Author Topic: -Running a dual arch grapple -  (Read 1821 times)
Offline BargeMonkey
« on: April 20, 2014, 11:14:53 PM »
 Got the skidder in the woods and trying to get the hang of it. Has a 120" esco grapple on it. Just wondering if anyone has some tips on what to watch for or what not to do, she seems to grab wood pretty easy but this is my first grapple. She is following a Timbco and im hoping to get 125-150 average trees a day out on a 1/4-1/2 mile skid.
Offline Kemper
  • Go Big Blue!
Re: -Running a dual arch grapple -
« Reply #1 on: April 20, 2014, 11:26:09 PM »
Tip #1 if you don't have wood in the grapple make sure it's closed or you could easily get your tires by mistake.
Offline chainsaw
« Reply #2 on: April 21, 2014, 01:17:17 AM »
Keep your turn low and close when skidding down hill.low and close will also let you pull a heavier turn with out pulling a wheelie.
Earth first,we`ll log the other planets later
Offline loggah
  • Just hangin' around :)
    • Johnson Hollow Sawing and Shingle Making
« Reply #3 on: April 21, 2014, 07:06:46 PM »
How is the inside of the grapple jaws? is it smooth or does it still have a good raised edge? lots of time when they get smooth ,they wont hold the wood good. the best thing is to have your bundles the right size , takes a while to figure it out.
Interests: Lombard Log Haulers,Tucker Sno-Cats, Circular Sawmills, Shingle Mills, Maple Syrup Making, Early Construction Equipment, Logging Memorabilia, and Antique Firearms
Offline CCC4
« Reply #4 on: April 21, 2014, 07:39:34 PM »
Make sure when you grab yer hitch that you always keep the hose box facing away from you...this will change when grabbing left or right hitches. When empty, keep your pincher tips just touching and carry yer grapple low, they can get in your tires...closing them all the way is just as bad, almost touching is where you want to be.
Offline BargeMonkey
« Reply #5 on: April 22, 2014, 10:30:44 PM »
 The grapple is kinda smooth on the jaw, looking to see what I can weld to give it a sharper grab surface. Trying to get the hang of it, im suprised it isnt as big in the woods as I had figured. This job isnt the best for making tight bunches due to all the small growth and brush. Setting a 30ft bridge across the creek next week and getting into the bigger stuff.
Offline treeslayer2003
« Reply #6 on: April 22, 2014, 11:32:20 PM »
lets have a look at her
Offline BargeMonkey
« Reply #7 on: April 22, 2014, 11:43:04 PM »
 Ive given up trying to post pictures, I can get them into the gallery but when I go to post it wont take a .jpg format.
Offline beenthere
« Reply #8 on: April 23, 2014, 12:13:23 AM »
Bargemonkey
You have one pic in your gallery, placed Apr 10 it looks like.
Once the pic is there, just click on the line below the post window (get there by clicking "modify" in whatever post you want the pic shown) that is the blue hi-lighted "click here to add Photos to post" and the on the top menu select "my gallery". Once there, click on your pic and it will blow up to full size. Then scroll down a page or two for the "Insert image in post" and you should have your pic.
Not sure where you are getting the hang up, but shout out for some help wherever that happens.
bt
Offline loggah
« Reply #9 on: April 23, 2014, 07:04:10 AM »
I found the best thing to weld onto the jaws is a couple pieces of Re-bar no 6 works well,bend it into the curve and weld both sides in completely, the rebar has a lot of carbon and lasts really well,also the rough surface bites into frozen wood pretty well.
Offline celliott
« Reply #10 on: April 23, 2014, 09:47:11 AM »
If you can get them into your gallery, you should be all good.
Go to your gallery, and on the photo you want to add to a post, click "insert image in post" or copy+paste the wording below.
Don't give up, we like to see pictures!
Worked with the timbco picture you have in your gallery.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline sawhead21
  • chop till you drop
« Reply #11 on: April 23, 2014, 06:25:58 PM »
when turning keep the buts off the grate and out of the tires also. tryto keeps your buts together in the grapple makes life easier. if you pick up a bundle with buts not together you can just losing the graple so the hitch slides and drive in reverse pushing the buts agenst the grate
Offline BargeMonkey
« Reply #12 on: April 23, 2014, 07:21:26 PM »
Offline BargeMonkey
« Reply #13 on: April 23, 2014, 07:23:27 PM »
Offline BargeMonkey
« Reply #14 on: April 23, 2014, 07:25:14 PM »
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #15 on: April 23, 2014, 08:01:42 PM »
That's a tough looking machine!
Offline celliott
« Reply #16 on: April 23, 2014, 08:08:05 PM »
 8) He got it!
Nice looking TJ!
Chris Elliott
265rx clearing saw
Offline BargeMonkey
« Reply #17 on: April 23, 2014, 08:29:34 PM »
8) He got it!
Nice looking TJ!
Thank you. Yeah my internet service is spotty up here, and sat in the sawmill today eating lunch and figured it out. She is a tank, and seems pretty stable. That was one big bag of 100' bills right there, bank pulled me aside and asked me "what the #◊% $" are you doing with that much cash.  8)
 800.00 in oil and filters to service it, hopefully thats it for a while. Needs a few cylinders packed and a couple pins and bushings in the arch are worn. Other than that she works good.
Offline thecfarm
« Reply #18 on: April 23, 2014, 08:31:56 PM »
Now that's a weapon!!
Offline Bobus2003
« Reply #19 on: April 23, 2014, 10:41:26 PM »
Whats it have for a grapple? I ran a TJ 450 for a couple years with a Esco grapple.. I didnt really like the machine (Deere Guy) and really hated the Esco grapple (had one on the 518 also) they are just hard to keep wood in. Had a JD 748 with an Esco, boss couldn't find a JD Box Style grapple quick enough, he didn't even put it in the woods till the new grapple was on.
450C dual arch grapple,
Started by BargeMonkey on Forestry and Logging
Last post February 27, 2014, 07:28:56 AM
by loggah
Timberjack 450 Dual arch grapple and winch.
Started by rfm7fxfox on Forestry and Logging
Last post November 18, 2013, 08:07:17 PM
by ga jones
Single arch or dual arch ???
Last post November 25, 2013, 01:14:20 AM
by thompsontimber
franklin 185 dual arch $25,000
Started by spencerhenry on For Sale
Last post August 19, 2009, 02:32:14 PM
by spencerhenry
