Arborwear
Author Topic: BT-6870 built by two old guys  (Read 13608 times)
Offline Gearbox
Re: BT-6870 built by two old guys
« Reply #140 on: October 24, 2017, 07:51:32 PM »
Repowered the processer today with a Predator 13 HP . The old Briggs was getting tired and couldn't pull to 2500 psi . I put a 12 in block in cross ways and it held right at 2500 . Ready start cutting for next years wood .
Offline hedgerow
« Reply #141 on: October 24, 2017, 09:20:26 PM »
Gearbox
You will like that 13HP  motor I have one on a cord wood saw and it has a lot of hours on it and zero problems. I run 20/50 Mobil one in it.
Offline Gearbox
« Reply #142 on: October 25, 2017, 09:17:48 PM »
I am running 5w 30 in it for 1 tank of fuel then I will switch to Mobil 1  0 w 30 . I run that in all my small engines .
Offline hedgerow
« Reply #143 on: October 27, 2017, 04:04:12 PM »
Gearbox
I have had good luck using Mobil one in air cooled small engines. Have a Kohler 25 with a couple thousand hours on it and in 70 hour oil changes it never takes any oil. Have a 25 year old 16 Briggs twin  that I should have put a hour meter on it but didn't probably gets 200 hours a year on it and all I used in it is Mobil one change it twice a year and it doesn't use enough oil to add any between changes.
Offline coxy
« Reply #144 on: October 27, 2017, 06:37:38 PM »
one thing ill tell you about your motor is take that vent tube that comes out of the gas tank and goes to the back of the carb other wise when the tank vents in the sun it will fill the crank case up with gas and hydro lock it i got one on my walk behind concrete saw and could not figure out how the gas getting in the oil after 3 oil changes in one day   i was sitting there and heard a gurgling noise and found it took the line off the top of the tank and that little vent shot gas a foot or so out of it so mine has been on hooked for about 6 years now
So now I have built my swinger with all of guys help, how do I dial it in
Started by bullshark on Sawmills and Milling
Last post May 16, 2015, 11:49:38 AM
by Ox
Built up Roof
Started by Don P on Timber Framing/Log construction
Last post June 11, 2006, 11:32:46 PM
by beenthere
grin
The Table Saw That I Built
Started by rbarshaw on Sawmills and Milling
Last post June 02, 2005, 09:19:56 PM
by Don P
Built yer own log splitter?
Started by Engineer on General Board
Last post March 18, 2006, 08:47:42 AM
by Frank_Pender
