Arborwear
Author Topic: Gearmatic to hydraulic  (Read 6841 times)
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« on: January 26, 2012, 07:04:04 PM »
My old C-5 Tree Farmer has what I think is Gearmatic but it maybe a Can Car winch.  I don't know  ;D  The winch has the usual problems.  Won't free spool,  the brake won't hold either but it will pull.  The hand brake controller is also full of rust and scale but seems to surprisingly work  :o :) but I can't imagine it would for long  :( :)  Rather than putting time and $$$$$ into this thing that's apt to sit for long periods and just rust up again I was thinking about pulling it off and installing a hydraulic winch like a Braden or something similar.  The machine should have enough hydraulic power as it is however a larger pump would be an easy install.  A hydraulic winch, some hose and a valve and it's done.  Right  ??? ??? ???  It would do away the problematic winch; a driveshaft and u-joints; brake lines, fluid and the controller.  If it sat for a period there were be no bands to rust or brake fluid to gather moisture and hopefully the machine when needed in a pinch could be put directly into service without troublesome startup maintenance.
  Line speed would be a concern.  How fast are hydraulic winches  ??? or is it more a matter of GPM  ???  It would be used as a backup machine for the forwarder and to pull logs from hillsides to a place accessible to the forwarder.  Seems like it would be a change for the better  ??? ;D :)  Hydraulic winches show up on E-bay and seem to be fairly reasonable in price when compared to parts for a Gearmatic winch that will only solve the problems for a while especially on a machine that won't see regular use.  Just want to make this thing serviceable and reliable so when I need it I can use it without working on it first  :) ;D
Offline jocco
Re: Gearmatic to hydraulic
« Reply #1 on: January 26, 2012, 07:13:54 PM »
Corley can't answer your hyd questions but i have seen some machines converted to a deere or a clark winch both of which worked much better than the gearmatic. ( The 9 did not seem to give the problems of the 8 and 19) Now a timberjack (eaton herqules winch would solve all your problems) smiley_devilish The only winch that could set for 20 years and still work!!!
You may check out but you will never leave
Offline doghunter
« Reply #2 on: January 26, 2012, 07:22:17 PM »
personally i'd put a 3325 john deere winch on it . it's self contained only needs a pto shaft to drive it, pretty simple to work on, cable controlled. hydraulic driven winches generate a lot of heat and need to be gpm matched to your pump the ones i've seen were way too slow for logging.i have a timberjack with a hercules that has been pretty well bulletproof that mightbe another option if you can come up with the proper control valve. just my personal opinion
Offline pineywoods
« Reply #3 on: January 26, 2012, 07:23:56 PM »
Rather than pure hydraulic winch, I would look for a big ole worm drive pto type winch and couple it to an external hydraulic motor. The things are just about bullet proof. Keep oil in the gear case and they last forever. No brake, no clutch, well usually a positive dog type clutch for free spooling. Line speed is just a matter of how much gpm you can throw at it. Look around for a truck boneyard.. I have one mounted on my kubota tractor. Hydraulic motor, a couple of sprockets and some roller chain. Wish you were closer. I have one in my junk pile parts department that came off a D6 dozer.
Offline madmari
« Reply #4 on: January 26, 2012, 07:33:30 PM »
For the cost of such a beast of a hydraulic winch you could put on a Hercules (Eaton- Timberjack) and be super happy and have enough left over to take your Bride to dinner and dancing ( and probably Cancun). Added benefit is that it will pull anything God put in the ground without complaint. It will completely lift the Tree Farmer off the ground.
  "When the lever goes north, the tree(s) come forth".
  I've had Gearmatics before. If you use it daily, keep it dry and sweet talk it occasionally it will provide likewise service. The Eaton however is like a Beagle. Asks nothing of you and hunts with the heart of a lion.
I know why dogs stick thier head out the car window.
Offline bill m
« Reply #5 on: January 26, 2012, 08:13:52 PM »
Most hydraulic winches are slow. A planetary is faster than a worm gear but still nowhere as fast as the ones on most skidders. In order to freewheel a hydraulic winch with a load on you must stop, let all of the weight off of the cable then disengage the clutch/freewheel. You can get a fast hydraulic winch, they are made mostly for cranes and are expensive.
Offline redlaker1
« Reply #6 on: January 26, 2012, 09:39:25 PM »
surplus center has a pto winch on their site,  its an 8000lb   but not sure how the gear ratio compares to the gearmatic.    or if the brake/clutch mechanism is strong enough for skidding with
Offline oldseabee
« Reply #7 on: January 26, 2012, 10:23:15 PM »
Tiger Cat Skidders use basically a Clark/Allied winch with a hydraulic drive instead of a PTO shaft.
Offline bill m
« Reply #8 on: January 27, 2012, 08:17:26 AM »
Look carefully at any winch you may be considering. Most winches can not release the cable with tension on it. The pto winch from Surplus Center might work on a tractor but would not stand up to the abuse it would get on a skidder.
Offline pineywoods
« Reply #9 on: January 27, 2012, 09:46:57 AM »
Therin lies one of the big advantages of a hydraulic winch. reverse the oil flow and you have built-in power out.. That feature has saved me a lot of angst.
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
« Reply #10 on: January 27, 2012, 09:52:43 AM »
I've worked with Gearmatic many yrs, i would fix that Ole Gearmatic. As long as you keep it covered and take it out once a month to keep everything lose it will be good to you. Its going to be pretty hard to replace it with something equal to its line speed and 40,000 lb. line pull.
Offline doghunter
« Reply #11 on: January 27, 2012, 06:57:03 PM »
if you change out the old gearmatic list it on forestry forum for sale i'm sure someone needs it for parts or to use on a machine that runs every day
ED K and gearmatic hydraulic repair?
Started by jocco on Forestry and Logging
Last post December 20, 2011, 06:26:50 PM
by timbuck2
question
Help Me Identify This Gearmatic Hydraulic Winch
Started by Dangerous_Dan on General Board
Last post January 15, 2007, 10:46:39 PM
by KGNC
Gearmatic winch and hydraulic lift
Started by masonjar on For Sale
Last post October 16, 2017, 06:49:38 PM
by Jwinter7258
LT40 Super hydraulic/LT50/LT70 DC Hydraulic pumps specs question....
Started by Percy on Sawmills and Milling
Last post August 06, 2017, 12:56:15 PM
by JB Griffin
