Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: stihl ms290 oil pump works great, but oil doesn't get to the chain  (Read 24058 times)
Offline stephen.rizzo
I've read a thread similar to this problem, but I think mine is unique.  With no bar and chain on, oil flows freely from the port.  The hole in the bar is unobstructed.  The saw is very clean.  With the bar and chain on, oil does not reach the chain, the chain and bar get so hot you can't touch it.  The chain is not too tight.
Is there supposed to be a gasket or seal between the saw and the bar that would force the oil to go through the hole in the bar to the chain instead of pooling under the cover?  It doesn't matter if the bar is in regular or upsidedown.  All I get is pooling.
I am positive that the oil pump is working as I have it turned up all the way and I can see it flowing freely from the port.  Any ideas???  Thanks in advance, Steve
Online pineywoods
Re: stihl ms290 oil pump works great, but oil doesn't get to the chain
« Reply #1 on: August 24, 2012, 08:59:22 PM »
Wrong bar, holes don't match ?
100k bd ft club
Offline Clam77
« Reply #2 on: August 24, 2012, 11:10:45 PM »
Sounds like it to me..  what kind of saw and what brand of bar is on it??
Andy
Stihl 009, 028, 038, 041, MS362
Mac 1-40, 3-25
Offline tyb525
  • Always learning.
« Reply #3 on: August 25, 2012, 12:00:03 AM »
Is the oil hole clean? mine seems to get blocked up all the time and will prevent oil flow
« Reply #4 on: August 25, 2012, 05:39:23 AM »
The holes match perfectly.  the hole is clean.  I've even taken a compressor and blown air through it to make sure.  When the bar is off of the saw, and I place the chain in the groove of the bar, I can see very clearly through the hole that the bottom tab of the chain that would pick up the oil if available passes by the hole idicating that the hole is indeed open.  It is a Stihl ms290 saw with the original stihl bar.  I've used the saw without a problem for about 5 years.  This problem started happening a few uses ago and I'm smoking blades left and right.
Offline Clam77
« Reply #5 on: August 25, 2012, 03:49:40 PM »
When the saw is running WITHOUT the bar on - is the oil flowing out as in running out.. or is it squirting out getting oil all over everything??
Starting to sound like your oil pump isn't pumping with full pressure to get it onto the bar.
With the bar off, try placing your finger over the outlet hole while it's running - see if you can hold the oil in.  If you can, your pump may be getting weak or there may be something broken inside it.
Andy
Mac 1-40, 3-25
Offline clww
  • Oh yeah? Watch this!
« Reply #6 on: August 25, 2012, 04:46:17 PM »
That sounds like an oil pump to me, too. If the bar/chain are installed, with the saw running if the pump is operating, oil should flow. A way to see is hold the bar tip a few inches away from any flat surface. Run the saw as normal and observe if any oil is leaving the tip and collecting on the surface when the chain is spinning. If not, with all the holes cleaned and unobstructed, I would think it's a bad pump or gear.
Many Stihl Saws-16"-60" Husky 372XP
18-Wheeler Driver for Millis Transfer
Offline Al_Smith
« Reply #7 on: August 25, 2012, 05:20:09 PM »
The 029-039 uses a little wire contraption that aligns with a notch in the clutch drum to rotate the pump gear .Now if for whatever reason that thing jumps out of that notch it doesn't pump so good .In addition also the worm gear which is made of plastic sometimes looses part of it's teeth .It might even be the screw portion of the pump that holds the wire could be stripped .
Easy enough to check out ,just pull the clutch drum and there it all is .To get to the actual pump you have to spin off the clutch but you should be able to eye ball it without removal .That's not a big deal either,block the piston and screw it off ,left hand threads .
Offline kenskip1
  • Stihl Looking for the fountain of middle age.
« Reply #8 on: August 26, 2012, 12:50:00 AM »
If the chain is two loose the drivers will literally fly past the oil being pumped.Figure this out.When you accelerate, the clutch pulls the chain tight on the bottom of the bar. Now if the chain is loose the chain coming off the clutch sprocket will literally overpass the oil. The oil has to go someplace so now it drips out of the bottom of the saw.Wrong  gauge chain may also be a contributing factor, Ken
Stihl The One
Stihl Going Strong
Stihl Looking For The Fountain of Middle Age
Offline js2743
« Reply #9 on: August 26, 2012, 01:14:24 AM »
Is the grove in your bar clean?
 It may look clean but could be too full for the chain to get the oil, if you dont have a grove cleaning tool use something thin enough to pull through the grove both sides of the bar.
« Reply #10 on: August 26, 2012, 07:57:21 AM »
Thanks again for the posts.  THe chain is not too loose.  The groves on the bar are squeaky clean.  I blow it out with a compressor when I clean it.  The oil FLOWS out when the bar and chain are not installed and the engine is running.  It does not SQUIRT.  I will try to occlude the hole and see if I can contain the oil.  THis sounds like the most plausable problem.  THanks again for the suggestions.
Offline joe_indi
  • The older I get the more I learn
« Reply #11 on: August 30, 2012, 02:15:15 AM »
Steve, you said oil gets pumped out of the outlet without the bar but itdoes not come onto the chain , and it pools. By pooling if you mean than oil is flowing down the rear of the bar, here are a few possibilities:
# The groove on your bar is worn out to a point that the oil escapes along the side of the drive links.The result is oil is not pushed forward.
# Similarly, the same thing could also happen if your saw chain's drive links are worn too much.
(These two causes will cause excess lateral movement of the chain when it is fitted on the bar.)
# The bar mount area on the power head or mating area of the guide bar are uneven.
(Use some thick but soft paper to make a gasket to get a proper seat)
# If yours is a Stihl guide bar, just inside the groove, next to the hole for the oil to come in, there is a sort of well, which is a separate clip like piece.If by chance, during cleaning you happen to loose this piece the oil wont flow forward.Check if its still in place by moving a small screwdriver or such through the groove. When you reach the oil hole, the screwdriver should take a slight dip when it moves into the well.If it does not do that, you are missing that well. But there is a well on the other side of the guidebar as well. Check if at least you have that one. If not you need to replace the bar.
Joe
Offline beenthere
« Reply #12 on: August 30, 2012, 10:11:41 AM »
Joe
You sure do offer good advice on our Stihl saws. And with good clarity on the explanation too.
Nice to have your input and expertise on the Forestry Forum.
Offline joe_indi
« Reply #13 on: August 30, 2012, 11:40:45 AM »
Joe
Thank you .
I would be only be too glad to know that my suggestions were useful here.
Joe
Offline fuzzybear
« Reply #14 on: August 30, 2012, 09:56:47 PM »
Joe
Make that X2
FB
I never met a tree I didn't like!!
Offline frankab
  • Member*
« Reply #15 on: October 11, 2012, 01:03:50 PM »
Steve
Did you ever fix your saw? If so, what was the problem? My 290 is having the same problem as yours. The bar is so hot a drop of water will boil after just a few cuts. I put in a new oiler, cleaned lines, filter, groves, new chain, turned oiler on high, but it still gets hot!! I emailed Stihl and that was a waste of time.
Offline SasquatchMan
  • Get it done.
« Reply #16 on: October 14, 2012, 10:49:37 PM »
The 290 won't spew oil - if the oiler is working, if you fire the saw up and hold it over a piece of cardboard and tweak the throttle a couple times, you'll see a fine line of oil hitting the cardboard near the tip of the bar, but that's all the E-matic system puts out.
If you got that much oil, the oiler's working and the issue is something else.
Nose sprocket need cleaning, something bent on the chain or in the bar?   Some extra friction somewhere.... dull chain?
Senior Member?  That's funny.
Offline thechknhwk
    • Story of the Trees
« Reply #17 on: November 02, 2012, 02:52:31 PM »
Stephen,
Did you ever figure this out??  I recently developed the same problem with an MS250.  I take the B/C off and I can see oil peridically spurting out of the oiler, but I'm not using hardly any oil.  When I put the B/C back on I'm not getting any oil off the tip of the B/C.  I have cleaned the bar groove, oil port on the bar, and the oiler port on the saw with compressed air.
Offline thechknhwk
« Reply #18 on: February 16, 2013, 05:15:15 PM »
Diggin' up bones here, but thought I would give my 2 cents.  I just tore 2 MS250's down to the crank case and swapped motors and all associated parts into new crankcases (clamshells).  I traced the oiling problem back to the clamshell being melted out by the oiler gear.  There must be some channel in there that was damaged causing the oil to fall out the bottom of the saw and not reach the chain.  While looking for crank cases I talked to a local stihl mechanic that stated this was caused by turning up the idle and then leaving the chain brake on.  After running my other 250 that had a tree dropped on it, but was like new and this one after rebuilding both the original one pictured below has quite a high idle.  Anyways here is a pic.
Offline 60DRB
  • Member*
« Reply #19 on: June 23, 2013, 12:39:49 PM »
I felt like a retard, but my last oiling issue on my 039 was resolved by simply clearing the oil vent with some compressed air.
Smarter guys (here) than me aimed me there.
Still MS290 chain oil pump problem
Started by Gord From Emsdale ON on Chainsaws
Last post June 20, 2005, 09:14:39 PM
Best 20' bar & chain set-up for Stihl MS290
Started by ReggieT on Chainsaws
Last post November 10, 2013, 09:32:24 PM
by IndianSprings
Stihl 029 chain oil pump replacement
Started by Barneyhunts on Chainsaws
Last post June 17, 2015, 04:24:53 PM
by Barneyhunts
Retail Firewood Sales what works and what doesnt
Started by woodshax on Outdoor Vending Solutions
Last post Yesterday at 05:24:11 PM
by starmac
