Arborwear
Author Topic: 618 Tooth question  (Read 1387 times)
Offline Gasawyer
618 Tooth question
« on: December 05, 2012, 08:40:19 PM »
I have had my 618 for 3 years now and have had to retip several of my blades.  I have had a random problem that  one or two teeth chip when going through knots in large red and white oak. I try to slow down when I come to the knots and not force the blade trough them. Sometime its just a corner sometimes the the whole tip of the tooth is gone. The tips are supposed to be from Bailey's the guy I bought my mill from had about 30 tips in a baggy. Are there different grades of tips for different purposes? Thanks for any help! Tod
Woodmizer LT-40hdd super hyd.,Lucas 618,Lucas 823dsm,Alaskian chainsaw mill 6',many chainsaws large and small,NH L555 skidsteer, Int. TD-9,JD500 backhoe, and International grapple truck.
Offline fishpharmer
Re: 618 Tooth question
« Reply #1 on: December 05, 2012, 09:40:11 PM »
Never chipped a tooth in big red or white oak, that is mainly what I cut with my 618.  Mill some Pecan, even that has not chipped a tooth.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Online Ianab
« Reply #2 on: December 05, 2012, 09:56:02 PM »
There are different grades of carbide. Harder types keep an edge longer, but are more brittle, and likely to shatter under rough use, like hitting a hard knot. So it's a trade off. The harder ones like that last longer in easy to cut wood. "Softer" (soft is a relative term for any carbide) will dull sooner, but is less likely to shatter.
May be that you the more brittle ones?
A saw doc that specialises in carbide tip blades can probably help you out with the different grades.
Offline fishpharmer
« Reply #3 on: December 05, 2012, 11:24:15 PM »
I wonder if a tooth or two was slightly out of whack from the others if it would be more likely to chip or break?
Guess that may cause some blade vibration from being out of balance.  Not sure if its feasible, saw shop retips my blades.
Offline DJ MILLMEN
    • LCS
« Reply #4 on: October 25, 2013, 04:04:27 PM »
the tips we provide are grade C2.
Insert tooth / carbide question
Started by DMcCoy on Sawmills and Milling
Last post December 05, 2015, 07:39:26 AM
by DMcCoy
Blade sharpener and tooth setter question.
Started by gator gar on Sawmills and Milling
Last post August 12, 2010, 09:11:43 AM
by paul case
7 tooth or 8 8 tooth sprocket
Started by postville on Chainsaws
Last post April 20, 2011, 08:04:47 AM
by postville
saw tooth
Started by coxy on Sawmills and Milling
Last post October 02, 2016, 04:15:45 PM
by Gearbox
