Arborwear
Author Topic: Box joint table test picture for posting  (Read 1114 times)
Offline rjwoelk
    • countrysidefirewood
« on: August 15, 2017, 09:55:52 PM »
I am looking at doing this type of joint for my sons bar top table.
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Brad_bb
    • My timberframe blog
Re: Box joint table test picture for posting
« Reply #1 on: August 15, 2017, 11:40:04 PM »
It surely worked!  Gonna take some careful cutting to have tight box joints that big.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: August 16, 2017, 05:26:41 AM »
I seen that done on a table saw with a sled and a block of wood. After each cut the cut was advanced
on the block for the next cut.
Love machine shop work
and Wood work shop work
And now a saw mill work
Online Don P
    • Calculator Index
« Reply #3 on: August 16, 2017, 07:00:07 AM »
A cabinet/furniture shop I worked at in my 20's was gluing up strips of oak into butcher block slabs, then we had a router jig and large porter-cable router that clamped on the ends of the slabs and could be indexed to give nice fitting joints. For some reason whenever I got drafted on a delivery it was one of the couches to a second floor apartment  :D
Offline rjwoelk
« Reply #4 on: August 16, 2017, 09:26:01 PM »
Thinking of using the chain mortiser to hog most of it out.
Offline low_48
« Reply #5 on: August 18, 2017, 05:17:46 PM »
Chain mortiser? What about the tolerances and splintering of the face grain? It takes a lot of precision to make those well. I can't imagine how you will get a tight glue joint on every one of those with that machine.
Offline rjwoelk
« Reply #6 on: August 18, 2017, 10:59:42 PM »
I would just get close then finish off with a chisel.  Or Make a jig and use a router, need a bigger router then.
Offline Brad_bb
« Reply #7 on: August 20, 2017, 01:43:15 PM »
Score the line deep with your framing chisel.  Then try the chain mortiser or boring bit to remove the majority and finish with chisel.  You'll have to finish with a framing chisel no matter what.
Online terrifictimbersllc
    • Terrific Timbers LLC
« Reply #8 on: September 03, 2017, 03:57:23 PM »
That is how I make box joints and would do this, the only twist here,  is that the mortise is wider than a full set of dado blades. I think this could be worked out by making a jig that indexed one side of the mortise on the index block and you would move it to the other side for the second pass.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline rjwoelk
« Reply #9 on: September 04, 2017, 10:56:43 AM »
The slab has been sitting in the cabin 2 to 3 weeks now and is around 12 % moisture has not changed in a week. We are still debating what kind of joint to use, we want the live edge to flow down, so after that it could be any thing.
Offline Larry
« Reply #10 on: September 04, 2017, 01:54:49 PM »
I've cut dovetails on that size of piece using my bandsaw.  With practice there is very little cleanup required.  Finger joints would be a lot easier.
I have a chain mortiser and wouldn't want to use it even just to get rid of the waste.   A good jig saw would work better I think.
Larry
Nine out of ten trees recommend wood for your building project.
First attempt at picture posting
Started by stumpy on General Board
Last post May 11, 2008, 10:11:18 AM
by chet
first attempt at picture posting
Started by slider on General Board
Last post June 10, 2012, 09:52:21 PM
by thecfarm
Picture Posting on Forum Help
Started by Jeff on Technical Support Topics
Last post February 02, 2018, 02:03:12 PM
by Magicman
So why or when did the picture posting thing change ?
Started by Kbeitz on General Board
Last post March 08, 2017, 08:37:53 AM
by Jeff
