Arborwear
Author Topic: Tree Cub  (Read 7893 times)
Offline mad murdock
Re: Tree Cub
« Reply #20 on: May 24, 2015, 08:29:08 AM »
That is real neat!! Wood power skidding more wood 8)
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #21 on: May 24, 2015, 12:53:33 PM »
Thanks Mad Murdock..
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #22 on: January 10, 2016, 07:24:37 PM »
Since the end of last winter I have not had any real time to work on this project. Might have been a good thing because the steering has been a real bug a boo. It kind of came together when I stripped all the sheet metal off and that gave me some room and changed things a bit.
Below is a poor vidio of the steering. Sorry about the poor quality.
Offline Paul_H
Re: Tree Cub
« Reply #23 on: January 10, 2016, 07:31:35 PM »
It will be interesting to see it's maiden voyage.
eg  tregar  meste  på  Tulla, for  ho  var  krulla  i  ulla.
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #24 on: January 30, 2016, 09:24:09 PM »
The first test run was today. Not on wood gas, that will come later. I just have an old engine C-clamped on because I picked up the wrong size v belt do i'm using an old long belt.
Still have a long way to go...
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #25 on: February 01, 2016, 08:17:33 PM »
Added steering snubbers so it doesn't buckle too far, when turning, and damage it's self. Used chain for that. Second test run I got into the woods. It's nice to be able to steer out of a spinning wheel..!! So far so good. Next is to find the right belt length and mount the engine more rearward.
And
Offline mad murdock
Re: Tree Cub
« Reply #26 on: February 02, 2016, 01:17:57 PM »
pretty much what you got there is a ride-on self propelled arch, pretty cool creation!  I can't wait to see it pulling wood 8)
Offline enigmaT120
Re: Tree Cub
« Reply #27 on: February 03, 2016, 04:13:12 PM »
What a cool machine.  But is there anything left of the Cub?
Ed Miller
Falls City, Or
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #28 on: February 04, 2016, 08:28:22 PM »
It's really built out of a wheel horse but if this works out I might also build one from a cub cadet. Don't ask which ones best, pros and cons for both of them.
It worked out once I got rid of all the junk that makes it hard to work on. So at this point I'm just using the trans axle, frame, steering wheel and seat. I'll add some sheet metal later.
Picked up some v belts so I should get the engine put in a better spot this weekend. Need to weld the rear portion more before I try pulling some wood. It's just tacked right now. Part of it is galvenized so I need to do that out side in the cold rain and snow..... And then the new gasifier build will be next.
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #29 on: February 07, 2016, 07:47:23 PM »
Moved the engine back and welded the back axles up. Running out of time, I headed out into the woods and hooked up to a pole. Of course things are c clamped on and the wrong winch in the wrong place, etc etc. Had to give up taking a video just too many things to deal with. Long story short is that I can not turn too sharp because the log will hit the back wheel and act like a big brake. Poor thing took some abuse before I figured out what was going on. Well, I got the log out after that then dragged it around the barn about half a dozen times. Need to make some kind of rear bumpers for the rear tires.
The jury is still out as far as traction goes. Just need to try it more and learn how to use my new tool.
Still a long ways to go.....
Photo in the woods with the first log/pole.
A photo of the hood just setting over the engine...
At least I didn't break it..... 😉
Offline mark3885
Re: Tree Cub
« Reply #30 on: February 16, 2016, 01:50:47 PM »
Awesome machine I really like the gasifier. I have been running  Biodiesel I my truck and all my diesel equipment for 12 years now.Alternative fuels are cool and cheap, no war required. 8)
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #31 on: July 05, 2016, 08:09:22 PM »
Dad is running the Chomper and I'm feeding them some blow down stems. Longer than I should skid but the rig did it. But the stem was close along the drive way, that helps.. the saw logs were skidded with the skid steer not the tiny rig.
Offline thecfarm
Re: Tree Cub
« Reply #32 on: July 05, 2016, 09:52:15 PM »
That is quite the rig you have there. You can seek that through the woods and not much of a need to cut a road if you hauled some short stuff out. The wife has a 30hp tractor. I use that in the woods just a little.She won't let me use too much. Mostly I put a trailer behind and I load wood on to that. She don't want me bang up her tractor. I would like to have a small tractor to haul out small wood. Can't really tell I been there with the wife's tractor.
Online WV Sawmiller
    • Green's Sawmill Services
Re: Tree Cub
« Reply #33 on: July 06, 2016, 10:14:31 AM »
   I'm intrigued by the design but wonder if it has enough weight in the front end to help counterbalance pulling a heavy log. Otherwise a real neat looking outfit.
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #34 on: July 07, 2016, 12:28:57 PM »
The pull point is about in the mid point between front and rear axle. So it tends not to nose over.
Offline coxy
Re: Tree Cub
« Reply #35 on: July 08, 2016, 06:52:48 AM »
that's a pretty neat rig you got there  8) 8) 8) now you have to work on a forwarder  :D :D
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #36 on: July 09, 2016, 10:27:39 PM »
A forwarder has crossed my mind but I think a cart for the rear end of the log would be the next step. After that a utility vehicle with a cab would be usefull. For the rear cart would a walking beam or just larger single tires be better?
Offline enigmaT120
Re: Tree Cub
« Reply #37 on: July 12, 2016, 02:38:43 PM »
If you want to be able to drive through the woods, I know a guy who logs with a pretty beefy ATV (sorry, don't know size) pulling one of Logrite's arches.  That's probably better than a tractor.  I don't think he has to pull downhill very much though!
Ed Miller
Falls City, Or
Offline Puffergas
    • Puffergas
Re: Tree Cub
« Reply #38 on: August 08, 2016, 10:40:48 PM »
This is about the limit under ideal conditions but going up an incline. Dead pine stem.
Offline mad murdock
Re: Tree Cub
« Reply #39 on: August 12, 2016, 08:49:34 AM »
That is a very respectable load for the size of that machine, IMO!  Good job on it, the coolest part is the woodgas power.
sad
Bushfires Australia story featuring video - Tree Cutting and Tree Removal
Started by acetree on General Board
Last post July 24, 2009, 10:15:06 AM
by acetree
20 inch Tree Terminator tree shear with top grapple SOLD
Started by okmulch on For Sale
Last post January 30, 2012, 06:23:40 PM
by okmulch
Magnolia Tree Question for all you Tree Experts
Started by DR_Buck on Ask The Forester
Last post June 27, 2015, 08:34:15 PM
by brendonv
Oak Tree, Central New Jersey - Tree Identification
Started by joerosa1 on Tree, Plant and Wood I.D.
Last post March 18, 2017, 05:10:41 AM
by plantman
