Arborwear
Author Topic: Stihl 026 trouble  (Read 3955 times)
Offline woody367
Stihl 026 trouble
« on: November 06, 2015, 01:24:24 PM »
My Stihl 026 ran fine last week now it will start and the  die like it is out of fuel. Even wit the choke set it does the same thing, what might be wrong with it? It has plenty of gas in it.  Thanks
Offline sawguy21
Re: Stihl 026 trouble
« Reply #1 on: November 06, 2015, 01:33:46 PM »
Check the fuel and impulse line for cracks. The in tank filter may be plugged. There is also a small screen in the carburetor that gets plugged with flock from the tank filter if it has that style.
Offline joe_indi
  • The older I get the more I learn
« Reply #2 on: November 07, 2015, 06:43:53 AM »
^^^^^ plus is your fuel fresh or old?
Is the air filter clean?
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #3 on: February 25, 2016, 09:03:51 PM »
I had that problem with mine a few years ago, the carb had gotten gummed up. I cleaned the carb, reset the hi and low and had no more problems.
Offline CTYank
  • Ain't he cute?
« Reply #4 on: February 25, 2016, 09:40:02 PM »
May have a prob w/H mixture setting. Many of the carbs used on 026s have fixed H mixture.
I'd also check that the carb is properly attached.
Because of the reported sudden emergence of the problem, it has to be something obvious.
'72 blue Homelite 150
Echo 315, SRM-200DA
Poulan 2400, PP5020, PP4218
RedMax GZ4000, "Mac" 35 cc, Dolmar PS-6100
Husqy 576XP-AT
Tanaka 260 PF Polesaw, TBC-270PFD, ECS-3351B
Mix of mauls
Morso 7110
Offline btulloh
« Reply #5 on: March 05, 2016, 07:45:51 AM »
Did you get your saw running?  I had this problem with my 20 year old  026.  Ran great one day, next day it started and then died right out.  Tried all the easy stuff first.  Ordered an $9 rebuild kit for the carb, cleaned the carb real good (soaking the carb in a bucket of cleaner).  Runs better than ever now.  I love my little 026.
HM126
Offline logeeland
« Reply #6 on: March 27, 2016, 06:58:34 PM »
Check the tank vent.
Stihl Fan, 036, 361,361, 038 Magnum II, and a MS441
Offline Jim Davis
« Reply #7 on: April 03, 2016, 12:17:29 AM »
So, where is the tank vent?
My 026 is doing the same thing. It's not the carb, because it will run perfectly for up to 30 seconds or so, then just dies and is hard or impossible to start for a few minutes. The tank vent makes sense, so as I asked, where is it?
Jim
Offline starmac
« Reply #8 on: April 03, 2016, 12:57:37 AM »
This happened to me last summer. I was using a saw regularly then didn't use it for a couple of weeks. When I got ready to use it again it would start like it was new, idle fine for 30 seconds or so but die as soon as I touched the throttle.
I did all the easy stuff, changed the fuel line, filter and plug, with no change. I just used another saw and didn't mess with it for a week or so, and then decided to adjust the carb, now remember this saw was running perfectly a couple of weeks prior, but the carb was so far out of adjustment it would do nothing but start and idle.
It had been riding in the bed of the pickup for the two weeks I didn't use it.
This may or may not be your problem as it was the first time it has ever happened to me.
Offline Jim Davis
« Reply #9 on: April 03, 2016, 09:17:56 AM »
That's not the problem with my 026. Mine starts and runs strong, will cut well for a little bit, then dies and won't restart for a couple minutes or more. Then it goes again and quits.
Where is the tank vent? I'll look for it if nobody tells me soon, but somebody could save me a few minutes.
Offline logeeland
« Reply #10 on: April 03, 2016, 09:38:09 AM »
I have had similar issues. Many times it is the tank vent. It is to the right or left of the carb attached to the tank.
Offline Jim Davis
« Reply #11 on: April 03, 2016, 12:46:49 PM »
Thanks!
Offline Jim Davis
« Reply #12 on: April 07, 2016, 03:03:18 PM »
A few more questions. First how is the tank vent removed?
Second, it looks to me like there is about 5/16 of an inch of the metal tube exposed where the pulse line attaches to the carburetor and it makes me wonder if the pulse hose is barely connected and leaking at that spot.
Last, how is the back end of the saw disassembled to check or replace that pulse line?
Thanks. Sorry to keep coming back with more questions.
Jim
Offline Texas-Jim
« Reply #13 on: April 07, 2016, 09:03:27 PM »
Its very unlikely its the tank vent. The vent can cause the problem your having but it take several minutes to pull vacuum on the tank. More than likely its not getting fuel, either impulse isnt working (impulse line) or there is prob with the carb.
What we do in life echoes through eternity.
Offline Jim Davis
« Reply #14 on: April 07, 2016, 11:04:28 PM »
That makes sense to me. How do I get at the impulse line?
Offline ZeroJunk
« Reply #15 on: April 08, 2016, 06:48:26 AM »
You can do it with long needle nose pliars. It is easier for me to get the big end through the carb box wall and then put the end on the nipple. You may invent some new words in the process. It's tight.
Offline Jim Davis
« Reply #16 on: April 08, 2016, 09:25:46 AM »
So would a dealer mechanic disassemble more and charge for the extra time, or would he do it with the long nosed pliers?
I took another look at my saw and can't see how it would be possible to get the pulse line plugged onto the crankcase nipple without major disassembly. Hope there's a trick that I am missing.
Offline Texas-Jim
« Reply #17 on: April 08, 2016, 07:51:24 PM »
Before taking it apart you can check it. You need a vacuum gauge, just put small metal nipple on gauge and put it in impulse hose under the carb. Pull the rope sharply, the gauge will flutter. In order for impulse line to work it goes back and forth from vacuum to pressure as the saw runs, that alternating difference is your fuel pump. Im very bad at explaining things so if i confused you ill try again if you don't get what im saying.
Offline Jim Davis
« Reply #18 on: April 08, 2016, 11:29:42 PM »
Your explanation is clear to me. Thanks. I guess part of my blindness was not realizing that taking the carb off would open so I could get at the hose.
Still don't see what to take apart if I need to replace the hose. Can I do that through the opening where the carb fts?
Offline sablatnic
« Reply #19 on: April 09, 2016, 01:20:41 AM »
To put the pulse line back on the crankcase nipple you just need a pair of long nosed pliers, and then you need to unscrew the left vibration isolator to get a bit more room - it is tight, but it is possible, just, done it myself several times!
How are your vibration isolators?
Trouble with stihl 064 ave.
Started by woodyone.john on Chainsaws
Last post June 27, 2013, 03:52:43 AM
by sharkey
Stihl ms 661 trouble
Started by SJK on Chainsaws
Last post January 31, 2014, 12:57:41 PM
by SJK
Stihl MS 461 chain trouble
Started by RKnee68 on Chainsaws
Last post November 10, 2017, 02:52:35 PM
by RKnee68
I don't think I'm in trouble.
Started by Weekend_Sawyer on General Board
Last post November 17, 2002, 05:16:32 PM
by C_Miller
