Arborwear
Author Topic: Anybody working on dust powered engines?  (Read 1636 times)
Offline mesquite buckeye
  • Trees are good- even ones with stickers
« on: November 29, 2015, 12:48:07 PM »
I was visiting the technology section of the Smithsonian probably close to 40 years ago where they had a dust powered engine. This thing was like a hundred years old, but apparently it worked. Basically worked on a dust explosion principle. Standard reciprocating piston with a notched circular disc that dumped the dust into the top. I can see lots of problems with running an engine with dust, but I think you could infiltrate the dust with nitrogen or some other really cheap gas so the explosion/fire danger could be minimized. Seems like if you could get this to work it would be a lot more simple to start up and run than a gasifier type engine. Those of us producing lots of sawdust would be in a perfect position to benefit from such technology.
Any thoughts? ;D ??? ??? ???
Offline ljohnsaw
Re: Anybody working on dust powered engines?
« Reply #1 on: November 29, 2015, 12:57:43 PM »
Sounds interesting but I wonder if it needs a particular size dust particles to work.  I know my dust is not uniform!  What type of vehicle or motor are you thinking of powering?  Tractor, generator, ??
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
« Reply #2 on: November 29, 2015, 01:23:48 PM »
Nothing in particular. I'm thinking it would be fun just to get an engine spinning at this point.
I think the dust would probably need to be size sorted and probably ground to get a uniform, fine consistency. I'm sure there would be a host of problems to solve to make it work. I think the original was designed to run on coal dust, which is brittle and easy to grind. I'm sure wood dust would work if you could make the right size and get it dry enough.
Offline Ianab
« Reply #3 on: November 29, 2015, 02:04:03 PM »
Laws of physics say it should work. Fine dust mixed with air burns quite well.  :D
The practical considerations like getting suitable dust, consistent dust flow and not blowing yourself up might be why it hasn't caught on?
Steam or Sterling cycle heat engine would seem more flexible and practical?
Offline starmac
« Reply #4 on: November 29, 2015, 02:38:28 PM »
It seems like the motors would have a short life span.
« Reply #5 on: November 29, 2015, 06:35:49 PM »
Maybe coat the pistons with high temperature teflon. You could also up its efficiency with a turbocharger. If you want to really go nuts, use oxygen enriched air.
I bet someone with a machinist's mind and a knack for putting together pieces from different sources could make this thing work.
Or maybe mount the piston upside down so that the crud doesn't have a gravity assist. There is that small problem with the oil sitting on the piston bottom. :(
Maybe a two cycle...
Offline Paul_H
« Reply #6 on: November 29, 2015, 11:46:15 PM »
I built one and hooked it to a vacuum cleaner and it's been running non stop since April 1st 1998  :P
eg  tregar  meste  på  Tulla, for  ho  var  krulla  i  ulla.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #7 on: November 30, 2015, 01:28:19 AM »
Industrial diesels and locomotive diesels have been run (successfully) using coal dust for fuel.
Your dust has to be very fine (i.e., a powder) so it will burn completely within the cylinder.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
« Reply #8 on: November 30, 2015, 02:43:55 AM »
Got a picture? ??? ??? ???
« Reply #9 on: November 30, 2015, 02:44:41 AM »
Do you have a reference to this??? :)
Offline Paul_H
« Reply #10 on: November 30, 2015, 10:08:51 AM »
No,I was totally BS'ing you ;D
Offline DMcCoy
« Reply #11 on: November 30, 2015, 10:10:22 AM »
I ran across this same reference with coal dust - WWll Germany maybe?   Can be done, if I remember correctly the drawback is injector abrasion.
 Edit: Nope ash content-  wood dust would also have a fair amount of ash.
Diesel engine ran on coal dust.
http://www.theoildrum.com/node/2249
There is also the 6 stroke engine. using steam from waste engine heat for the extra cycle.
« Reply #12 on: November 30, 2015, 10:49:33 AM »
Thanks a lot, Paul, for picking on the old man. :( :( :(
First time I got burned by an
April Fool's joke in November. :snowball: :snowball: :snowball: :snowball: :snowball: :snowball: :snowball:
« Reply #13 on: November 30, 2015, 10:54:22 AM »
Great stuff. You might want to skip the Luddite comments, however. It seems all new technologies create resistance.
I had no idea they have been developed to that point. Diamond injector tips and ultra hard valves and piston rings. Simple easy. ;D
Offline DMcCoy
« Reply #14 on: November 30, 2015, 11:33:53 AM »
Interesting foot note in the ongoing WV diesel scandal.  Engineer admitted to adding diesel to gasoline to improve the efficiency tests of gasoline cars.  Diesel contains more BTU per given volume than gasoline, kerosene edit- lower(?).  It would appear from light internet searching adding 10-20% is do-able.  Don't know if this is after the engine is already warmed up and no reference about emissions being tested at same time as MPG.
So diesel as a HP increasing additive?
Offline Brucer
« Reply #15 on: December 01, 2015, 12:37:39 AM »
I first heard about it from a co-worker who was interested in railroads (as a hobby) and also in how to get fine solids to flow (as a profession). He told me that German engineers studied it during WWII because they had limited access to liquid hydrocarbons. His opinion was that they would have to grind/pulverize it much finer and get rid of the ash before it would be practical.
Perhaps the best current reference is the one DMcCoy just posted.
Here's an interesting newspaper account from 100 years ago. Probably only of historical interest. https://news.google.com/newspapers?nid=1893&dat=19281127&id=kPMoAAAAIBAJ&sjid=29MEAAAAIBAJ&pg=5236,3682431&hl=en
Offline DMcCoy
« Reply #16 on: December 01, 2015, 08:01:08 AM »
Brucer- Interesting article.  Deals with the ash issue directly.
I suspect at times that the convenience and adequate abundance of liquid fuels caused a great many of these inventions to get lost. We consume an insane amount of FF every year.
Offline r.man
« Reply #17 on: December 01, 2015, 08:54:06 AM »
I think that a full size mill would produce usable wood dust but it is airborne and settles gradually on all surfaces. I did tour a mill two years ago that had an expensive fines collection system, complete with explosion and fire suppression capabilities, so I expect they would have a supply of engine dust on hand. As to the danger of working with it think about gasoline and propane for volatility.
Lazair Ultralight powered by Pioneer 100cc Chainsaw 5.5hp Engines?
Started by Armilite on Chainsaws
Last post December 18, 2016, 03:04:08 PM
by weimedog
Working with trees services, and working and working...
Started by Daren on Urban and Community Forestry
Last post April 23, 2009, 02:01:44 PM
by chep
For all the hard working, "working class" folks out there.
Started by jjmk98k on General Board
Last post May 11, 2010, 07:19:21 AM
by Ianab
EPA---gas engines
Started by D._Frederick on General Board
Last post August 23, 2002, 04:29:49 AM
by ADfields
