Arborwear
Author Topic: 100 grade 5/16" choker chain...  (Read 3844 times)
Offline HiTech
« on: July 20, 2013, 02:09:14 PM »
Was just wondering if anyone uses these. I used 5/16" 70 grade and they seem to break fairly easy. I found some 5/16" 100 grade at the Woodsman Field Days in Boonville and bought a few to try. I love them. Light, easy to carry and very strong...have yet to break one. I went last year to get more and asked the dealer where I bought them the previous year if they had any more and they looked at me like I was crazy. I wanted to replace my heavy 3/8" chokers with them. I will look again this year but have my doubts if I will find any. I may have to go online and buy a barrel or a 1/2 barrel of chain and make my own. Might not be heavy enough for the Big Skidders but for me they work great. Most trees I pull are 24" and under. Sometimes I have to use one choker and two sliders to get them hooked up and pulled out. lol My buddy laughs at me when this happens.
Offline jdonovan
Re: 100 grade 5/16" choker chain...
« Reply #1 on: July 20, 2013, 04:13:35 PM »
the WLL between 5/16 is 4700 vs 5700. Its surprising you break 70's frequently, but have 100's hold up when there is only about 20% more strength on the g100.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #2 on: July 20, 2013, 04:37:44 PM »
Check with a construction supply house for crane chokers  :)
Offline thecfarm
« Reply #3 on: July 20, 2013, 08:48:52 PM »
This is from an old Labonville catalog,2011,Pewag G-100 3/8  ROUND-LINK CHAIN. Part # G100R. They also carry overhead chains too. 5/16 through 5/8
Offline HiTech
« Reply #4 on: July 21, 2013, 06:18:57 AM »
If you ever used the two you would see the difference.
Offline wildbill
  • looking around
« Reply #5 on: July 21, 2013, 09:42:00 AM »
We have a company down here called "certified sling".  they are great for lifting equipment.  find a rigging retailer in your area and they will get you anything you want.  (if they are half as good as certified sling)
Raider Bill's favorite son
Offline jdonovan
« Reply #6 on: July 21, 2013, 11:42:31 AM »
I have, and I do, but what I was saying was the real rated strengths are not that different.
I source most of my chain from AWdirect. They are near by so shipping isn't too bad on heavy things.
Offline HiTech
« Reply #7 on: July 22, 2013, 06:06:13 AM »
You are right, for strength rating so close you wouldn't think there would that much difference in them. It's like night and day. I will look one more time at the Woodsman Field Days and see if they have them again. If not I will buy some chain on line and make my own chokers.
Offline jdonovan
« Reply #8 on: July 22, 2013, 08:53:32 AM »
So I was thinking about this... horizontal use pulling devices are rated with a 4:1 safety factor. so..
        WLL  Max strength
G70   4.7   18.8
G100  5.7   22.8
so the WLL is only 1k different, but the ultimate strength is 4k different.  That strength is in a straight line pull. Once you start doing off-angle things the strength drops substantially. For example a 30-degree angle pull can reduce strength by almost 50%.
You are probably still exceeding the safe working load limits of even G100, and should consider upgrading the chain you are using to something with a higher rating than even the 5/16 G100.
Offline beenthere
« Reply #9 on: July 22, 2013, 10:32:33 AM »
hitech
Hope you find the chain you are looking for.
Apparently the G100 5/16 works good for you and you like the 5/16 for size. Can't blame you for going after what works for you and what you like to drag around.  :)
Now just don't get a bigger skidder. ;)
Offline mnmdad
« Reply #10 on: July 22, 2013, 03:27:33 PM »
Check with CJ logging in Boonville 315-942-5431 talk to al in  parts
Offline mnmdad
« Reply #11 on: July 22, 2013, 03:30:06 PM »
Also try kahlers in rome 315-336-3825
Offline HiTech
« Reply #12 on: July 23, 2013, 05:31:02 AM »
hitech
For Big trees or a real hard pull I carry a couple 3/8" chokers, but for the firewood trees or smaller logs you can't beat the 5/16" 100 grade. My buddy has a bigger skidder and runs 3/4" swedged cable and he hasn't broke any yet and he tortures them. lol They are so much easier to carry while pulling the cable, especially if you have to pull it any distance. lol
Offline HiTech
« Reply #13 on: July 23, 2013, 05:33:41 AM »
I know Al real well. Very nice gentleman to do business with. I asked him once and he didn't know if he could get them or not. I am thinking I got the ones i got from Comstock at the Field Days.
Offline HiTech
« Reply #14 on: July 23, 2013, 05:36:04 AM »
I asked them last summer at the Field Days if they had them or could get them and they looked at me like I was crazy. Tried to give me a deal on grade 70.
Offline ga jones
« Reply #15 on: August 11, 2013, 08:03:46 PM »
AW direct has it.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
Offline HiTech
« Reply #16 on: August 12, 2013, 07:54:07 AM »
Offline bill m
« Reply #17 on: August 14, 2013, 07:52:41 AM »
At AW Direct it is about $5.45 a foot. At Tulsa Chain.com it is $3.65 a foot.
Offline HiTech
« Reply #18 on: August 14, 2013, 08:15:17 AM »
Thanks bill m. Seems to be more places than I originally thought to look.
Offline ga jones
« Reply #19 on: August 16, 2013, 10:51:48 AM »
I'm here at boonville comstock logging has them
Choker chain parts
Started by Hawkshoe on Forestry and Logging
Last post June 04, 2009, 05:43:13 PM
by Hawkshoe
How to fix broken choker chain ?
Started by Madman_Mark on General Board
Last post March 06, 2005, 09:32:43 PM
by maple flats
Help clarifying NHA grade book rules on QS oak and "select" catagory
Started by Kelvin on Sawmills and Milling
Last post August 19, 2007, 02:08:36 PM
by Kelvin
How do you "grade lumber"?
Started by yieldmap on Sawmills and Milling
Last post July 17, 2004, 04:12:29 AM
by Ron Wenrich
