Arborwear
Author Topic: Plumb-bobs, plumbettes, etc.  (Read 1048 times)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« on: July 18, 2013, 06:48:40 PM »
What do you use? I made up a simple "plumbette" for scribing in some new parts on one of the barns. I couldn't find a "real" plumbette, and since I'm not laying out to lines on the floor, I just made one out of basically garbage. :D Since I don't have to see through the plumbette to a chalkline, I just used a big discarded nut. I think it's a 1" fine thread.  ;D Then I got a scrap of pine and cut a prow on the front of it like a very square-ish ship might have, and put a slot in it for the string line. I then pounded a sheetrock screw into the top of it, as I didn't have a phillips bit,  ::) and tied a couple of feet of old chalkline on the screw. It needed a little weight on it, so I glued a marble scrap to the top. Presto! I had a plumb line scribing gizmo. ;D
The main angle is 90, and the bottom relief angles are probably 15. This keeps all the wood away from the line so you can do your picage, or pricking of the dimension. What I'm doing is sort of French scribe. Sort of.
Goat ka-bobs
Started by tule peak timber on FOOD! FOOD! FOOD!
Last post August 14, 2016, 11:03:53 AM
by POSTON WIDEHEAD
Plumb Wore Out!!!!!!!!
Started by dail_h on General Board
Last post January 08, 2010, 10:10:50 PM
by WH_Conley
i know its crude but how to cut plumb with chain saw
Started by northcalj on Chainsaws
Last post June 30, 2009, 09:21:27 AM
by Stephen1
Rehab'ed Plumb Hatchet
Started by JB Griffin on General Board
Last post November 25, 2015, 03:45:01 PM
by Dave Shepard
