Arborwear
Author Topic: Lug nut resque  (Read 1418 times)
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Lug nut resque
« on: June 22, 2013, 06:19:01 AM »
Yesterday my mechanic showed up to work on one of the trailers that I gave him in a swap for working on my stuff.
It was an old ski-mobile trailer that my father had built for his skido back in 1972. The plate on it had a 1983 sticker on it. So that was the last time it was on the road.
The tires were flat, of course, but I have given him two spare rims that I had. He got two new tires and put them on the spare rims.
Well, those lug nuts haven't been off that trailer probably since 1972, as I don't ever remember us getting a flat on the trailer.
Of course they were very rusty.
I suggested he put some "oil" on them before we tried to get them off. He searched his mechanic's truck for a can of spray oil and couldn't fine one of the five he said he had.
I said: "I've got some blue creeper!"
He asked: "what's that?" "It sounds like something you'd go to see the doctor about  :o "
I got out my bottle and put some on the end threads of all lugs on both sides of the trailer, while he was getting out some tools to take the flat tires and rims off the trailer.
He put a large four way lug wrench on the first nut and "wow" it spun loose.
Then the next, and the next, on and on till all were off. Once side then the other.
We didn't even have to get out the torch to heat them up.
Afterwards we put "blue creeper" on the threads of the lugs and he put the spare rims with new tires on and tightened down all the lugs.
Blue creeper did it's job. Thank you blue creeper.
Jim Rogers
Offline Tamiam
  • Board Moderator
  • Gender: Female
    • Logrite
Re: Lug nut resque
« Reply #1 on: June 22, 2013, 09:15:29 AM »
great news!
glad bluecreeper was there to help.
Offline beenthere
Re: Lug nut resque
« Reply #2 on: June 22, 2013, 10:29:51 AM »
It is what I have come to expect from the Blue Creeper.  8)
Removed the front cast iron door from my wood boiler this week, and had to remove the 1/4" machine screws that have been there for 30 years. Treated each of the 16 or so threads with the Creeper and easily turned them off. One was near completely burned off so couldn't get the socket on it.... used the steel chisel for that one.
Offline tyb525
  • Always learning.
Re: Lug nut resque
« Reply #3 on: June 22, 2013, 12:23:56 PM »
I have yet to try Blue Creeper, but I've still got a little bit of Rust Reaper left.
Offline beenthere
Re: Lug nut resque
« Reply #4 on: June 22, 2013, 01:52:12 PM »
tyb
All the same stuff, as I understand.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
Re: Lug nut resque
« Reply #5 on: June 22, 2013, 02:23:23 PM »
Identical other than the color and the name.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Lug nut resque
« Reply #6 on: June 22, 2013, 08:28:19 PM »
When Jake and I tried to remove the side panels on the edger that I am babysitting for him, we could not get the bolts to budge.  We left the panels alone, but yesterday, a drive belt came off as it was too loose and worn out, and there was no way to replace the belts without removing the side panels.  Could not get any of the bolts to turn.  I sprayed the bolts liberally with blue creeper and called Jake to discuss a plan.  We settled on the "cold chisel" destructive method.  Tapped the first one counterclockwise a couple of times and it came loose.  Then found that all the others could be turned and removed as the blue creeper had done the job.  Very good stuff.
Offline WmFritz
Re: Lug nut resque
« Reply #7 on: June 23, 2013, 12:36:07 AM »
Thanks for that story Jim, it reminded me I've been wanting to order some. I need to break some brake lines and bleeders loose on a 12 year old  pickup  that has spent its whole life primarily in Michigan's winters. Its not pretty under there. :o
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Offline Tamiam
  • Board Moderator
  • Gender: Female
    • Logrite
Re: Lug nut resque
« Reply #8 on: July 02, 2013, 08:33:17 AM »
sounds like a job for Bluecreeeper!
