Recent
Welcome to The 2025 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
Got a FB Messenger contact from a potential customer. She wanted me to saw 2x6' from cedar logs - 10 logs up to 20' long, 7" to 20" in diameter.
She asked could I do the job in an hour? When I explained 10 cedar logs wouldn't be enough for a half day, my minimum charge, she wanted to negotiate my rates. "Over budget" could I saw for less since she had to buy the logs. "Can't afford..." "Your rate is too high!" "I'll be a good customer." "Can get you more business." "I have to provide a helper?!?" Blah, blah, blah...Read More
26 Comments
I had sawn some birch last fall and ran it through my small kiln. Finally got around to a garage day to begin a little project yesterday. I'm not much of a carpenter, especially the finer points. It did not go quite as planned, but it should hold dust anyway. Nice to take the log full circle and turn...
Read More
2 Comments
I have a Norwood mill with a B&S vanguard 23. The oil filter sits almost on the deck. I was able to barely get a oil filter wrench on it. Will not budge. Afraid I was going to tear the fitting off the side of the motor, filter itself starting to collapse in. I think if I tried the screwdriver through the filter trick it might just tear through the filter. Hard to get purchase on the thing also. Any thoughts? Read More
26 Comments
I've had some failures while attempting to clamp and hold odd shaped (crescent, quarter-round) wood , in off-from-square positions on a LT40 so as to make the cuts to produce quarter-sawn lumber .
The problem is that the combination of:
- the geometry of the wood shape,
- the position/orientation of the wood held for quarter-sawing , Read More
18 Comments
Does anyone here have or use a Davis saw filer? This pic is out of the R.R. Howell catalog.
2 Comments
Pages: [1] 2 ... 40
