Arborwear
Author Topic: Killing trees with herbicides?  (Read 2150 times)
Offline Splaker
« on: June 29, 2017, 07:17:52 AM »
Hello folks,
I am looking for advice on the most effective commercial product available that will kill stubborn trees like box elder and black walnut.  They are sending out suckers and spreading their offspring throughout my property.  Would like to kill them to permanently remove or at least get them under control.
I have researched the following: Triclopyr, Glyphosate, 2 4 D.
If I squirt these types of products on the exposed cambium layer of said trees, will I see results? Which of these would you recommend?  Others?
Thanks very much in advance!
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Killing trees with herbicides?
« Reply #1 on: June 29, 2017, 07:27:20 AM »
Are you spraying the foliage or the cut stems?
Offline Splaker
« Reply #2 on: June 29, 2017, 07:35:43 PM »
Possibly both... what would you do?  Most effectiveness is my goal!
Thanks!!
Online Claybraker
  • Mostly New!
« Reply #3 on: June 29, 2017, 07:47:44 PM »
That would depend on the size of the stems, and the number of stems.
Offline Splaker
« Reply #4 on: June 29, 2017, 08:53:02 PM »
I want to kill a few larger trees (over 8" diameter) and a lot of smaller ones (under 3").
Offline WDH
« Reply #5 on: June 29, 2017, 10:20:41 PM »
If you hack-n-squirt where you use a hatchet or machete to hack into the bark and squirt herbicide into the cut, Tordon is very effective.  Beware that it is soil active, so confine the herbicide to the cut and do not slop it all over the place and on the ground.  You can read the Tordon label to determine the details of the hack-n-squirt method, spacing between cuts, and the proper chemical concentration.  It is very effective.
If you spray the hardwood foliage, a 3% solution of Garlon 4 will do the job very well.
Online Claybraker
  • Mostly New!
« Reply #6 on: June 29, 2017, 10:48:25 PM »
Hack and squirt with Tordon RTU works like a charm, but here's a variation called drill and fill.
I transfer the Tordon to a quart spray bottle. Pro tip- label the spray bottle with the contents, because you might forget what's in the spray bottle.
Offline Splaker
« Reply #7 on: June 29, 2017, 11:05:59 PM »
Can you explain what you mean by "soil active"?  Do you mean it will kill other stuff nearby if it accidentally spills?  So if I can carefully manage to keep this on the target trees, will my soil and surrounding environment be safe from contamination?  Can it harm ground water/well water?  We have a drilled well but it's not close to where I need to apply this product, although I sure that contamination can spread throughout a ground water system...
Thank you very much folks... I will give this a try!
Offline Ianab
« Reply #8 on: June 29, 2017, 11:32:07 PM »
Quote
Basically yes. Sprays like Roundup are only absorbed through the leaves of a plant. If you spray some on the ground, or the bark of another tree, nothing bad happens and it quickly breaks down.
Other sprays are "soil active" and can be absorbed through the roots, and often stay active in the soil longer. They all break down over time, so you aren't going to permanently poison the soil, but it's easier to get unwanted kills from over-spray if you aren't careful.
The "drill and fill" looks like a pretty controlled way of dealing to smaller trees as all the herbicide is kept in the hole, not being sprayed around, and maybe landing on things you don't want to kill.
Modern sprays have done away with ingredients like DDT and Dioxin that used to give worries about groundwater and long term contamination.
Offline Splaker
« Reply #9 on: June 29, 2017, 11:45:55 PM »
Forgot to ask if there is a time of the year/season when it's best to apply?
Offline Splaker
« Reply #10 on: June 29, 2017, 11:50:10 PM »
Quote
Thanks! We have very young kids so I will take precautions and keep them away from the applied areas for a while just to be on the safe side..
I am assuming RTU should be applied during dry periods so rain doesn't wash it away?
Offline WDH
« Reply #11 on: June 30, 2017, 07:40:33 AM »
Best applied while the plant is actively growing.  As long as you use the chemical 12 hours or more before a rain, you are good because the plant will absorb the chemical and no worries about rain washing out any chemical.  If it is very dry, better to wait until the trees are not stressed, otherwise they will not take up as much chemical and your treatment will be less effective.  The label describes when it is best to treat.  The best time for me is the Fall.  It is not as hot and it is nicer to be in the woods.
As long as you confine the chemical to the cut or frill as it is called, you are good.  The only issue you might have is if another tree has grafted roots with the tree that you are treating and receives some damage from the chemical.  However, I have not found this to be a problem.
The tiny amount that you spray in the frill does not pose any threat to the soil or groundwater.  No danger to your kids unless they play with the frills.  I use a squirt bottle like a Formula 409 cleaner bottle that has a trigger and you squirt a little stream of chemical in the frill.  The frill only has to penetrate the bark to the solid wood as the cambium is the actively growing area that you want to target.  On a cut stump, you only need to apply the chemical on the interface of the bark and the wood where the cambium is located.  Coating the whole stump does no good and just wastes chemical because you are just targeting the live cambium with the treatment.
Online Claybraker
  • Mostly New!
« Reply #12 on: June 30, 2017, 10:29:04 AM »
Unless it's raining sideways, the drill and fill method works fine anytime, and if you're working outside under those conditions, there's a possibility you have bigger issues.  On larger stems, by the time I've worked my way around them, I can usually fill the holes again, just to make sure I get the required amount of herbicide where it needs to be.
Foliar spraying with the "waving wand" method using a tank mix also works well, especially if you are treating many small stems. and allows you to cover some ground pretty quickly. A tank mix of glyphosate and Garlon 4 is going to give you a pretty broad spectrum of control. Once calibrated, I pre-mix my solution in one of those containers that allows me to refill my back pack sprayer with the correct number of ounces, per tank, and the biggest limiting factor is the amount of water I can transport to the area I'm working.
If it's really thick, I'll try the foliar spray first to cut some paths through the area, and once that's had time to work I can come back with a spray bottle of Tordon and cordless drill to pick off the survivors.
Online Texas Ranger
  • Texan, by God and by choice.
« Reply #13 on: June 30, 2017, 12:08:17 PM »
back in the day I used a hypohatchet (rather the crew did) with a hit every 3 inches around the stem and it squirted the right amount
Offline Splaker
« Reply #14 on: June 30, 2017, 03:04:30 PM »
This has been very helpful and much appreciated... just looked at buying some RTU and a quart is $20 on Amazon - we cannot buy it up here in Canada commercially as our regulations on herbicide and pesticide use have become very strict.  So $20 and get this - shipping costs bring the total to $200!!!  My sister lives in Georgia (north of Atlanta) and she is visiting in August but wont be able to bring it because she's bringing a carry on luggage! So my only other option is to have it shipped to their house through Amazon or another retailer then she can ship it to me... this is too complicated!
One more question - if drilling or hack and squirting, should I target the base area of the tree or can I apply further up the trunk or some large branches?  Maybe all three areas?
Online Claybraker
  • Mostly New!
« Reply #15 on: June 30, 2017, 04:49:19 PM »
If she lives  north of Atlanta she can swing by and pick up a quart or 2 from me. I'm here in Cumming near Lake Lanier.  Sometimes TSC has Tordon RTU. but I can spare a quart or 2, and I'll throw in a gallon of Remedy (Garlon 4)  I've had for a few years, still unopened,  just to make it worth the trouble. That will come in handy for foliar spray-glyphosate won't do squat to box elder. How you get it to you  is your problem.
As far as the height, I try and work at a comfortable height.
Offline Splaker
« Reply #16 on: June 30, 2017, 09:14:50 PM »
They are in Winder... I've fished Lanier! Nice striper fishing... we also go to Hartwell as they have a lake house there.. love it down there...
Will let you know if my bro-in-law can swing by and get some of your stuff.  He might need it himself...
Thanks very much!!
Online Texas Ranger
« Reply #17 on: June 30, 2017, 10:36:33 PM »
with the hypohatchets we hack at or above waist high.
Offline Splaker
« Reply #18 on: September 06, 2017, 05:21:45 AM »
So I recently received my Tordon RTU in the mail but before applying I have a bit of a concern since this stuff is very potent.  If I apply it to the trees/shrubs i intend to kill, what will happen to the nearby plants, trees, shrubs, soil?  I guess I am worried that the root system of the affected tree could disperse the chemical to adjacent trees/shrub root systems... also, is the soil in that immediate and surrounding spot affected negatively for any period of time?   For example, if I am ridding a planting site of an undesirably plant, should I not replant on the same spot for some time?  weeks/months in order to let the chemical disperse?
thanks for any help!!
Offline PA_Walnut
« Reply #19 on: September 06, 2017, 06:07:11 AM »
I'm not trying to be sarcastic or argumentative, but just curious as why not just cut them down?
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
killing trees without herbicides
Started by Klunker on Ask The Forester
Last post December 09, 2017, 01:06:49 AM
by BaldBob
Wi-Fi Killing Trees???
Started by wesdor on Ask The Forester
Last post November 25, 2010, 09:16:36 AM
by Texas Ranger
Is something out there killing pine trees in MI?
Started by Paschale on Forest Education
Last post May 29, 2004, 04:08:53 PM
by SwampDonkey
Grubs killing my trees?
Started by Missy on Urban and Community Forestry
Last post October 24, 2017, 03:17:45 PM
by ely
