Arborwear
Author Topic: New firewood processor build  (Read 11932 times)
Offline North River Energy
Re: New firewood processor build
« Reply #100 on: August 29, 2017, 08:10:11 AM »
Thank you.
It's been a good learning experience for sure.
I tend to run the smaller stock through a cordwood buzz saw.
Seems more cost effective in terms of fuel usage and machine wear?
Offline mjeselskis
    • Big Rock Lumber
« Reply #101 on: September 01, 2017, 09:28:59 PM »
Finally got a short video. It's still slower than it could be because of the low relief valve setting on the saw motor, but I've put about 6 cords through it and it does ok up to about 12".
2006 WM LT28  2002 John Deere 990
« Reply #102 on: September 02, 2017, 10:15:12 AM »
That looks respectable. Can you up the pressure on the saw drive, or are you already at the margins?
Offline mjeselskis
    • Big Rock Lumber
« Reply #103 on: September 02, 2017, 01:28:00 PM »
The pump has a cartridge relief valve built into it that is supposed to be at 3000psi, but it's going at 1500 instead. It's easy to replace if I can find a new one.
Even getting another 500-1000psi would certainly be much better.
« Reply #104 on: September 02, 2017, 03:20:14 PM »
The flow control for my saw motor had a built-in relief that blew off way too soon, so I added enough washers to the spring to bind the coils, then added an adjustable stand-alone valve upstream of the flow control.
That might not work for your situation, however.
Meanwhile, assuming you have a pressure gauge on the circuit, you could shim the spring and see if that helps?
Online firefighter
« Reply #105 on: September 02, 2017, 09:39:23 PM »
Nice video and congrats on the great job you did.One question did you build the conveyor?Again great job.
Online firefighter
« Reply #106 on: September 02, 2017, 09:58:37 PM »
Would it be possible to get a couple pictures of the completed processor . Could you also send a picture of the part for the length the round is to be cut thanks Peter
Offline lopet
  • Do not climb any higher your comportable falling !
« Reply #107 on: September 03, 2017, 09:11:59 AM »
Yeah, looking good. The saw might be a issue, but what makes you think it's a pressure problem ?
Saw motor could be at it's limit or pump only puts out so many gallons.  Just sayn.
Offline mjeselskis
    • Big Rock Lumber
« Reply #108 on: September 03, 2017, 12:32:22 PM »
The saw motor speed is good, so the gpm from the pump is fine. It cuts great in smaller wood (less than 8"). I have a pressure gauge on the supply line to the pump and when I stall the chain, the gauge is only reading 1500psi and the relief valve on the pump is stamped 3000psi so I'm pretty sure the spring is weak and it's lifting early. The relief valve is a cartridge and it's self contained so I can't shim it. I'll post a picture of it later when I get some pictures for firefighter.
Offline jmur1
  • Wood is King
« Reply #109 on: September 04, 2017, 06:10:52 PM »
Hi mjeselskis:
Very impressed with your build.  Nice post all around.  Great work.  Keep the updates coming!
jmur1
Easy does it
Offline dave_dj1
« Reply #110 on: September 05, 2017, 06:34:34 PM »
Very nice! It's much better to move handles than the alternative of cutting with a saw, moving wood to the splitter etc etc. Nice job! I am jealous.  8)
Offline mjeselskis
    • Big Rock Lumber
« Reply #111 on: September 07, 2017, 12:20:08 PM »
Firefighter,
Here's a few pictures. The log stop is 2" square tube and it slides into a receiver tube that I got on Amazon. The stop is drilled and pinned for different length firewood.
I got the conveyor as scrap from the paper mill up the road and added the legs and axle since it was horizontal in the mill.
Offline dave_dj1
« Reply #112 on: September 07, 2017, 08:16:00 PM »
Nice pictures, thanks.
Do you notice any problems with the saw binding towards the last of the cut because of the solid stop? I do like the idea of a solid stop over a chain or antenna though.
Keep us in the loop as it progresses :)
Again, nice job  8)
Offline mjeselskis
    • Big Rock Lumber
« Reply #113 on: September 07, 2017, 08:50:11 PM »
I like the solid stop. It's nice to have a good stop when advancing the log, its easy to get the right length without fussing with it. 95% of the time, the wood falls down without binding but there have been a few times when the piece hangs up and the saw kinds of cuts on the up stroke until the piece falls. It's not enough to make me think about changing it.
Online firefighter
« Reply #114 on: September 07, 2017, 08:57:35 PM »
thanks for the pictures they are great.
Offline blackfoot griz
« Reply #115 on: September 10, 2017, 10:48:33 PM »
Mike,
I'm glad to see that thing run...it's been a long time in coming for you!  Can you start a new cut as your splitter cylinder is retracting?  That would speed things up a tad. Great build!
Offline mjeselskis
    • Big Rock Lumber
« Reply #116 on: September 11, 2017, 08:55:18 PM »
Mike,
Thanks, I appreciate all your help. I can start a new cut while the splitter is retracting, but I'm usually the slow link in the process.
Offline Stinny
  • firewood cuttah
« Reply #117 on: September 13, 2017, 01:07:53 PM »
Great job on the build project. Very impressive!!!
Suzuki 4x4 on Tatou tracks tugging logs in winter
Processor Build, Home Made Firewood Processor
Started by Higgo on Firewood and Wood Heating
Last post July 10, 2017, 06:57:27 AM
by Tony01
Firewood processor build
Started by muddstopper on Firewood and Wood Heating
Last post July 08, 2012, 06:10:37 PM
by muddstopper
Want to build a homemade firewood processor
Started by Tommy Frantz on Drying and Processing
Last post April 01, 2016, 01:45:01 PM
by Tommy Frantz
Firewood processor build circler saw
Started by hiluxpig on Drying and Processing
Last post September 07, 2014, 05:41:32 PM
by BargeMonkey
