Arborwear
Author Topic: - support for Rottne equipment ??? -  (Read 2914 times)
Offline BargeMonkey
« on: June 15, 2014, 06:28:03 AM »
 Starting to get the itch for a new piece of iron and after losing my last employee im starting to look at going CTL for 90% of it. Sick of buying stumpage, pampering help and not getting ahead. Found a few Rottne forwarders for sale, both actually within driving distance and just wondering whats the good and bad with them ? Been looking at the Timberpro's but they seem so big, maybe its just me. Ive only got a small 4 wheel 230 right now, but i see the potential for a big forwarder. Will an 8 wheeler really go where "they" claim ? Another local logger runs a 670 franklin 6 wheeler, bunching with a dozer and a Timberpro barsaw buncher and im not ashamed to admit he does a nicer, cleaner job. I told my dad when I was home I was looking at a Rolley head and an 8 wheeler, he just shook his head. Right now counting the 7 trucks, we stand at 42 pieces of equipment not counting any of the trailers or small stuff.  :'(   counting batteries and tires will make you cry anymore.
Offline Jamie_C
Re: - support for Rottne equipment ??? -
« Reply #1 on: June 15, 2014, 07:17:25 AM »
I have run a few Rottne forwarders, you can put a lot of wood to the road with them in a hurry. Going from a standard TJ 230 to an 8wd Rottne is like coming out of the dark ages. Hydrostatic drive forwarders will get around in a lot rougher and hilly ground than you could dream of in a standard tranny machine.
Offline Brleclaire
« Reply #2 on: June 15, 2014, 08:46:35 AM »
Don't know much about rottne but the timberpro's only look big because of the way the house is mounted. The machines are the same width as your timbco. A few loggers around here have them and they seem to go through the woods just fine. Put some tracks on a 8 wheeler and you will be surprised where they can go. Not only on hills but also in soft ground if the processer puts the tops in the trail making a mat for the forwarder to run on. Only thing is if you get one stuck its a little bigger project to get it out than your 450
Offline snowstorm
« Reply #3 on: June 15, 2014, 09:08:07 AM »
like jamie says out of the dark ages. the dealer in pa is factory owned. so they stock a lot of parts. one thing i find kinda odd about them they dont open till 8:30am. depending on the year it could have a iveco or deere motor or if its real old a ford. with the iveco once you get the part numbers crossed over to new holland parts can be had. i have a list of most engine parts. they are a well built machine and fairly easy to work on......most of the time. i was told not to spend a money on the ac replace it with a red dot. as he said we only have 2 to3 weeks of 70 degree weather in sweden  we dont need ac
Offline BargeMonkey
« Reply #4 on: June 15, 2014, 10:38:48 AM »
 Theres 2 machines for sale ive seen,
 1 has pretty high hours, somewhere around 19k, 6 wheeler with good rubber and joystick. It has a 6.8 deere engine which is a plus for me, just came off a pipeline job. 50k
 The other 1 is a newer 8 wheeler, a 2000 I think with 4k hours. Nice looking machine, with the iveco engine I believe. Thats 150k, which is getting up there for what im looking for.
 I would probably either sell the jack outright, or see if the dealer might take it in on a rolly head, so being stuck with 2 doesnt happen. Just kicking the idea around. Anyone know the capacity on a 6-8 wheel rottne rapid ?  The jack is ok but she is tippy, doesnt reach very far and has served her purpose.
Offline MT logger
« Reply #5 on: June 15, 2014, 10:59:42 AM »
I havn't run rottne but I have most others ponsse is the best machine and best support bar none. Just my opinion.
Offline Jamie_C
« Reply #6 on: June 15, 2014, 11:33:57 AM »
The Rottne Rapids have a max capacity of 16 tonnes ... roughly 8 cords in theory. I would go with the 8wd, lot smoother ride and better traction in wet areas.
From my experience the Rottne and John Deere forwarders will climb much steeper hills with a full load than a Ponsse. The last Ponsse Buffalo King I ran wouldn't drag 12 tonne loads up the same hill a Rottne or JD would drag 16 tonne plus loads. And that was after new drive pumps and trips by the dealer to ensure all pressures were set properly.
Offline barbender
« Reply #7 on: June 15, 2014, 02:10:43 PM »
I still don't understand why that Ponsse wouldn't climb, Jamie. I've never had mine power out, it either digs holes or spins inside the tracks. I also don't consider 8 wheel machines smooth riding, they are superior by every other measure but they beat the snot out of the operator when you are driving. The smaller tires don't roll over stumps, they slide off and knock your guts out. It may be different with tracks under the cab as well, we just run chains and you get to feel every stump twice >:( I have no experience with Rottne machines, I've only ran Ponsse machines and only for the last 3 years.
Offline barbender
« Reply #8 on: June 15, 2014, 02:46:46 PM »
Another thing, I can't speak for other brands but with Ponsse machines, your A/C system needs to function or you can't operate. If it is sunny, it only needs to be about 20 F and you will have it on. With all the windows for solar gain, you will cook, and the windows are all sealed. When you add the heat from the hydraulics under the cab, you find yourself using the A/C way more than you would expect. It can be a high maintainence item, but very necessary so be prepared for the associated costs.
Offline MT logger
« Reply #9 on: June 15, 2014, 03:15:05 PM »
AC is a must in all on a sunny day we have done long adverses of 60% if your diff is locked when you need it and the soil holds she'll climb. my favorite thing about ponsse is the support, great guys.
Offline 1270d
« Reply #10 on: June 15, 2014, 04:21:00 PM »
ill agree the 8w is a rough ride.  For operator comfort 6 wheel is nicer, my opinion.  8 is superior in traction and flotation though.
Offline Jamie_C
« Reply #11 on: June 15, 2014, 05:17:08 PM »
All of the 8wd machines I have ran had half tracks on the front bogies too, with only wheel chains on the front they are a rough ride.
As for why that Ponnse wouldn't climb hills I have no idea unless the dealer mechanic really goofed. The previous owner had the same problem. The day I had the mechanic in the machine with me and it wouldn't climb a 15 degree hill with a load on I laughed at him when he said it was so steep nothing would climb it. The hill wasn't even steep enough to bother wearing the seatbelt in the harvester. It wouldn't spin or dig holes even if you tried to. I personally think that the relief was set way too low, I bet it didn't have the tractive effort of a 12 tonne machine and it was rated at 18 tonne.
Offline Jamie_C
« Reply #12 on: June 15, 2014, 05:20:33 PM »
Oops forgot ... without an operating a/c unit forget about running them on sunny days with a temp much over 10 Celsius ... will be like being inside a slow cooker ... push that to 20 Celsius and you will literally get heat stroke it gets so hot in the cab. You are basically sitting inside a greenhouse.
Offline 1270d
« Reply #13 on: June 15, 2014, 08:25:39 PM »
Yes I have never run with tracks on the cab end of the machine.
 Early this spring before the snow went, my a/c was out on the harvester.  My phone registered 132* f.  Outside temp maybe 45*.
Offline snowstorm
« Reply #14 on: June 15, 2014, 08:46:50 PM »
dont be scared of the iveco motor. its a very well built engine. as the rottne guy told me a lot of owners liked the iveco better than the deere. it had more torque and used less fuel than the jd. i have had a hard time getting the part numbers for engine parts. all the new iveco part # are new holland part # so its all available. they use to use air over hydraulic brakes . the hydraulics are all electric  so there is no oil in the cab. with a air ride and heated seat you wont even  want to start that tj again
Offline snowstorm
« Reply #15 on: June 15, 2014, 08:48:10 PM »
19000 is not high hours 30000 might be
Offline Jhenderson
« Reply #16 on: June 15, 2014, 08:52:38 PM »
Make sure it's a US spec machine. Dealers won't support a grey market piece that was bought in and shipped from Europe.
Offline BargeMonkey
« Reply #17 on: June 15, 2014, 09:16:49 PM »
  I know my 230 is over 10k, and my jack and deere skidders have over 10k, but generally we wont even look at anything with over 5k hours. We have a mechanic 1-2 days a week and our maintenance program is 100% but im leery of buying a basket case. I saw a 640D with 32K on it, about fell over. John deere had a few loaders @ finch years ago with 40-50k on them. Our 644H has 12k now and its getting time for a K series come fall.
Offline BargeMonkey
« Reply #18 on: June 15, 2014, 09:56:09 PM »
 Will the newer parallel link loaders pick up and handle the big, long stuff comfortably ? My 230 will pick about anything, but you wanna be careful reaching over or she gets tippy.
Offline BargeMonkey
« Reply #19 on: June 15, 2014, 10:08:20 PM »
Also.. whats a set of tracks cost ? Ive been looking and seen a few different brands but didnt know which was best, or they where even worth having ? How hard are they to take on and off ?
Support Equipment
Started by summerjob on Sawmills and Milling
Last post May 15, 2005, 06:53:14 AM
by Fla._Deadheader
Auxilary Support Equipment?
Started by Mobilesawyer on Sawmills and Milling
Last post September 01, 2007, 06:35:18 AM
by Ron Wenrich
Some ugly support equipment
Started by woodNthings on Sawmills and Milling
Last post October 23, 2013, 07:45:25 PM
by jlmccuan
Small mill support equipment
Started by ex-Engineer Wannabe on Sawmills and Milling
Last post October 31, 2005, 07:27:41 AM
by JP
