Arborwear
Author Topic: Putting together a 25995 under CDL single axle Log Truck.  (Read 3524 times)
Offline mills
Re: Putting together a 25995 under CDL single axle Log Truck.
« Reply #20 on: October 28, 2016, 08:14:50 PM »
Are there any problems dumping with bunks ? Right now I use a standard dump body (smooth sided). I can haul small loads into the mill w/o being in the way, dump them quickly, and be gone. Don't bother or wait for the  loader/scaler who is usually busy with a big load. I was thinking of converting it to bunks but wondered how it would dump.
It will work, but it's rough on the bunks. I'll dump a load several times a year, and no matter how you think you loaded it, knots and butt flares catch on the bunks and cross beams.
Offline starmac
« Reply #21 on: October 28, 2016, 10:34:07 PM »
It must not be too much problems dumping with bunks, as the guys I know haul several loads a day, day in and day out. When one of them was just hauling to his mill yard, his turn around times were less than an hour.
Offline Ohio_Bill
  • Wood is Good
« Reply #22 on: November 20, 2016, 06:20:06 AM »
Making some progress on the truck . Did a test fit and making the bumper / hitch today . Should be ready for paint this week .
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Online Dakota
  • Swing'en in South Dakota
« Reply #23 on: November 20, 2016, 08:56:02 AM »
Built to last.  Good job.
Dave Rinker
Offline Oliver05262
« Reply #24 on: November 20, 2016, 09:47:45 PM »
  Bill, do your stakes have a cap on top? If not, do they have a way to drain rainwater out so they don't freeze and split?
  Most I have seen around here that are made with box tubing have the stakes open on both ends (handy to hang the straps/chains on) and the bunk is butt welded to them.
If a tree falls in the forest, and then springs back up again; do the squirrels freak out?
"Abandon hope, all ye who enter here"
Offline Ohio_Bill
  • Wood is Good
« Reply #25 on: November 20, 2016, 11:55:00 PM »
Yes the bunks have caps on them and hopefully water will stay out . We made some more progress today and got the bumper / hitch on and also the deck covering the drive shaft . Now its time for paint and wiring .
Bill
Offline YellowHammer
  • There's a lot more to it.
    • Hobby Hardwood Alabama
« Reply #26 on: November 21, 2016, 06:41:30 AM »
I've been following this build for awhile, that looks great, I'm jealous.
Hobby Hardwood Alabama.com
LT40 Diesel Hydraulic, Stihl 028, MS440, MS660, 2 Kilns
Offline reprod
« Reply #27 on: November 23, 2016, 12:13:04 AM »
First post here...  Actually just joined the forum.  I built a very similar truck a few years back.  I have hauled 100's of loads with it.  It is great for short logs, up to 16' long.  I average a little over 1mbf/load, more if I load it heavy.  1.6mbf was the heaviest load I've ever got to the mill.  I go right into the mills just like the bigger trucks.  The stacker operators scratched their head the first few loads.  There is enough room above the frame and under the logs for them to reach in and grab the load.
Hopefully the pic will show up.
Cheers,
Steve
Offline Ohio_Bill
  • Wood is Good
« Reply #28 on: November 23, 2016, 10:11:42 PM »
Welcome to the Forum  Reprod .  That is a very nice looking truck. I like the style bunks that are on it. There use to be a lot of smaller trucks around but they are becoming fewer and fewer. Seems like everything is getting bigger.
Bill
Offline reprod
« Reply #29 on: November 23, 2016, 10:48:47 PM »
Thanks Ohio_Bill,
I knew I was on the right forum when I saw your truck build.
The bunks that I have on the truck have worked out about right.  I always wish they were taller, but if I load the truck with as much as I can, I am still usually under weight by a 1000 lbs or so.
Offline Ohio_Bill
  • Wood is Good
« Reply #30 on: November 27, 2016, 06:36:47 PM »
Got warm enough to get the bed painted and with a little help should be able to get it mounted tomorrow.
Bill
Offline Ohio_Bill
  • Wood is Good
« Reply #31 on: December 30, 2017, 03:09:11 PM »
Thought I would give a update on this project . Been using the truck for about a year now . It has worked out very well . I stopped logging for the most part and use the truck to haul logs from other loggers to my mill also make some deliveries of finished products to customers . I travel to another state from time to time so applied for DOT numbers which put me in the new entrant program . Several hoops to jump trough for the DOT . Federal inspection , health card , UCR , Maintenance files ,  Driver files and a DOT New Entrant  Saftey Audit  . So got trough the audit and using the truck a good bit .
Bill
« Reply #32 on: December 30, 2017, 04:42:44 PM »
Good job, I know it's not easy navigating the laws.  I am also DOT registered, and it's a bunch of paper and leg work.  Oddly enough, I wasn't required to get a DOT number in Alabama, and wasn't required to get one in Tennessee either, if I didn't cross state lines and stayed under 26,000 lbs.  But as soon as I crossed state lines, and was over 10,000 lbs rated sticker weight (who isn't?) I became an Interstate Trucker and was required to have a DOT number and everything that goes along with it.
All this was politely explained to me by a friendly State Trooper, who gave me a lights on escort to the nearest weigh station and started a "multiple violation citation" even though I was unloaded.  What fun.
Offline starmac
Re: Putting together a 25995 under CDL single axle log der eh Truck.
« Reply #33 on: December 30, 2017, 07:12:35 PM »
They call that the price of schooling, what an education you get huh.
I built similar bunks and installed them on my log truck, so I could haul 24 foot shorties this fall. I didn't make a full length frame for them, since it wasn't set up to dump. I just split some I mean a foot long and bolted to the frame, then bolted the bunks to it, so I could pull them off real quick and put my regular bunks back on. It takes about an hour. I also put a little more clearance between the frame and bunks, because If I pulled into the mill here and let them unload it, they would total the truck before it was unloaded. The mill does not take the short logs anyway and it turned out there was no danger where we were hauling these to.
I also have 2 inch thick walled pipe in the top of my bunks, so I could have stake extensions up to 14 foot, but still remove the back ones so didn't have to pick the trailer up high enough top clear the whole 14 feet to load and unload.
Offline Skeans1
« Reply #34 on: December 30, 2017, 08:10:01 PM »
Cheers,
Steve
Nice little thinning operation there, what part of NW Oregon are you out of?
Offline coxy
« Reply #35 on: December 30, 2017, 11:35:53 PM »
 I like that truck  8)   what is the reason you went  6x6 posts   are tandem has 4x4 posts and never had any trouble   4x4 would have been a lot lighter  ;D  in NY if the truck has air brakes even if it weights 3000lbs you must have a CDL
Offline starmac
« Reply #36 on: December 30, 2017, 11:55:54 PM »
The factory stakes on my bunks are 3x5, 3/8 thick, but they also start tapering to a point about two feet up, the pipe for the extensions are on the outside.
The shop built ones are 3 x 5, 1/2 in thick and a little taller.
These are for full loads, 1 bunk on the truck and 1 on the trailer handles a 63,000 pound payload legally, they may have accidently been overloaded a time or two, but are no worse for wear.
I have a set of light duty bunks for just a truck, no trailer and no provisions for extensions that are just 4x4, 1/4 inch thick.
Offline mike_belben
  • Pulp Friction
« Reply #37 on: December 31, 2017, 12:22:01 AM »
Or if the trailer is 10k.  NY uses the highest of any 3.  Scaled weight, manufacturer rated weight or registered weight.  If you tag for 12k on a 7500lb car trailer, you need an A license with combination in NY.  They dont care what state you are from or whats legal in that state.  When in NY, yer a new yorker.
Their CDL manual still says hauling personal goods not engaged in commerce is exempt, but i still got towed, impounded and a criminal charge for an empty trailer, while sleeping at a rest stop.
Offline Ohio_Bill
  • Wood is Good
« Reply #38 on: December 31, 2017, 02:37:56 PM »
I had plans of using smaller uprights , but these were available  from scrap so a substantial savings . If I remember correctly it still only weighs 1900 . The completed truck comes in under 12000 .   BTW the load on the truck is Ash . Its pretty much all dead here in Ohio .
Bill
Need single axle tractor
Started by CLL on Wanted
Last post July 23, 2007, 12:25:06 AM
by CLL
single versus tandem axle for log/lumber hauling
Started by rmack on Forestry and Logging
Last post September 29, 2012, 06:51:47 PM
by thecfarm
Putting together a log truck
Started by mainiac on Forestry and Logging
Last post January 06, 2012, 05:47:25 PM
by treefarmer87
how many tones can a tri axle log truck hold?
Started by logman81 on Forestry and Logging
Last post December 23, 2012, 06:17:20 PM
by lumberjack48
