Arborwear
Author Topic: 10' X 12' Timber Frame Shed (Raising the Frame)  (Read 25122 times)
Offline jander3
    • Peeling Logs
Re: 10' X 12' Timber Frame Shed (Raising the Frame)
« Reply #20 on: September 07, 2011, 08:18:18 PM »
Stained the aspen with a standard Cedar stain.
Today, we installed the ridge and 1/2 the rafters.
Jon
Offline ljmathias
  • Been sawing part-time almost 27 years now
    • Polymer Science Learning Center
« Reply #21 on: September 08, 2011, 04:45:10 AM »
Beautiful is all the comes to mind- and don't fall off the beam...   :D
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
Offline Brad_bb
    • My timberframe blog
« Reply #22 on: September 08, 2011, 12:52:18 PM »
So is this a tool shed?  Is the loft space for storage, or do you plan to sleep there when you're in the doghouse?
Offline Sprucegum
« Reply #23 on: September 08, 2011, 01:20:23 PM »
Thanks for the tutorial  8)
Do the rafters meet each other above the beam?
Offline jander3
    • Peeling Logs
« Reply #24 on: September 08, 2011, 10:17:31 PM »
The shed will be closed in; I will add heat and electric.  That way I can use this space as a small workshop to keep my busy during the winter months.
Rafters are 2"x6" and secured with 8" timber screws.  The rafters have bird's mouths cut at ridge and plate.  I allowed 1/2" to 3/4" space at the peak (between rafters) as the ridge log was far from straight and true.  In general I fitted rafters individually.   Next time, first thing, I will find 3 very straight and and very true logs to set aside for plates and ridge.  It will make rafter cutting so much easier.
Today, we finished installing the rafters, added some 1"x6" nailers and put up the tin.   Ordered the ridge cap, but that will take a week or two to get in.
Rafters installed and nailers for the tin.
Screwing in the last piece of tin.
Tin installed sans ridge cap
I spend three days with my younger brother putting up this structure.  Man, it doesn't get much better than that.  And, this was the first project in years where I actually had help.   A guy sure could get spoiled with an extra set of hands on the job site.
Jon
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« Reply #25 on: September 09, 2011, 09:26:43 PM »
Looks great and thanks for sharing some pics!  I really like the stain you used.
-Matt
What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.
Offline jander3
    • Peeling Logs
« Reply #26 on: September 27, 2011, 10:05:00 AM »
Started the board and batten siding; framed in some windows.
Jon
Offline fishpharmer
« Reply #27 on: September 27, 2011, 12:27:55 PM »
Jander, great looking shed project. 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline sparky1
« Reply #28 on: September 30, 2011, 08:48:45 PM »
Ive never been involved or apart of anything in this sort of construction (timber frame). It looks like it would be a very rewarding and fun project to tackle sometime!! the pics are great. Out of curiosity, how much does something like that cost to build, or do you have your own mill?
Shaun J
Offline beenthere
« Reply #29 on: September 30, 2011, 09:19:29 PM »
jon
I see where the cross piece under the window looks a lot straighter now. ;)
Bet that wasn't a pleasant surprise.  ::)
Looking great, and wonder if the neighbors have figured it out yet?  :)
Soon you will need the wood stove in there.
Offline jander3
    • Peeling Logs
« Reply #30 on: October 03, 2011, 10:16:16 AM »
Window cross piece?  What do you mean?
Oh, yeah, layout was done on both front posts together.  Checked and double checked.  However, if you cut the girt mortise on the wrong side of the 48" mark, things get a bit un-level.    How do I know this?   Well, when I figured it out on raising day, I was glad there were not children outside playing.
So far, someone has called the dog-gone building inspector on this project two times.  10' x 12' needs no permit.  First time, we pulled a tape on a spot  that was 9' 11 3/4"; inspector was happy.  Next time, he was still happy, but he let me know galvanized roofing was a no-no in town (I should have looked into this before roofing).   So, I will be pulling off the metal and putting on a different roof.   Whoever turned me in may not be so happy, as the new roof will be blue (but legal per code) cause my wife likes blue.
Actually, the inspectors in town are really good guys.  You would think if someone had an issue, they would come talk with me.  Nope, here in MN, folks are civil; they smile at you, and then they call the inspectors to turn you in. However, when I get done, the siding will be painted to match the house and from the outside it won't look like a barn structure. At that point, I think the concern will go away.
When they wrote the code for 10' x 12' without a permit, they were probably thinking a Mendards shed, not a timber frame.
Jon
Offline jander3
    • Peeling Logs
« Reply #31 on: October 03, 2011, 10:24:15 AM »
Cost?
I have my own mill and trees.  However, the mill is at the Stump Ranch, so, it took me some time to cut, mill, and haul.  And, the dimensions had to change a bit in that 14' 6" is about as long as I dared haul in short-bed truck.
Cost is below:
Concrete Pad = $1200 (poured by a local guy)
Windows = $300 (Building Materials Outlet Store)
Roofing  & Rafters = $450
Screws and Such = $100
I think if you purchased the timbers from a local sawyer, you would have 2K into the timbers.
Jon
Offline jander3
    • Peeling Logs
« Reply #32 on: October 30, 2011, 08:49:24 PM »
Replaced the roof with something blue.  Now compliant with the city code.
Working on the siding when I have time.
Jon
Offline Piston
« Reply #33 on: November 02, 2011, 09:19:29 AM »
That looks GREAT!
-Matt
Offline RPF2509
« Reply #34 on: December 16, 2011, 06:30:43 PM »
Would you be willing to post a cut list for this building? - we have a 10' x 12' no permit required as well.  I have 2 - 16'x 36" logs ready to mill come springtime.  Somewhere I have a book by Jack Sobon where he shows how to build a similar structure but since we just moved its in a box - probably at the bottom of the pile
Offline jander3
    • Peeling Logs
« Reply #35 on: December 17, 2011, 04:49:59 PM »
http://peelinglogs.blogspot.com/2011/03/timber-frame-plan10-x-12-shed.html
Here are the plans, there are a couple of things that maybe aren't quite right (i.e. center post is reversed...not on purpose).   The sketchup plan is posted as well.  If you download the sketchup plan and have Timberframe Rubies, you can adjust the model and make your own shop drawings.
The plans show the ridge and the plate at 16', I had to go with 14' because I couldn't get anything longer in the back of my truck.
Jon
Offline RPF2509
« Reply #36 on: December 19, 2011, 06:12:51 PM »
Great!   Thanks Jander3 - I'm figureing my way around sketchup - rubies is next.  Ah for the long winter of planning
Offline mog5858
« Reply #37 on: December 27, 2011, 09:41:10 PM »
NICE JOB you really out did your self. after reading this really wont me to go and start cutting timbers for a little shed too. but i have to put my sawmill together and then lean how to cut timber and timber frame bean reading books but that's about as faw as i got. maby buy this summer i could try somthing like what you got going on i hope.
Offline jander3
    • Peeling Logs
« Reply #38 on: December 28, 2011, 01:54:25 PM »
Installed a door with big hinges as it is one heavy son-of-a-gun.  I just have to finish up the battens and loft planking, then, I will be ready to move things in.
December 27, no snow in Minnesota...different this year.
Jon
Offline Rooster
  • Tools are extensions of ourselves... share a tool.
    • Photobucket image storage account
« Reply #39 on: December 28, 2011, 06:29:54 PM »
Are you planning on decorating the shed for the holidays???
Sorry, I couldn't help myself.
It looks great!
Rooster
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Garden Shed frame raising videos
Started by Jim_Rogers on Timber Framing/Log construction
Last post April 10, 2013, 10:11:16 AM
by Jim_Rogers
timber frame raising
Started by logman on Timber Framing/Log construction
Last post August 03, 2006, 08:09:32 PM
by submarinesailor
Timber Frame Barn Raising in NH
Last post September 19, 2003, 05:51:12 AM
by Jim_Rogers
Timber Frame Raising in Danville, Illinois
Last post August 30, 2003, 08:11:12 AM
by Jeff
