Arborwear
Author Topic: connection problem  (Read 679 times)
Offline xlogger
connection problem
« on: May 02, 2016, 06:42:42 AM »
I cut on my computer this morning and could only get about 1/3 of the web sites I go to each morning. As you see I did get this one. Also can't get new emails, I use outlook. I unplug the router and cut off computer with no luck. Wonder what causes this?
update, just try unplugging router again, this time for about 10 minutes. No luck same as before. Should I call my provider or do you think it's on my end?
Offline xlogger
Re: connection problem
« Reply #1 on: May 02, 2016, 08:06:00 AM »
tried it again, got email now and a few more web sites but not all.
Offline pineywoods
« Reply #2 on: May 02, 2016, 09:40:10 AM »
xlogger, you likely have a router somewhere in your area that's temporarily down. (not yours) I can trace the route from my router to any destination. My Connection to the forestry forum may go through half a dozen routers, the number and route varies..Your connection would do the same but would be different from mine...
Angle Iron Connection for Post and Tie Beam Connection
Started by Jjoness4 on Timber Framing/Log construction
Last post October 04, 2017, 05:42:14 AM
by MbfVA
Tie Beam to summer beam connection/ problem /questions
Started by windfall on Timber Framing/Log construction
Last post July 15, 2016, 03:06:05 PM
by windfall
connection to hot tub
Started by xlogger on Firewood and Wood Heating
Last post October 11, 2014, 06:16:39 AM
by xlogger
losing my connection to FF
Started by 47sawdust on General Board
Last post June 27, 2015, 10:46:26 PM
by Brian_Rhoad
