Arborwear
Author Topic: Another great CraigsList find  (Read 5688 times)
Offline ljohnsaw
« on: May 14, 2016, 11:56:28 PM »
My daughter thinks I have special powers.  I think about what I want or need and it shows up on CL for free :D
Up at my cabin, I have a solar powered water well that pumps into a tank.  From there, when the cabin is done, an RV pump will supply the cabin.  The tank is high enough that it gravity feeds the toilet in my shower house I built last year.  I have to run the pump in the shower house for the shower and sink, however.
I've been wanting a gas powered pump to mount on a little trailer with water barrels so I can have some water pressure for concrete cleanup and ready water for burn piles and such.  So, today a old gas powered pump shows up for free about 5 miles from my house.
Its was a little dirty.  It had a light coat of white paint mist like it was sitting somewhere close to a building being painted.  I pulled the air filter off and it was totally clean inside.  The gas tank was dry, no rust with a little bit of dust (old sediment).  I check the oil and it is brand new.  The plug was used but in good shape.  I started to push off the oil soaked dust and was amazed at the condition.  I recognized the kind of puke green paint.
It has a little Briggs & Stratton 2 hp mated to a small pump.  It is an old Sears product.
I'm pretty sure it hasn't been started since it got "painted".  There is paint on the head fins that should have cooked off if was running.  Anyhow, I gave it some fresh gas and tried to start it.  No go - I think the intake valve is stuck open a little.  I can feel both vacuum and pressure when I turn it over.  I'll pull the head and have a look tomorrow.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
Re: Another great CraigsList find
« Reply #1 on: May 15, 2016, 06:52:19 AM »
You do have special powers.   :)
Save a farm today or starve tomorrow.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #2 on: May 15, 2016, 07:02:54 AM »
That will come in very handy!
~Chuck~
I LOVE MY SAWMILL
Offline sawguy21
« Reply #3 on: May 15, 2016, 12:37:58 PM »
Stuck intake valve is very common for air cooled engines in that application.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: May 15, 2016, 03:33:40 PM »
Looks like your "need" and "find" stars may have aligned.   8)
Offline ljohnsaw
« Reply #5 on: May 15, 2016, 08:37:28 PM »
I'm hoping, I figure this has probably been sitting for many years.  Had that issue on my 16hp Kohler that I know was sitting for 7+ years.  Fingers crossed.
John Sawicky
Offline scgargoyle
« Reply #6 on: May 16, 2016, 06:21:18 AM »
Everyone should have a super power, and yours is one I can relate to! Half of the things in our house seemingly came from craigs or ebay. :D
I hope my ship comes in before the dock rots!
Offline sandhills
« Reply #7 on: May 16, 2016, 12:34:59 PM »
Might not hurt to pull the flywheel and clean up the magneto also, I've found that to help a lot with small engines that have sat a long time.
Offline ljohnsaw
« Reply #8 on: May 16, 2016, 03:20:16 PM »
What's to clean on the mag?  Spiderwebs?  It has spark - seems like enough.  At first, I pulled the plug and had the wire hooked to it.  Pulled the starter rope but nothing - not a good ground.  So I held the wire so the threads of the plug were on the head good.  Pulled the rope and the spark plug wire was leaking a bit :o
John Sawicky
Offline sandhills
« Reply #9 on: May 16, 2016, 04:51:22 PM »
I was talking mostly rust on everything and checking measurements, if yours has good spark it probably won't help much though.
Offline ljohnsaw
« Reply #10 on: May 16, 2016, 09:07:05 PM »
I need to pick @Kbeitz brain since he has one of everything in his collections :D
No go.  I changed the plug to one from a running 2hp B&S.  Seems like way more spark - a scary amount!  So, spark is good (outside the head).  I am concerned that when I place the palm of my hand over the intake and pull the rope, I feel alternating suction AND pressure.  That is why I was thinking the intake is stuck open.  So I pulled the head.  This engine has definitely ran in the past.  A bit of carbon buildup.  Light rusty around the exhaust and black around the intake and combustion chamber.  Nothing major and not oil soaked.  So I cleaned all that off.  What I noticed is the action of the intake valve.  Maybe this is normal but I don't see how it could work.  The valve open quite wide for the intake stroke and closes ALMOST completely at the bottom of the stroke.  It is very slightly open (enough so I can rotate the valve) until the piston is about 1/2" from top of stroke.  It is fully seated for that last 1/2" or so.  I don't see how that could give much compression.  That is, unless this engine has a compression release but that seems strange for such a small engine.  I tried squirting some carb cleaner in the intake to see if it would fire. Nope.  My neighbor brought over his starting fluid and shot a good dose in the spark plug hole.  We pulled and pulled but not a pop.  Ideas?
John Sawicky
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #11 on: May 17, 2016, 03:04:20 AM »
I've seen this happen a few times in my lifetime.
If the engine was run hot the valve stem can stretch.
The only fix is to remove the valve and replace or
just grind off the amount needed to get it closed again.
You can google "valve stem stretch" and see that other
people have this problem to. I myself just grind a little
off the valve or the lifter so it closes again.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline ljohnsaw
« Reply #12 on: May 17, 2016, 10:48:25 AM »
Kbeitz,
Now there is a controversial topic!  I can pull the intake valve without popping the case so I'll give it a little grind and see what happens.  Still a puzzle as to why I can't get a little pop, though.
Thanks for the idea.
John Sawicky
Offline pineywoods
« Reply #13 on: May 17, 2016, 11:03:24 AM »
The valve stems will stretch from excessive heat, but more likely the valve seat is corroded away from running un-leaded fuel. Grinding off the end of the valve stem to adjust is nothing new. Henry Ford's flathead V8 was like that, no adjustments in the valve train...
Offline ljohnsaw
« Reply #14 on: May 20, 2016, 06:25:05 PM »
Spent an hour or so and got it running.  I looked up the specs on the valves and read a little on how you are supposed to take it apart and such.  They recommend pulling the carb and muffler off to make things easy.  Well, when I pulled the muffler off, I found the exhaust port PACKED with cut leaves and the muffler packed with mud.  Stupid mud daubers!  Cleaned all of that out and checked the valve clearance.  Exhaust was good and the intake was about .002 - should be between .005 and .007.  So I pulled it and ground it down and ended up at .010.  Oh well, that will give it room to grow.  I pulled the exhaust valve as well to clean it up and get the rest of the leaves out of the port.  Put it back together and it fired right up!
So on to the pump.  There was a rubber check valve of sorts that was deformed and stiff so I pulled that and made a new one.  Also washed out a lot of rust powder, dirt and dead bugs.  I filled a 5 quart bucket with water and stuck the pickup pipe into it.  I primed the pump, fired it up and nothing (for about 3 seconds).  As I was walking around to see if I could tip it or lift the bucket to help it pull the water, it started pumping and just caught me with the water stream on my side.  Emptied the bucket in about 2 seconds!  This will work great up at the cabin project.
John Sawicky
Offline Onthesauk
  • Still learning!
« Reply #15 on: May 20, 2016, 08:11:07 PM »
Sweet!  And the price was right!
John Deere 3038E
Sukuki LT-F500
Dont attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
Offline ljohnsaw
« Reply #16 on: May 20, 2016, 08:23:12 PM »
Yep!  All I spent on it was my time.
Next up is to make a pickup manifold to hook to a pair of 55 gallon drums.  Need to get a 1" pvc ball valve and a couple unions so I can disconnect it.  Then add a hose reel and it will be ready to go up to my property.
John Sawicky
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: May 21, 2016, 08:53:28 AM »
Congrats on your pump success.  Now back to bigger and better things.   8)
Offline ljohnsaw
« Reply #18 on: May 29, 2016, 05:49:43 PM »
I decided to "palletize" my pump.  I had a stack of various plastic pallets (so it will never rot out) to choose from.  I needed a hose reel (plastic ones show up on occasion on CL) but wanted something a little more sturdy.  Walked into Goodwill and there it was.  Brand new steel RainBird reel with 75' of 1" hose (green) and about 8' of hookup hose(red).  I found a 1" ball valve in my stash of junk supplies.  I added another 75' of " contractor's rubber hose.  Should be enough to get everywhere on my foundation when I need to wet it before the pour next week.
It can move a lot of water if no back pressure (10-15 gpm) and with a little jet stream, probably builds up to 40 or 50 psi.  Just need to put a strap or two on the tank and good to go!
John Sawicky
Offline ljohnsaw
« Reply #19 on: June 02, 2016, 07:33:00 PM »
(Almost) a final update:
I filled the water barrel about half way and tested everything.  Worked great.  Ran the fuel tank dry.
On Tuesday, took it up to the property.  Spent the better part of the day finishing up little details to get ready for the pour (next Wednesday!).  Took the palleted pump down to where I could gravity fill it from my holding tank.  Filled up the gas tank.  Gave it a pull - nothing.  Choked it - nothing but a few pop-pops.  Too sunny out to see if there was still a spark.  Pulled the pump off and took it home.  I thought maybe had something to do with the altitude or I sucked some dirt into the carb, but same pop-pop and nothing.  Checked for spark - nothing!??!  Pulled the flywheel to check the points - figured maybe the condenser gave out or something.  Go to check the gap and NO GAP!  The points didn't even move at all.  Everything was tight so I loosened the condenser and moved it down far.  Then cam was doing what it is supposed to do.  Reset the gap and it runs great again.  I'm at a loss as to how it could have closed up the points?  I guess it was just marginal before, but this is strange.  The condenser looked ok but in hindsight, maybe it swelled a little pushing the contact up into the points?  The points were not pitted so I assumed the condenser was good.
Now I need to take it back up the hill and test it before I need it on Wednesday.
John Sawicky
CraigsList find
Started by ljohnsaw on General Board
Last post December 30, 2015, 01:25:25 PM
by ljohnsaw
Jeff's great find.
Started by Wildflower on General Board
Last post July 30, 2016, 06:10:10 PM
by POSTON WIDEHEAD
Scored a great find at an estate sale.
Started by DR_Buck on General Board
Last post January 25, 2015, 05:56:15 PM
by Magicman
great dump find...stupid people..
Started by zopi on General Board
Last post May 18, 2009, 04:05:59 PM
by zopi
