Arborwear
Author Topic: Oregon Chain Grinder vs. Stihl chain angles  (Read 4035 times)
Offline Chelsea Tree
« on: July 07, 2013, 09:24:01 PM »
Hi folks,
Question about Stihl chain angles.
I have an Oregon 511A Bench Grinder and I run Oregon chain which is great, however I am trying to grind Stihl PMC3 chain for a buddy and I can't seem to translate the charts.
I have three variable angles on the grinder.  The grind angle ajustable on the back, the top plate angle and the vice-tilt angle.
The grind angle runs from 90 degrees thru to 40 degrees.
The top plate angle runs from -40 degrees thru 0 to + 40 degrees
The vice tilt isn't marked but it seem to run from - 10 thru 0 to +10
All of this is fine for Oregon but there seem to be more numbers for Stihl.
According to the Stilhl USG Chart, PMC3 has an "A" angle of 40, a "B" angle of 15, a "C" angle of 30 and, from what I can interpret, a grind angle of 75...
I am guessing C is the top plate angle but I don't get A or B.
Anyone?   Anyone?   :)  (head spinning... seriously)
Cheers,
JP
Offline joe_indi
  • The older I get the more I learn
Re: Oregon Chain Grinder vs. Stihl chain angles
« Reply #1 on: July 07, 2013, 11:28:57 PM »
JP
I dont use a Stihl USG grinder, but maybe this link would help:
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/USG_Manual.pdf
Joe
Offline bandmiller2
« Reply #2 on: July 08, 2013, 07:58:36 AM »
Chelsea,thats the germans they have specs and dimentions for puppy poo.Put the chain on your sharpener and sharpen it as your own.If your buddy complains it doesn't cut then change the angles. Frank C.
Grinder Head Angles on a TECOMEC chain saw grinder--Same grinder as Oregon 511
Started by hydro2 on Chainsaws
Last post November 29, 2005, 01:15:23 PM
by rickk
Oregon 511 chain grinder
Started by DonT on Chainsaws
Last post October 29, 2009, 09:04:48 PM
by DGK
oregon chain grinder
Started by poorfarm on For Sale
Last post October 26, 2012, 08:00:24 AM
by poorfarm
New Oregon Chain Grinder
Started by deastman on Forestry and Logging
Last post September 23, 2015, 07:57:38 AM
by Corley5
