or so it must warn up and hit on all four. It has to affect the pulling power but so far I am able to pull anything I grapple. It has a blower and turbo they also should be looked at to I figure. Buy now all I see is dollar signs.
Offline bushmechanic
  • Someone else has it worse than you.
Re: 4/53 Turbo
« Reply #1 on: November 03, 2010, 07:04:16 PM »
My advice to you would be go with a rebuilt that was done at a reputable shop.Contrary to what people say those engines are not easy to rebuild,there are a lot of moving parts in that engine,and to do justice to a rebuild you have to check everything and replace what is worn.In my experience you can use a 53 series until there is practically nothing left internally but then you have to do a complete rebuild not just bearings and rings but the whole nine yards.You should do a compression check because you may have a couple of problem -matic injectors,also check your feul lines for restrictions from dirt as it will give you the same functions as a dead cylinder(dirt holds up around 90 degree fittings like goes into the filters).
Double Hard Turbo 7 verses Bi-Metal Turbo 7
Started by Beavertooth on Sawmills and Milling
Last post July 04, 2017, 09:01:19 AM
by petefrom bearswamp
wtb turbo for a 425 cat 3406b the number on the turbo is 7c6609
Started by lmo506 on Wanted
Last post May 12, 2017, 05:02:17 AM
by lmo506
4s vs turbo 7s
Started by Crossroads on Sawmills and Milling
Last post March 14, 2018, 06:50:08 AM
by Lawg Dawg
Started by coxy on Forestry and Logging
Last post November 06, 2013, 10:29:05 AM
by wetdog
