Arborwear
Author Topic: t auger  (Read 627 times)
Offline 1styear
t auger
« on: January 02, 2016, 08:16:10 AM »
Are there any companies that makes t augers? I have been searching for one and the only ones I have found are on ebay.
Know just enough to be dangerous.
Offline beenthere
Re: t auger
« Reply #1 on: January 02, 2016, 08:48:15 AM »
Would you elaborate a bit more about what you refer to as a "t auger" ?
What is your application?
If timber framing, maybe an admin can move the thread to the timber framing forum.. ;)
Offline 1styear
Re: t auger
« Reply #2 on: January 02, 2016, 09:22:04 AM »
Hand Drill~Barn Beam Hole Auger. I hope this explains it clearly.  With the wooden handle and the auger bit it forms a T.  You rotate the handle with both hands to drill the auger into the wood to make a hole.
Offline Remle
Re: t auger
« Reply #3 on: January 04, 2016, 05:00:13 PM »
As others have said go down to the Timber Framing Section, Jim Rogers, moderator of that section sells them along with the rest of the tools for timber framing.
Auger Bit Question
Started by Haggis on Timber Framing/Log construction
Last post January 11, 2016, 03:28:16 PM
by Haggis
What can be used to power a big auger bit?
Started by TW on Timber Framing/Log construction
Last post November 18, 2006, 03:17:49 AM
by TW
Auger BIts
Started by iv3359 on Timber Framing/Log construction
Last post August 30, 2017, 03:25:14 PM
by Brad_bb
Auger'n Holes
Started by beenthere on General Board
Last post October 10, 2006, 06:08:33 PM
by johnjbc
