KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Another great CraigsList find  (Read 5843 times)
Offline easymoney
Re: Another great CraigsList find
« Reply #20 on: June 03, 2016, 11:02:35 AM »
did you put a little grease on the crankshaft where the points ride? if the crank is dry the points can close up from the contact point wearing.
Offline r.man
« Reply #21 on: June 03, 2016, 12:02:28 PM »
I have seen one that had the cam lobe either broken or wore round. I put an electronic ignition kit on it, ran fine.
Offline ljohnsaw
« Reply #22 on: June 03, 2016, 01:38:07 PM »
I didn't add any (doh!) but it was greasy looking.  There is a square push rod of sorts that contacts the cam down a hole.  The points ride on top of that.  This is a really old B&S - I used to repair lawnmowers as a kid, eons ago, and never saw a B&S like this one.
It is running great now so we'll see how long that lasts.
Don't think the cam is worn since the push rod is plastic/nylon and I was able to get .020" gap quite easily.  Also, this is what I would call a reverse cam?  Points ride open until the push rod drops to make contact for a moment.  It's been a while since I messed with points but from what I remember, that seems backwards - but it works!
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline ljohnsaw
« Reply #23 on: November 07, 2017, 05:19:25 PM »
Well, not exactly a CL find, but a great dumpster dive!  After I finished a quick grocery store stop, I drove around the back as it is an easy exit from the parking lot.  There was a big dumpster with a odd aluminum shelving unit sticking out of the top, so I stopped.  Under it was a Macro Bin - large plastic bin that are 4'x4' and this one looks like it will hold about 1/2 yard of material.  The thing is in excellent shape.  While I was pulling that out, this was sitting under it:
Ever since I have been watching @jimdad07 videos, I've been wanting one for when I start handling my timbers (next spring).
It was a bit dirtier at the time, covered in greasy dirt.  This is what was wrong with it, the other half was missing:
I made a new pin out of some SS I had laying around.  That is the new pin on the top:
I couldn't figure out how to get the linkage apart so YouTube to the rescue.  Also learned how it is suppose to work and how to adjust it.  Works like new.  I found a place to buy a new pin ($11.00), but where's the fun in that! ;)
John Sawicky
Offline btulloh
« Reply #24 on: November 07, 2017, 06:05:37 PM »
Outstanding.  Great rescue.  It's hard to believe what people throw away.
HM126
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #25 on: November 07, 2017, 06:37:10 PM »
Isn't  that stealing?
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline red
  • we will never forget
« Reply #26 on: November 07, 2017, 07:24:49 PM »
One mans trash is another mans . . .
We have a lot of good boys and girls in harms way
lets all support them and their familys.
    • A&P Saw mill LLC
« Reply #27 on: November 07, 2017, 09:32:06 PM »
Maybe they give things away.
Sawing since 1987
Offline ljohnsaw
« Reply #28 on: November 08, 2017, 01:07:30 AM »
There was a paint crew there and all of the stuff I salvaged was getting covered with empty paint buckets and tons of painter's paper and tape.
John Sawicky
Offline ljohnsaw
« Reply #29 on: November 28, 2017, 05:06:30 PM »
Listed for free on Craigslist - 6" x 36" Craftsman planer.  What!  No way!  I didn't think Craftsman made planers.  Well, it turned out to be a jointer ::)  I emailed the poster (pointing that out) and he liked my email and "wanted it to go to a good home that knows more about it than me".  He was quick to point out that the guard was pretty stiff and didn't know how to make it work.
I spent a few hours cleaning the rust off the bed, lubing up various moving parts and adjusting the infeed table so it was flat with the outfeed table.  And tightened about 2 dozen bolts that were supposed to be holding the stand together.  Also had to sharpen the blades - they were really dull on the right 2" where it was used all the time.  The other 4" on the left were almost new.  Added locking wheels to make it portable.
The PPO (previous, previous owner) added a chip collection chute made out of some 1/16" aluminum.  Works really well!
This replaces the 4Ĺ" x 24" jointer I have down in my shop.  Actually, I have about 90% of a second one as well that my daughter thought I needed :D
John Sawicky
Offline 21incher
« Reply #30 on: November 28, 2017, 06:59:06 PM »
Wow, I got 60 bucks for mine when I sold it on Craigslist last year.  Sold it in a hour with 10 people in line. You got a good deal, they are a great starter joiner. Craftsman sold rebadged bellsaw planers at one time. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Onthesauk
  • Still learning!
« Reply #31 on: November 28, 2017, 08:00:10 PM »
I bought one of those new over 30 years ago and got good use out of it!
John Deere 3038E
Sukuki LT-F500
Donít attribute irritating behavior to malevolence when mere stupidity will suffice as an explanation.
    • A&P Saw mill LLC
« Reply #32 on: November 28, 2017, 08:10:43 PM »
 smiley_thumbsup smiley_thumbsup
Sawing since 1987
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #33 on: November 29, 2017, 04:11:26 AM »
Looks just like the one I bought from Sears in 1973 for $480.00.
I still use it and it has never give a problem.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline samandothers
« Reply #34 on: November 29, 2017, 09:36:57 AM »
I cleaned up my dadís craftsman that had been sitting for years.  Plugged it in and the magic smoke left the motor! :-\
Offline Kbeitz
    • My Hobbies
« Reply #35 on: November 29, 2017, 08:18:53 PM »
Easy fix....
« Reply #36 on: December 01, 2017, 08:22:03 PM »
Offline ljohnsaw
« Reply #37 on: March 01, 2018, 06:35:10 PM »
Took a while to connect with this guy but he listed a bucket of stainless steel bolts for $20.  Turned out to be about 3 gallons of bolt in 5 diameters (1/4" to 1/2") and lengths from 1" to 5" in 1/4" increments (6 to 8 sizes).  99.5 pounds of bolts!  I think I'm set for a couple lifetimes!
On the left side is random galvi bolts.  A little over 2/3s are stacked that I did during the rain today, the jarred ones were from yesterday.  I still need a few more PB jars to get them all put away.
John Sawicky
Offline btulloh
« Reply #38 on: March 01, 2018, 06:44:55 PM »
Heckuva deal.
You sure do eat a lot of peanut butter.  :)
HM126
Offline ljohnsaw
« Reply #39 on: March 01, 2018, 07:22:11 PM »
Heckuva deal.
And that ain't half of them!  The skinny green lid ones are Parmesan cheese - love that stuff, too!  A couple are Miracle Whip.  We go through a big jar a month, maybe less.  Lately, the price per ounce is much less on the littler jars that are more useful for storing the not-too-long bolts.  Sooo much better than glass jars.
There are between 50 and 75 bolts on most sizes.  One size there must be 200.  I'm guessing close to 1,500 bolts.  One cent a bolt sure beats $1.00-2.00 at the local hardware store!
John Sawicky
CraigsList find
Started by ljohnsaw on General Board
Last post December 30, 2015, 01:25:25 PM
by ljohnsaw
Jeff's great find.
Started by Wildflower on General Board
Last post July 30, 2016, 06:10:10 PM
by POSTON WIDEHEAD
Scored a great find at an estate sale.
Started by DR_Buck on General Board
Last post January 25, 2015, 05:56:15 PM
by Magicman
great dump find...stupid people..
Started by zopi on General Board
Last post May 18, 2009, 04:05:59 PM
by zopi
