Arborwear
Author Topic: Cutting branches of a standing maple  (Read 1222 times)
Offline Czech_Made
« on: January 06, 2017, 07:57:13 AM »
n/a
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Cutting branches of a standing maple
« Reply #1 on: January 06, 2017, 11:29:48 AM »
CM,
   How big is the tree and how big and how high is the last limb you plan on cutting?
   I have used a climbing deer stand for such but if its a valued shade tree you need to be sure it is one that does not bite into the tree and cause permanent damage. (The same would be true with someone using climbing spikes.) I'd climb the tree and have a heavy cord or small rope tied to a small chainsaw below then pull it up and lower it as needed. The deer stand can be rotated around so you are behind the limb so it won't fall on you.
   If the tree is too big for such a deer stand you might consider getting a trained/licensed arborist. A good one is well worth his pay in such cases.
Offline low_48
« Reply #2 on: January 07, 2017, 10:35:04 PM »
How many branches are some? I've taken off higher branches with a manual pull saw with several pole extensions, but at my age, it's getting to be one branch a day. Pulling on the pole for a half hour is no fun, the bark tears under the branch, I can't control the landing, and my neck gets bad if I look up that long! Keeping the saw in the kerf isn't much fun at the start either. I'm about to the point in life where I'm going to call a service and tell them that the next time they are in the neighborhood..........
Offline Al_Smith
« Reply #3 on: January 08, 2017, 05:07:27 AM »
I've got an inexpensive Poulan pole saw .It does okay for what is .You have to use a little common sense gravity being what is else you could drop the limb on your head which would not be good .
With that thing you can  get up to maybe 12 feet with it.It's not designed for professional use. I've cut 8-10 inch stuff with it just takes a while
These little things are just weed wacker engines that use a flex shaft for the pole saw part and usually come with a weed wacker attachment .You can also buy a head and turn it into a mini tiller like a Mantis. Poulan I think still makes them,Sears might still sell them .
They don't cut like a Stihl or Husqvarna pole saw but they don't cost  800-1000 bucks either .Mine was 200 a few years back .
Offline DonT
  • Lifes rough wear a helmet
« Reply #4 on: January 08, 2017, 01:38:54 PM »
Pruning is part science, part art. You want to make sure your pruning cuts are made properly to protect the tree.  You don't want to leave stubs and you do not want the bark to tear off. Most medium to large pruning cuts are achieved in three stages,an undercut (about a ft from the tree main stem) an over cut above the first cut (most of the branch will fall with this cut) and finally a stub cut on the branch ridge collar,with most of the weight off,you will avoid tears in the bark. This can be achieved with a decent pole saw or by climbing up to the branch. If you have previous tree climbing experience then you know how to do this.If you don't,maybe consider getting training or hiring a qualified individual. Rigging is the lowering of pieces of a tree safely to the ground . Usually an arborist block is positioned in the tree. A rigging line is used to connect the branch,block and usually a friction device at the bottom of the tree to assist in lowering heavy pieces. There are a lot of good you tube videos,on pruning, rigging and climbing for you to have a look at.  I also suggest you look at some of the "tree felling gone bad" videos. These act as a reminder to stay with in our own personal skill set. Remember it may be cheaper in the long run to hire someone and you clean up, rather than have to buy new tools you may never need again. As with anything tree related, safety first and wear all of the PPE that should be worn.  Just my .2 cents    DT
Offline Wudman
  • Eat, drink, and be merry before you go on quota!
« Reply #5 on: January 27, 2017, 10:48:26 AM »
I bought an electric pole saw for working around my yard and driveway.  It was under $100 bucks.  I built a work platform that mounted on the 3-point hitch of my tractor (I use it for many elevated work tasks).  I use a generator that I already owned to power the unit.  With the platform I am about 6 feet off the ground.  I am about 6 feet tall.  The pole saw extends to 12 feet.  I can trim to 20 feet without much problem.  At full extension the pole saw is a bit end heavy.  You just about have to work straight overhead to control the saw.  I limbed a quarter of mile of driveway through a pine plantation in a couple of afternoons.  It works pretty well.  I use electric tools for most of my seasonal work.  With gas powered stuff, carb maintenance is a nightmare on small engines that are not used regularly.  I even have an electric mini garden tiller for use in the flowerbeds.  It is amazing the power that little thing has.  Electric tools have their niche.
Wudman
Offline Czech_Made
« Reply #6 on: January 27, 2017, 01:21:34 PM »
Thank you  ;D
I use caryall on my tractor to reach places, might as well add to it some steps.
This particular tree is within a reach of power cord from the house, I will buy pole saw from TSC to start on this job.
Wudman
Who's cutting the oak branches off?
Started by sprucebunny on Ask The Forester
Last post August 03, 2004, 02:25:00 PM
by SwampDonkey
exclamation
Cutting the bottom branches on Fir trees?
Started by Bow Saw on Forestry and Logging
Last post November 13, 2008, 06:48:07 PM
by SwampDonkey
moved
MOVED: Cutting the bottom branches on Fir trees?
Started by Ianab on General Woodworking
Last post November 03, 2008, 11:20:00 PM
by Ianab
Identifying curly maple while it's still standing
Started by NH-Murph on Tree, Plant and Wood I.D.
Last post September 03, 2015, 10:30:27 AM
by mesquite buckeye
