BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Quickcrete foundation??? For a 20x24 timber frame  (Read 2534 times)
Offline Dflick
  • I'm new
« on: June 25, 2017, 06:59:05 PM »
I am going to be building a 20x24 timber frame on my property.  The problem is I cant get a concrete truck or a loaded dump truck (unless an excavator pulls it)  up my drive way.  I plan on pouring 9 footings with sono tube peers.  Do You guys think I can use Quickcrete (Sackcrete) in stead of mixing my own mix?
Online ljohnsaw
Re: Quickcrete foundation??? For a 20x24 timber frame
« Reply #1 on: June 25, 2017, 09:23:34 PM »
How many CU-FT (or fractions of a yard) per tube?  My neighbor had a few to do and was too cheap money consious to hire a pumper.  I offered up my little mixer.  He got a yard of sac-crete delivered as a pallet of 56 bags.  I could load two (60 lb) bags in my mixer if I angled it just right so it didn't slop out.  Took about an 2 hours with 3 of us working - hauling bags, mixing and hauling half-full 5 gallon buckets.  Turned out he needed another yard so the next weekend, we did it all over again!
If I were to do that for a big structure (his was just a deck), I would make sure it was high strength or add some Portland to each batch to make it high strength.
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Delawhere Jack
  • I ought to know better.....
« Reply #2 on: June 25, 2017, 09:25:05 PM »
Not an expert, but Sackrete is used all the time for footer for decks and other projects. Check what the local codes are regarding compression strength required. It would be a good idea to rent or buy a small mixer. It takes a LOT of bags of Sackrete to fill even a small sonotube. A mixer will allow you to fill the tube quickly and insure a homogeneous footer.
Don't even think about putting the mix in the tubes dry and then adding water. That's fine for fence posts, but not for footer.
Oh, and welcome to the FF.
Online ljohnsaw
« Reply #3 on: June 25, 2017, 09:31:12 PM »
Also, in my readings, I've found that concrete strength, besides the amount of Portland in it, is directly related to the aggregate size.  Bag mix is usually pea gravel.  I'd want 3/4" or larger for a foundation.  If you need a lot of material, you could always get an aggregate mix delivered (by your truck/trailer) and add Portland to it as you go.
« Reply #4 on: June 25, 2017, 09:35:42 PM »
https://www.quikrete.com/calculator/main.asp
Appears to be 45 80# bags to make one yard of concrete..
(Check my math...)
Online ljohnsaw
« Reply #5 on: June 25, 2017, 09:58:33 PM »
My recollection is the 60# bags are 1/2 cu-ft and the 80# are 2/3 cu-ft.  So, you would need 40.5 80# bags to the yard.  My computer (Widows 10) didn't think your link was safe so I didn't go there.  I mis-spoke earlier - you need 54 60# bags to the yard.  If the per-yard price is the same, get 60# bags - your back will thank you! ;)
Offline Dflick
  • I'm new
« Reply #6 on: June 25, 2017, 11:38:49 PM »
Im not sure what the size of the footings and peers are going to be yet.  I am waiting on the plans right now. From what I've read it sounds like High strength Quikcrete is the product I may want to use it has the fiber in it.  Also I know to be careful with the amount of water I put in it.  On another not some one recommended using those eco blocks  that they use for big retaining walls.  They are pre cast concrete blocks 2'x2'x4'.  I just can't find any examples of them being used for home foundations anywhere.  Thanks for the info guys!
Offline Don P
    • Calculator Index
« Reply #7 on: June 26, 2017, 07:06:49 AM »
Actually piers fall under "engineering required" for residential construction. Prescriptive foundations (non engineered) are made with a continuous perimeter footing and foundation walls to form a braced structure that can resist lateral (horizontal) loads from wind or seismic. Piers depend on the soil to resist those loads and it depends on soil type, embedment depth, pier diameter, ect. The eco block is probably less likely to topple than a pier. On our house and a number of others I've worked on we've pulled the trucks in with dozers, used pumpers, bobcats, tractors, even 4x4's and drums to bring in the concrete. You can site mix, I've found it isn't much more difficult to bring in sand, gravel and Portland and mix them there. If you are blessed with rock I've done rubble stone walls with rock and site mixed mortar and concrete, a 16" thick uncoursed wall. You can also do gravel footings and permanent wood foundations. This is all covered in chapter 4 of the IRC although AK has it's own set of rules and methods.
Offline Dflick
  • I'm new
« Reply #8 on: June 26, 2017, 12:40:09 PM »
I am concerned with the type of concrete used to make the eco blocks.
Offline florida
« Reply #9 on: June 27, 2017, 02:19:19 PM »
You should be more concerned with bag mix you'll be making yourself. When we were pouring foundations for commercial buildings the engineers stood right there watching the mix and notating the added water. They also took a sample of every batch after any water was added. It's really hard to mix bag mix by the yard and keep it dry enough to make the required compressive strength.
Have you considered a pumper?  Around here a guy with a portable unit will cost you about $100.00 a truck.
General contractor and carpenter for 50 years.
Offline John Mc
« Reply #10 on: June 27, 2017, 10:07:48 PM »
I'm no concrete expert, but I do know that the footings for a timber frame are NOT something you want to skimp on. A timber frame has much higher point loads than a "stick built" building.
Offline Don P
    • Calculator Index
« Reply #11 on: June 27, 2017, 10:40:48 PM »
I agree, I'd extend that to say the foundation is not something to skimp on. Take the time to research and design a good one. I don't know how many houses I've had to go back under and fix failing foundations on. It is tough, expensive and not particularly fun.
Offline mometal77
« Reply #12 on: July 04, 2017, 04:33:29 AM »
Going to do the same but have the cement truck at the bottom of my 400 ft driveway and have him fill my 410D john deere backhoe bucket 1 yd at a time 10 yards 10 trips later.  I know a guy who does this for a living has a skid steer he rents for jobs loads and pours.  Cement vibros come in handy too you can find a used cheap one online.  Best to buy one vs rent one.  I never read any of the comments about water retention and diversion.  Seen a few places even one woman near a lake here the engineers said build that house at the bottom of the hill.  She didn't and the cost to a brand new cabin was 600,000 if i remember right. I was invited to the house warming party and that slab had cracks in it all over. Later on the rich lady had it tore down logs beams everything and rebuilt where she was first told to.  I have seen and heard a lot of stupid things.  Another was the owner of Amazon.  With that rock shaped cactus. They had shipped in or bill gates flooring to his house.  Lot of money out there i wish i had more of it. LOL....  Most gravel companies will pre mix your gravel so you can just throw it in your 1 yard mixer or what ever you have.  Portland cement at home depot i see went up in price... and if you have a salvage yard find painted rebar never use rusted rebar for a new slab... Good luck sounds like a lot of work... plus what i am not looking forward to is paying for truck time for the cement truck..... life i guess.  Reminds me i need to buy that red 2 wire heating cable for mine so i can keep a slab nice and warm during winter months.  I do not think i will have a hole in the ground to work on transmissions etc more work.
Too many Assholes... not enough bullets...I might have become a millionaire, but I chose to become a tramp!
Offline woodmaker
« Reply #13 on: July 14, 2017, 08:42:52 PM »
I'm not sure if they are permitted where you are,but we have a local pre-cast company that pours one piece sonotubes ,(although these are actually square) with enlarged footings on the bottom. They have different sizes for heavier buildings.you just dig a hole to the correct depth,in the correct location,set them in,and backfill.
franklin q80,builtrite 40,husky 372,sachs dolmar 123, dozers,excavators,loaders,tri-axle dump trucks ,autocar tractor with dump,flatbed and detachable trailers, and 8  f350 diesels
Offline newoodguy78
« Reply #14 on: July 14, 2017, 10:01:21 PM »
X2 they work great
Offline nativewolf
  • Forester
« Reply #15 on: July 14, 2017, 10:07:43 PM »
As seismically active as AK is I'm glad you are getting the engineering done on the building.  Question:  can you get a backhoe up to it?  And how far from the house site is the nearest road a mix truck can get?
Liking Walnut
Offline Al_Smith
« Reply #16 on: July 15, 2017, 05:07:55 AM »
Just a thought for what it's worth .These old giant timber framed dairy barns,some still standing were just built on top of rocks buried in the ground .They didn't have a foundation and they are older than 100 years .
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #17 on: July 17, 2017, 04:00:09 PM »
I helped my friend Jimbo pour his cabin tubes about 8 years ago up in tennessee. We used bag mix. I forget how many bags I did that day but it was around 100 80 pounders.
We pulled the mixer to each tube with a ATV, another ATV brought the bags. Filled up the tractor bucket with water from the hose back up the hill.
The First 60 years of childhood is always the hardest.
Offline snowstorm
« Reply #18 on: September 18, 2017, 08:03:02 PM »
Just buy precast tapered frost piers. Way easier than pouri ng your own.
Offline 47sawdust
« Reply #19 on: September 21, 2017, 06:10:11 PM »
Have you given any consideration to a pressure treated frost wall?That is a small building and it might be a possibility.If you do a search of rubble trench foundations you will see some options that might be of interest.
 Good luck.
Mick
Timber frame barn footer/foundation/sill restoration
Started by blackhecilopters on Timber Framing/Log construction
Last post April 25, 2016, 01:43:34 AM
by Brad_bb
"Foundation" for a timber frame shed
Started by ohsoloco on Timber Framing/Log construction
Last post November 30, 2007, 10:56:30 PM
by Don P
frame to foundation
Started by laffs on Timber Framing/Log construction
Last post March 29, 2016, 04:51:55 PM
by addicted
Foundation for my frame
Last post June 16, 2003, 05:09:47 AM
by shopteacher
