Arborwear
Author Topic: Honda GX620 No Spark  (Read 6243 times)
Offline leweee
  • Illegitimus non tatem carborundum
« on: November 22, 2003, 12:24:52 PM »
 :'(Anyboughty have a story about their 20 Hp ignition problem and how it was solved. I need stories with happy endings now. Anything to cheer me up ??? Leweee
Offline Kevin
Re: Honda GX620 No Spark
« Reply #1 on: November 22, 2003, 01:24:28 PM »
Does that have an oil sensor that kills the engine?
Offline leweee
« Reply #2 on: November 23, 2003, 07:20:28 AM »
yes Kevin it does.oil alert system, oil level switch,engine stop diode,even a fuel shutoff.plugs are wet so I assume the fuel is not the problem.it has always been hard to start cold.anyone have these problems with their 20 hp or is it  just me? ::)
Offline Kevin
« Reply #3 on: November 23, 2003, 07:26:19 AM »
Check the oil level then disconnect the oil sensor wire.
I had one like that on a Kohler, maybe not related but it's a quick check.
Offline leweee
« Reply #4 on: November 23, 2003, 08:17:40 PM »
Thanks Kevin; beenthere &done that.honda tech coming tomorrow. will keep you posted on the unfolding progress in the saga of the sparkless Honda.Wait I hear a beach boys tune " help me Rhonda"playing in the back ground... gotta go rewrite those lyrics... leweee ::)
Offline Kevin
« Reply #5 on: November 23, 2003, 08:39:45 PM »
You could install an inline spark tester and watch for the spark.
If the spark is good it may be the plug or a flooding problem.
Let us know what you discover.
Not water in the gas, eh?
Offline Mark M
  • Wilton, ND
    • Some of My Pictures
« Reply #6 on: November 24, 2003, 02:52:57 PM »
I did a little milling on Saturday. My 20 hp Honda was hard to get started but it was only about 15F. Once I got it started it ran fine but would kill at the end of every cut unless I kept my hand on the throttle and let it return to an idle slowly. I know a lot of people have had cold weather problems with this engine so I wasn't too surprised. For no more cutting than I plan to do this winter I can live with it.
Offline OneWithWood
  • I am happy!
    • elmhouseindiana.com
« Reply #7 on: November 24, 2003, 02:56:45 PM »
If you haven't already, trace and test the wiring from the ignition switch on through to the plug cap. :P :o
One With Wood
www.elmhouseindiana.com
Offline EZ
  • Betya can't cut just one!
« Reply #8 on: November 24, 2003, 05:14:28 PM »
Ha Mark M, my Briggs does that in the winter time. I put a couple of pieces of duct tape over the cooling vent and it work ok. I think the carb ices up from to much air flow.
EZ
Offline dail_h
  • G-Diddy and the Baby Hurlenator
« Reply #9 on: November 25, 2003, 07:23:09 AM »
   Hey guys,
  There's a bunch of stuff 'bout the Honda 20s over on the Norwood equipment forum. Best I remember there was a problem from the factory with a bunch of engines,Hond ducked and dodged a bunch,but finally cane up with a fix.Check with the rep with serial number ,they should have a list of affected nos
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Offline etat
  • Member*
« Reply #10 on: November 25, 2003, 04:32:32 PM »
Not an expert or professional, but have you tried kicking it!
question
Honda GX620 not charging battery
Started by losttheplot on Sawmills and Milling
Last post April 13, 2016, 08:15:12 AM
by Ox
Honda GX620 flywheel magnet
Started by Fla._Deadheader on Wanted
Last post December 04, 2012, 08:11:09 AM
by Fla._Deadheader
Honda motor no spark
Started by Bigmikessmallen on General Board
Last post September 10, 2017, 08:15:28 PM
by dgdrls
moved
MOVED: Honda motor no spark
Started by Roxie on Ask The Forester
Last post September 09, 2017, 01:41:27 PM
by Roxie
