Recent
458 Guests, 3 Users
Dan_Shade, lxskllr, Ianab
Welcome to The 2024 Forestry Forum!
Do you have trees to grow? Logs to saw? A forest to manage? Chainsaws to fix? A sawmill to purchase or maintain? Timber related business to run? Lumber to dry? Trees or plants to identify? A cabin to build? Are you hungry and like FOOD?
Or would you just like to pull up a stump and visit with a friend?
If any of these and a multitude of other topics apply, then The Forestry Forum is the place for you.
What Will you Find on the Forestry Forum?
Pages: [1] 2 ... 40
I've been looking at repairing my current blade, it's been welded too many times, as well as replacing bushings but estimates have been pretty pricey. I have a chance to pick up a 440C blade in great condition. Everything lines up and fits the D but it's about a foot less wide and three inches less...
Read More
2 Comments
Just getting started on the forum although I have been reading it for over a year.
Just retired and have time to use the Norway LM30 I bought 2 years ago.
Working my way through Red and White oak from land clearing for my sons home.
Thanks for all the great info and I will have questions Im sureRead More
15 Comments
Good day everyone,
Looking for some of your inputs on a sawmill I'm looking to purchasing.
Vallee equipment 'Little blue" sawmill.
https://valleeforestryequipment.com/product/little-blue/?v=3e8d115eb4b3
What are your thoughts?
They are made only a few hours away from me.
20hp honda engine
The frame is 2x6 3/16
Read More
19 Comments
Does anyone know these engines differences really well, or can point me in the direction of someone that does?
So a friend of mine bought a Valmet 544L, and I fixed the blown head gasket to get it running. Previous owner said they replaced piston and connecting rod #2... Within an hour of running it was making very angry sounds. I pulled the engine out and apart and see they swapped a used rod into #2 cylinder (it was stamped "5" and this is a four cylinder engine...). The rod bearings had spun on #2. The rod in #2 is different than the other rods in the engine. This engine needs a crank, bearings, and a rod at minimum.Read More
5 Comments
This is about hardwoods. I came across an article (link) that mentioned having 36 crop trees per acre, which means about 35 ft between all trees. I have a 40-ac woodlot of nice hardwoods and in a lot of it, there are far more than 36 trees/acre, but of course, most of them are small and would need to
Read More
6 Comments
Pages: [1] 2 ... 40
