Arborwear
Author Topic: I adopted new baby-girl  (Read 4047 times)
Offline Climber
  • Quick, Clean & Safe
« on: December 17, 2015, 06:19:15 PM »
I adopted new baby-girl. It cost me $22,000
Her name is T8500 last name GMC.
She does not pee or poop. Clean and dry.
She born in 2002 and only traveled 9,000 miles ( oh yes! under 10 thousand)
Also got for her a boy-friend. He will ride her in near future.
Offline sawguy21
Re: I adopted new baby-girl
« Reply #1 on: December 17, 2015, 10:25:45 PM »
That looks good.  ;D Once you get the deck mounted you will have a nice storage container.
Offline Climber
« Reply #2 on: December 18, 2015, 07:45:33 AM »
I am hoping to sale it. Some one needs 30 ft dry box.
Offline timberlinetree
« Reply #3 on: December 19, 2015, 06:42:58 AM »
That will be a sweet rig when done. Those cab over fit in some tight places. Nice score!
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Offline Climber
« Reply #4 on: December 20, 2015, 02:53:29 PM »
Box is OFF. Cost = my labor.
Axles moved forward 42 inches. Cost = my labor.
PTO (Chelsea) installed. Cost = $2,300
Dual hydraulic pump 20+20 GPM x 2,000 PSI (bushing style, can go upto 3,000 PSI). Cost =$1,200
One on fuel tanks converted to be hydraulic oil tank.
Sub-frame for log banks welded and installed. It made of 4" x 4" x 0.25" square tubing.
2 hydraulic pressure lines made of steel run from PTO to back, where loader will be.
Sub-frame is used as return line. Holes cut and fittings are welded.
Offline Climber
« Reply #5 on: December 20, 2015, 02:55:54 PM »
I think I need to start new topic about it.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #6 on: December 20, 2015, 06:49:12 PM »
I think it would be just fine to put the whole build right here. :)
Offline Climber
« Reply #7 on: December 21, 2015, 12:24:21 AM »
Or, David,  you can just come by and see. I am only 2.5 hours away ;D
Offline ljohnsaw
« Reply #8 on: December 21, 2015, 02:00:55 AM »
Neat truck but I'm confused (not a trucker).  The axles look pretty far forward (long tail end) and you moved them further forward?  Are you going to trim off some of the tail?  Is it not good to have a 30' bed to haul some long logs, or would they be too heavy?
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Climber
« Reply #9 on: December 21, 2015, 10:57:06 PM »
The axles look pretty far forward (long tail end) and you moved them further forward?  ...
Yes. I am planing to have 18ft long bad and Prentice 120 on the back.
... Are you going to trim off some of the tail? ...
A: Already done.
...  Is it not good to have a 30' bed to haul some long logs, or would they be too heavy?
A: Weight is not a problem -   Maneuverability IS. Getting into tight spots is my specialty. I have some friend (See Picture)
he got huge log truck. Some times he can't get into places where I need him to be. My truck will be About 26 ft bumper to bumper. His truck is 40 ft + 34 ft trailer.
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #10 on: December 21, 2015, 11:00:33 PM »
subscribed
Boy, back in my day..
Online beenthere
« Reply #11 on: December 21, 2015, 11:15:48 PM »
Climber
You mean turning in tight space like this one?   ;D
Offline Climber
« Reply #12 on: December 21, 2015, 11:56:31 PM »
Yep, this is about it.
Offline Climber
« Reply #13 on: December 22, 2015, 07:17:14 PM »
Made some pictures today:
Right back view
PTO and Pump
End of the frame, subframe, pressure lines, also fottings for return oil.
Added Air Dryer and fuel filter in between battery bay and fuel tank.
Pressure line running inside chassis
Offline ljohnsaw
« Reply #14 on: December 22, 2015, 09:03:34 PM »
Sure looks like it could do some serious hauling - looking good.
Is the purpose of the sub frame carrying the return oil to give it a chance to cool off or to add more capacity?  Will there be anything attached/welded to this sub frame?
John Sawicky
Offline Climber
« Reply #15 on: December 22, 2015, 09:24:56 PM »
Sure looks like it could do some serious hauling - looking good....
A: GVW = 52,350 lb. So far it is 14,000lb. Hope payload will be about 22,000 lb
Is the purpose of the sub frame carrying the return oil to give it a chance to cool off or to add more capacity? ...
A: Valume. Cool. No extra piping. And strength of superstructure.
... ?  Will there be anything attached/welded to this sub frame?
A: Sure. 4 in x 6 in x 0.25 in crossmembers. with pockets and uprights. Qty = 5
Offline Knocker of rocks
« Reply #16 on: December 24, 2015, 11:21:17 AM »
I wouldn't recommend using the square tube sub frame as part of the hydraulic loop, even for the return circuit.  Too many stress risers, flexing and the like.  Seems like a leak is inevitable and almost unrepairable after it happens.  Iron pipe is cheap.
« Reply #17 on: January 02, 2016, 05:36:02 AM »
Wow! Nice job! That truck will be really nice to have. Dealing with wood removel on tree jobs is a real hassle but can score some nice logs!Thanks for posting!
Offline coxy
« Reply #18 on: January 02, 2016, 10:45:38 PM »
 what are you going to cover the motor with and what motor is in it   I would think the single frame would crack faster or bend    jmop
Offline brendonv
  • Arborist
    • www.VorioTree.com
« Reply #19 on: January 13, 2016, 10:14:55 PM »
Hows this coming?
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Baby Girl
Started by Karl_N. on General Board
Last post March 07, 2005, 09:03:03 AM
by Karl_N.
Wife's in labour!!!!!! Not anymore....Baby girl
Started by sbishop on Timber Framing/Log construction
Last post November 12, 2009, 05:18:25 PM
by WildDog
MORE OIL, BABY, MORE OIL
Started by fencerowphil (Phil L.) on Chainsaws
Last post January 27, 2002, 09:17:03 AM
by Kevin
I too Have a new Baby
Started by johnjbc on Sawmills and Milling
Last post August 01, 2002, 07:03:38 AM
by Tom
