Arborwear
Author Topic: Better carb for Lucas Kohler?  (Read 1135 times)
Offline Seaman
  • Still learning as hard as I can go.
    • Uniquewoodcuts.com
« on: October 23, 2013, 08:00:16 PM »
I have a lot of problems with the carb on my Kohler 27 V-Twin. It is 10 or 12 yrs old .
It runs rich, won't idle, and floods at inopportune times. I thought I read on here about replacing the Cali approved carb but can not find it  .
Any help?
Thanks, Frank
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Offline hamish
Re: Better carb for Lucas Kohler?
« Reply #1 on: October 23, 2013, 08:51:43 PM »
Whens the last time the carb was serviced/rebuilt?
Norwood ML26, Jonsered 2152, Husqvarna 353, 346,555,372,576
Offline logboy
« Reply #2 on: October 23, 2013, 11:23:28 PM »
Ive had issues with mine a couple times on my 827 over the years. Take the carb apart, clean the jets, change ALL the fuel lines, and replace the filter. You might as well completely drain the fuel tank and clean it out while you're at it, since 10 years of sawing has undoubtedly left some gunk in there. Do that and you shouldn't have any issues.  Mine has only done what you described when it was dirty. Thats a good carb, it shouldn't need replacing.
The carb on the 16 HP B&S on my slabber was another story. That was a miserably poor California carb that was always refusing to idle because it was starved for fuel. Since I replaced it I've had a lot fewer problems. And it doesnt use any more fuel despite a lot more time idling.
I like Lucas Mills and big wood.  www.logboy.com
Offline Seaman
« Reply #3 on: October 24, 2013, 06:10:18 AM »
Thanks Logboy, yours must be the post I remember about the Cali carb. Got a travel job today, if we make it thru that I will clean everything this weekend.
Frank
Woodmizer LT40HD
Semper Fi
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: October 24, 2013, 07:19:52 AM »
After you have serviced and cleaned it up, you might consider non-ethanol gas if it is available to you.  Just a thought.
That is all that I ever run in my lawn mower, chain saws, generators, and other small engines.
Offline sigidi
« Reply #5 on: October 24, 2013, 08:12:33 AM »
Frank - get EFI  :o  ;)
Offline Seaman
« Reply #6 on: October 27, 2013, 09:03:41 PM »
I hear you Sidigi!!
Woodmizer LT40HD
Semper Fi
Offline Seaman
« Reply #7 on: October 31, 2013, 10:09:09 AM »
Thank you LOGBOY !
I disassembled the carb and found one of the brass tubes filled with gunk. The tubes with all the cross drilled holes. Cleaned and cleaned, she purrs now and even IDLES !
Frank
Woodmizer LT40HD
Semper Fi
Offline sigidi
« Reply #8 on: October 31, 2013, 04:55:15 PM »
Attaboy Frank!!!! good onya, now you are getting into it  ;D
Offline Seaman
« Reply #9 on: November 01, 2013, 07:56:38 AM »
Yep, and got the new bar from LCS yesterday. Going to try it today, hope it helps solve the climb. I will keep you posted.
Frank
Woodmizer LT40HD
Semper Fi
Offline logboy
« Reply #10 on: November 01, 2013, 11:12:21 PM »
You're having other issues?
Offline Seaman
« Reply #11 on: November 04, 2013, 06:44:09 AM »
Logboy,I'll try it today and see if I still have climb. Loafed the whole weekend camping with friends.
Woodmizer LT40HD
Semper Fi
Offline tjhammer
« Reply #12 on: November 04, 2013, 08:26:52 AM »
  Frank I can't buy no-ethanol gas here anymore I use lucas safeguard at the wall-mart  16oz makes 80gal 1oz to 5gals the ethanol is hard on carb gaskets and causes the gunk.
 tj
hammer
Offline logboy
« Reply #13 on: November 05, 2013, 12:18:25 AM »
It is important for everyone to know about the harmful effects of ethanol as it is applicable to all small engines. This of course includes all makes and models of mills running gas engines. If you can help it, you do not want to run ethanol through a small engine, especially one that has plastic components (fuel tank).  Ethanol is corrosive and will actually degrade the plastic inside of the tank, gradually gumming up the works. Even though the fuel you're getting from the gas station might say ethanol free, because it is all shipped in the same trucks, lines, and pumps, there is always a bit of cross contamination.  I once spoke with a chemist who told me that they tested all of their local gas pumps labeled ethanol free and found that all of them had at least 2% ethanol, versus the 10% at the ethanol pumps. So even if you are buying ethanol free gas, it isn't.  Either way you're going to end up needing some sort of additive.  There are a lot of different products out there claiming to fix the problem, and they range widely in price.  One of the best ones I have found is called Star Tron Enzyme Fuel Treatment. It comes in a blue bottle, costs only a few dollars, and treats up to 48 gallons of gas. Since I started putting it in every tank I have not had any more issues with gumming up. Sawdust can be an issue if I don't stay on top of my fuel filters, but that's another subject entirely.
Offline logboy
« Reply #14 on: November 05, 2013, 12:53:42 AM »
If it is climbing on your slabber, it could be a number of issues.  What are you cutting, how wide is it, what is angle on your teeth (10-15), and how did you sharpen the chain? I have found 90% of my climbing issues could be fixed by a good sharpening.
Offline Tee
  • All the years I just burned the things.
« Reply #15 on: November 05, 2013, 03:11:12 PM »
Hey Frank,
      It was good to talk with you earlier. I meant to tell you I'd seen this post and tell you I agree with folks that say ethanol is bad on small engine fuel systems. More so on ones that sit for extended periods of time. Below is a link to a site that list e-free stations. Click on NC and see if there is one around you if you don't know where one is already.
     Tee
http://pure-gas.org/
Offline Seaman
« Reply #16 on: November 05, 2013, 03:18:13 PM »
I try to burn e-free in the mill. When I cannot, I add Seafoam.
Started another link about the bar issue cause I was so excited.
Woodmizer LT40HD
Semper Fi
Carb icing on the Kohler 25HP
Started by Geoff on Sawmills and Milling
Last post November 06, 2002, 07:05:56 PM
by ARKANSAWYER
Adjusting Kohler carb on a 17hp Magnum engine.
Started by Dave Shepard on General Board
Last post May 15, 2008, 09:25:38 PM
by Dave Shepard
Kohler 25 hp Carb repair Wood Mizer LT35 and others
Started by MartyParsons on Sawmills and Milling
Last post May 19, 2017, 08:42:05 PM
by SlowJoeCrow
New Stihl carb or Warblo carb?
Started by ihookem on Chainsaws
Last post April 24, 2015, 07:45:06 PM
by SawTroll
