TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: Splitter questions.  (Read 1932 times)
Offline Hilltop366
Re: Splitter questions.
« Reply #20 on: September 29, 2017, 08:08:19 AM »
Well thats no fun.
There is a lot of leverage on that back mount with the cylinder that high off the beam.
I have straightened a bent rod before in a hydraulic press.
Could look into making a mount that would go over the gland end of the cylinder to reduce the length of the unsupported cylinder by half.
Check the pressure relief setting as well.
Offline hedgerow
« Reply #21 on: September 29, 2017, 08:54:39 AM »
That is the problem with multi wedges. You better have a pressure gauge and watch your psi and you better have a strong splitter or you will have broken parts.  Good luck on the repair. I too have straighten bent rams in the press usually works ok.
Offline barbender
« Reply #22 on: September 29, 2017, 12:24:23 PM »
The one time I tried to straighten a bent rod in a press, it didn't go well👎
Offline jmur1
  • Wood is King
« Reply #23 on: September 29, 2017, 01:59:51 PM »
Hi  overclocking:
Tough one.  The flame cut surface of the notched plate (where your cylinder back pin is mounted) was likely a good start for the crack that eventually became the plate fail.  Make sure you fill the area with weld when you get it repaired - round off as much as you can.
I checked a similar layout of plates for you to see the difference.  See pics - below
I had a similar fail on my splitter cylinder and then upgraded it to a larger diameter ram (at the local hydraulics shop)  Wasn't that cheap to get done but did improve the speed of travel noticeably (less oil to move), and hasn't failed again.
The rounded one has about half the stress at the peak.  I used 40,000 lbs ram load on the pin.
Easy does it
Offline dave_dj1
« Reply #24 on: September 29, 2017, 03:35:08 PM »
Bummer, but at least now you have a project  8)
I have been known to straighten things in my horizontal gas powered hydraulic press brake (AKA log splitter) LOL
Do you know someone with another splitter close by? Take some pieces of 4x4 or 6x6 and set it up properly and take small steps.
Offline overclocking
« Reply #25 on: September 29, 2017, 04:21:05 PM »
Hi  overclocking:
Thanks for the insight. I looked at the splitter this beam came off and it looks like whoever added the longer cylinder cut away some material to fit it and like you said thats why it broke.
That's a really cool program, I am looking for a program to help me redesign this splitter as well as a firewood processor. Would that program work well for that?
Also, I thought adding a bigger ram decreased travel speed due to holding a higher volume of fluid?
What I am likely going to do is just toss this cylinder out and get a 32 inch travel 5 inch cylinder so that it doesn't happen again, but I am going to cut this whole thing apart and start from scratch next time.  The relief pressure of the spool was 2750 and this ram was likely only rated at 2500 or less. The pump was rated at 3000psi at 3000 rpm, the tach usually runs around 3-3100 rpm max.
Offline jmur1
  • Wood is King
« Reply #26 on: September 29, 2017, 08:42:39 PM »
Hi  overclocking:
Hi overclocking:
The program is handy to have.  - its quite pricey to own ~$15k.
https://www.ptc.com/en/cad/3d-design/parts-and-assembly-modeling
The overall volume of the cylinder is decreased when you increase the ram size.  I had a 2" ram and upgraded it to 3".  They had to rework the cylinder end hole and seals and the inner connection to the baffle.  They charged me ~$765
Note the outer cylinder size stays the same so the oil required to move is reduced.  It does not affect the push power because the ram end is the same size.
Easy does it
Offline Al_Smith
« Reply #27 on: September 30, 2017, 06:54:58 AM »
The problem with that installation is the fact only the tail end of the cylinder is anchored .Yes I know there are several makes of commercial splitters made that way but it's not the best idea .
With a welded cylinder like that here isn't much you can do to repair a bend shaft .Not saying it's an impossibility just difficult .
The power of the prime mover has little to do with amount of force the hydraulics can produce .With a high pressure low volume pump 5 HP could have done the same thing .A company by the name of Farval makes lube pumps for machinery lubrication  that only use a 1/2 HP motor but 10,000 Psi that will blow a steel lube line apart like it had a bomb inside of it .
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #28 on: September 30, 2017, 08:43:55 AM »
Darn thing is how expensive new cylinders are.  You may be able to get another used splitter for the same $ if you are buying a brand new cylinder.  I paid $450 for my splitter.
Most splitter builds around here go like this.
1.  Find a cylinder and sturdy beam.  Everything else will be built around them.
2.  Find a junk lawnmower or other small engine.
3.  Buy a hydraulic pump & valves unless you were lucky enough to scrounge them.
4.  Scrounge the rest of the steel needed from junk equipment.  If in doubt, add more steel.
R&D questions for a custom splitter
Started by Farmer Jim on General Board
Last post April 09, 2015, 07:04:08 PM
by Farmer Jim
Another splitter build - Hydraulic questions
Started by DeerMeadowFarm on Firewood and Wood Heating
Last post April 23, 2015, 09:47:30 PM
by lopet
Hand powered log splitter, the Smar-Splitter??
Started by Chuckolicious on Firewood and Wood Heating
Last post March 23, 2010, 01:50:09 PM
by Ernie
Rugged Split 37 ton splitter/splitter suggestions?
Started by jbos333 on Firewood and Wood Heating
Last post November 14, 2014, 08:57:15 AM
by ckhenshaw4
