Arborwear
Author Topic: chainsaws on your tractor  (Read 9454 times)
Offline shinnlinger
« on: February 21, 2012, 09:18:58 PM »
Hi,
How do you folks carry chainsaws on your tractor?  Its nice to have two of course and I can make a scabbard easy enough with p plywood, but where do you hang them that is out of harms way but not obstructing your vision?
Shinnlinger
Offline pineywoods
Re: chainsaws on your tractor
« Reply #1 on: February 21, 2012, 09:51:59 PM »
My Kubota has a built-in chainsaw scabbard. The one on the other side is full of hydraulic hoses..
Offline Okrafarmer
  • Location: upcountry SC-- Sweetgum capital of the world!
  • Avast! Here appeareth some sweetgummery about....
« Reply #2 on: February 21, 2012, 10:15:31 PM »
Every model of tractor is different. You have to be creative.  :-\  We always just used one and carried it on the floor of the JD B. Some tractors don't have floors.
No matter how conventional wisdom may fly in the face of radical thought, it's still the most popular type.
Turbosawmill 8" cut GX390 Warrior Sawmill, 13hp Honda
MS290 Stihl
Genesis Hardwood Lumber
Offline beenthere
« Reply #3 on: February 21, 2012, 11:55:42 PM »
Bolted a plywood scabbard on the ROPS.
Offline thecfarm
« Reply #4 on: February 22, 2012, 09:21:16 AM »
I copied what billm did,he's his picture,
I had another tractor and I had a box behind the seat that worked good. was not enough room to do it on this one. All tractors are differant,have to give it some thought on what will work and what won't. Remember too you will be getting on and off the tractor alot and reaching for the saw too. You want it in a good spot easy to get to.
Offline shinnlinger
« Reply #5 on: February 27, 2012, 08:49:00 PM »
Ok,
Here is what I came up with.  Thanks for the ideas!
Shinnlinger
Offline WildDog
« Reply #6 on: February 28, 2012, 02:47:26 AM »
I like these ideas of plywood scabads, I have just got my old Husky 61  going again, it would do it some good to be out in the weather.....Shinnlinger, looks like you've got everything but the kitchen sink behind your tractor :)
If you start feeling "Blue" ...breath    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #7 on: February 28, 2012, 06:21:21 AM »
  this works for me :D
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #8 on: February 28, 2012, 08:55:59 AM »
Peter, I have a similar setup on my Farmi, but made a plywood scabbard to fit in the bracket so the chain doesn't ride on steel.
Had to use pretty  thin plywood, but only on my second one since 1994
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline g_man
« Reply #9 on: February 28, 2012, 05:40:02 PM »
Two saws behind the seat on a plywood shelf across the fenders
    • A&P Saw mill LLC
« Reply #10 on: February 28, 2012, 08:29:20 PM »
Ya petefrombearswamp   I know I have to get my lazy but in gear :D :D
Sawing since 1987
Offline John Mc
« Reply #11 on: February 28, 2012, 09:32:48 PM »
I like these ideas of plywood scabards
In a pinch, I've bore cut a 2 x 6 down the length of it to make a scabbard. It worked pretty well, but doesn't hold up as long as one made from plywood. Once the 2x6 is bore cut, it doesn't take whole lot of abuse to split it.
Offline MrPete
« Reply #12 on: February 28, 2012, 09:36:31 PM »
This my first post and I can't figure out how to post pics yet. :-[ But if you can see in my profile pic I mounted a Cherry log to my ROPS.  It holds 2 saws, 3 wedges and an axe with plenty of room for more.
Offline Okrafarmer
« Reply #13 on: February 28, 2012, 10:03:11 PM »
Welcome, Mr. Pete! I grew up in Clinton Maine.
MS290 Stihl
Offline MrPete
« Reply #14 on: February 28, 2012, 10:06:47 PM »
I've been lurking on here for a couple months okrafarmer.  It is definitely a small world.  I remember that truck you bought being around years back, seems I live next to the Prentiss Carlisle wood yard.  That pretty much tells you where I live! lol
Offline Okrafarmer
« Reply #15 on: February 28, 2012, 10:18:58 PM »
Ha! Except I can't remember where that is, lol. I remember a wood lot on the Benton Neck Road, Benton, and the Albion Log Yard. Pulp went to Scott Paper in Hinckley, birch went to Pride in Burnham, white pine went to Hancock, in Pittsfield. A few other little sawmills I remember-- Johnson's in Caanan, a cedar mill in Pittsfield, and Tukey's in Oakland. There was always logging being done, everywhere you looked.
I lived between Johnson's Sawmill, and Pride Manufacturing, if that tells you anything.  :)
MS290 Stihl
Offline MrPete
« Reply #16 on: February 29, 2012, 05:05:51 AM »
  Thanks to Furby, I am able to post my picture now.  I am really happy with this mod. It doesn't show up real well but it is a cherry log attached to to ROPS.  You can ee the saws on either side of my nephew's head.
Offline Woodhog
« Reply #17 on: February 29, 2012, 09:21:55 AM »
It helps to have wide fenders.... I put one on each side...
I would never go in the woods with less than 2 saws..
Offline Okrafarmer
« Reply #18 on: February 29, 2012, 11:02:55 PM »
Ideally, yes. Sometimes I'm so desperate I go with just one saw because it's the only one that works!
MS290 Stihl
Offline Randy88
« Reply #19 on: March 03, 2012, 06:43:35 PM »
On the loader tractor we carry the stuff in the bucket, on other tractors we carry the saws in the rock boxes we have on the front of the tractors, I like the scabbards you people have on the tractors, those are nice ideas and attachments to any machine.
moved
MOVED: New chainsaws compared to old chainsaws
Started by Kevin on Forestry and Logging
Last post March 02, 2011, 09:20:25 AM
by Kevin
Started by blkhillsvt on Chainsaws
Last post March 15, 2011, 07:20:02 PM
by 1270d
40-50 cc chainsaws ?????
Started by sandsawmill14 on Chainsaws
Last post April 04, 2015, 08:15:29 PM
by lumberjack48
Chainsaws
Started by Iron65 on Chainsaws
Last post January 28, 2014, 02:33:54 PM
by DonT
