Arborwear
Author Topic: The wife asked for a GreenHouse  (Read 4415 times)
Offline Geeg
  • Living the Dream!
« on: August 13, 2016, 05:03:15 AM »
Just finished off the greenhouse drawing for the misses. Now I need to cut some trees down and get to work. Plan is red pine 6x6 and the floor plan is 9'x12'. Polycarbonate 8mm roof with a mix of used windows to keep the costs down. I will post the progress here, wish me luck!.
Airbus 380 Captain, living in the Middle East, counting down the days till retirement. Timberking 2200,  Kioti RX6010PC,  Polaris WV850
Offline Geeg
  • Living the Dream!
Re: The wife asked for a GreenHouse
« Reply #1 on: August 13, 2016, 05:49:25 AM »
Forgot the best part, I managed to get some more tools with the deal, Makita 7104L Chain Mortiser, 3" slick, 2" and 1.5" TF chisel. Ordered a Borneman from the TFG, just waiting for that shipment.
I also drew up ponies that I saw in a magazine, need these since I donít think my cheep horses will stand up to the task. For those of you who use sketchup, I will upload the .skp file here and also in the depository.
Cheers Geeg
Offline glassman_48
  • 1-231-258-4246-work/ed/231-564-2672/cell
« Reply #2 on: August 13, 2016, 08:47:28 AM »
Geeg,
I own a glass shop in Michigan, and occasionally our suppliers will put sheets of polycarbonate on sale.  If you don't already have a source, check a local glass shop.  I will also frequently just sell a sheet just above cost instead of retail to help my customers out.  Our sheets here are 48" by 96".  Good luck with your project.
Offline Roger Nair
« Reply #3 on: August 13, 2016, 08:51:47 AM »
Geeg, a small matter, turn the tenon 90 degrees that enters the base beam to avoid excessive cross grain loss.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
Offline Geeg
  • Living the Dream!
« Reply #4 on: August 13, 2016, 10:12:17 AM »
Thanks for the info Glassman. That's kind of what I thought to Roger but have a look at the drawing, maybe I missed something?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #5 on: August 13, 2016, 01:19:53 PM »
Mortises have to go with the grain not cross grain:
Jim Rogers
PS tested and passed:
Offline Geeg
  • Living the Dream!
« Reply #6 on: August 13, 2016, 11:45:17 PM »
Thanks Jim, Fixed
Offline Geeg
  • Living the Dream!
« Reply #7 on: October 09, 2016, 05:05:20 AM »
Well, I finally broke ground and started on the wife's green house.
This was just a layout with the intended area for the build.
Was able to score some of the windows however still need to find many more.
We ended up putting in two loads, one of pit run and the other was crushed limestone as a base. Also used 2" foam with 6mil polly under the whole foundation.
Got the base down, used 2x6 pressure treated lumber screwed to the pine base with foam.
End of a long day, managed to cut down 4 pines for the project.
Offline thecfarm
« Reply #8 on: October 09, 2016, 08:08:22 AM »
Looking good.
I run some metal conduit,Ĺ" down the middle of ours. Hooked it up with some small chain that was made for the foor foot lights and all was well to hang the hanging baskets from it.
Offline ljohnsaw
« Reply #9 on: October 09, 2016, 12:51:53 PM »
That's looking nice!  But, there seems to be an awful lot of trees/shade around!  Are you planning to cut some for the build?
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Geeg
  • Living the Dream!
« Reply #10 on: October 10, 2016, 02:10:31 AM »
Looking good.
That's a great idea!, was thinking of a solar system.
Offline Geeg
  • Living the Dream!
« Reply #11 on: October 10, 2016, 02:14:11 AM »
The green house is right on the edge of the tree line, it gets the morning sun and will receive the afternoon sun as well with a little thinning to do. Those red pines around the structure will not cast much of a shadow.
Offline Geeg
  • Living the Dream!
« Reply #12 on: October 10, 2016, 03:53:58 AM »
Added some more pics of the build.
Putting up the rear bent section.
Shaving a little off for a better fit.
Almost finished raising the bents, little harder when you are doing it all by yourself.
Offline Czech_Made
« Reply #13 on: October 10, 2016, 06:22:34 AM »
Following
Offline fishfighter
« Reply #14 on: October 10, 2016, 08:10:44 PM »
Looks good.
Offline Geeg
  • Living the Dream!
« Reply #15 on: October 13, 2016, 03:15:23 AM »
Fitting the knee braces.
I am sure there is an easier way to put these things up?, man that is hard work.
Make sure to use gloves if you will be beating on the wood with a mallet, tend to get blisters, don't ask me how I know.
End of a long day.
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #16 on: October 13, 2016, 10:25:49 AM »
Looking good.
More hands make lite work.
Jim Rogers
Offline Geeg
  • Living the Dream!
« Reply #17 on: October 21, 2016, 11:27:21 PM »
Have the main structure done, didn't get any of the shots getting the rafters in place or the purlins but the wife did get some video, just have to figure how to upload that to youtube. Got some closeups of some of the joint work, remember this is my first build so be gentle.
Offline ljohnsaw
« Reply #18 on: October 22, 2016, 01:54:42 AM »
That sure is pretty!
John Sawicky
Offline thecfarm
« Reply #19 on: October 22, 2016, 05:47:00 AM »
Yes,it does look good. Like the curved supports.
Greenhouse advice
Started by 69bronco on General Board
Last post March 01, 2016, 10:34:52 PM
by sandsawmill14
New greenhouse build
Started by Picky2016 on Timber Framing/Log construction
Last post October 10, 2016, 02:17:06 AM
by Geeg
starting a HF Greenhouse
Started by DDW_OR on General Board
Last post February 05, 2018, 12:39:31 PM
by DDW_OR
greenhouse problems
Started by Kansas on FOOD! FOOD! FOOD!
Last post April 23, 2011, 02:34:55 PM
by Bandmill Bandit
