EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: side by side fix  (Read 1192 times)
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
side by side fix
« on: November 12, 2015, 07:42:00 PM »
My brother-in-law bought one of those economy level side by side UTVs from Tractor supply this fa;; and had trouble with it from day one. When pushing the choke in after starting, the knob would never quite seat right, and the engine was always acting like it was choking out. We decided to try and adjust the choke cable as it looked like it had been put together incorrectly at the carb. We tried this and we tried that, repeatedly re-positioning and adjusting the cable. Nothing we did made things better on this basically new machine. I then remembered the little precision applicator of Bluecreeper I keep in my truck. I went and got it and put a couple drops on the cable at one end, and a couple drops on the other end, and a drop or two on the carb linkage. As close as to instant as you can get, the cable started working properly and the chole opening and closing as it should. The engine stopped smoking from the extra fuel dumping in it, and it now starts good cold or warm. All because of a couple three drops of Bluecreeper.
Offline sandsawmill14
  • love my job (most days)
Re: side by side fix
« Reply #1 on: November 12, 2015, 10:45:15 PM »
glad you got it fixed :)
Offline Tamiam
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #2 on: November 13, 2015, 08:40:11 AM »
Great Bluecreeper story!
Bluecreeper making things better one drop at a time. ;D
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #3 on: November 13, 2015, 09:25:38 AM »
 I had a carriage bearing on my mill that locked up on me and had a job that needed get done. Took the bearing off thinking I had a new replacement here, none was found, got the bleucripper out and a few drops later it was loose, a few more drops and it was turning, a few more drops and it was spining. it was put back on the mill and worked fine....   :)
Offline martyinmi
« Reply #4 on: November 14, 2015, 09:40:11 AM »
Gotta love that Michigan "slang"!
I used that on a wood splitter vendor from New York at the farm show down in Louisville, Ky a couple 3 years ago. He'd never heard it before. ???
I swear he started staring at my mouth to see if I had any teeth left.
I believe he was also looking for signs of bruising from a possible fall from a turnip truck! :D
No God, No Peace
Know God, Know Peace!
Online beenthere
« Reply #5 on: November 14, 2015, 02:51:29 PM »
You have lived a sheltered life..   ;D
WM LT300 Tapered Lumber side to side
Started by MIsawyer on Sawmills and Milling
Last post March 30, 2016, 03:06:45 AM
by JustinW_NZ
Woodmizer LT15 Idle side rail scraped by idle side vertical mast
Started by Hunter1000 on Sawmills and Milling
Last post March 27, 2016, 07:46:33 PM
by thecfarm
See you on the other side
Started by Buck on General Board
Last post April 05, 2011, 10:38:52 PM
by customdave
Flipping side bar!!!
Started by biziedizie on General Board
Last post March 17, 2003, 03:44:30 PM
by OneWithWood
