Arborwear
Author Topic: Pontoon Re-build  (Read 966 times)
Offline DDW_OR
Pontoon Re-build
« on: September 04, 2017, 06:58:37 PM »
I have a pontoon with a 8x16 deck. the deck is rotten and i am planning on a total strip-down and re-build.
 this is how the pontoon looked when i lived in AZ
plan to change the layout
i will use a grid to explain where things are.
example, 6-3 is a removable table in green
Motor on left
small white circles are swivel seats, 2-1, 2-7, 4-7, 14-2, 14-6
small green circles are for shade umbrellas
red rectangles are bench seats
simple kitchen is at 7-7
captains council is on bottom edge
TimberKing 2000 & Talon Sharpener, Mahindra 5520 4x4, Max22 4x4, Bobcat Excavator 331, E80, Multitek 1610EZ
Offline DPatton
Re: Pontoon Re-build
« Reply #1 on: September 04, 2017, 08:41:30 PM »
What are you going to build the new deck out of?
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500.
Offline DDW_OR
« Reply #2 on: September 04, 2017, 09:20:22 PM »
Was thinking of using some of the cedar trees i have, then use fiberglass to seal it like i have seen done for canoes.
but then i thought how slippery it would be when wet.
have read where some people add playground sand to the final coat.
 :P
would like to have an aluminum deck, with hardwood used for the cabinets and other stuff.
Offline Briankinley2004
« Reply #3 on: September 04, 2017, 10:26:18 PM »
I used to help moderate a pontoon restoration forum. It was pontoonstuff.com. Its been many years and I haven't logged on in several. The head moderator died recently. The question of decking came up very often. Weight and rot is an issue especially if you're going to use your own lumber. Pontoons get a lot of splash under the bottom which can cause rot. The new non CCA treated plywood can corrode the aluminum framing. You can still get the CCA marine plywood but its high dollar. If money is not a problem I would recommend the COOSA board or something similar as a sub deck and a thinner layer of your favorite wood on top. I would seal it with penetrating epoxy or epiphanies spar varnish and plan on replacing unless you have access to teak, heart cypress or some other wood that will not rot. I just re read where you have access to cedar and that should work fine as long as its heart. Its good and light and you should be able to use it direct on the aluminum but I would still seal with cpes on topside.  I don't think it would be real slippery. Even table top epoxy doesn't seem real slippery to me on a table but I haven't done much table dancing  :D :D :D
Offline DDW_OR
« Reply #4 on: September 04, 2017, 11:55:14 PM »
THANK YOU!!
i know what needs to be done, but did not know what to do it with.
Money is an issue, but i prefer to do this once.
Offline DDW_OR
« Reply #5 on: September 05, 2017, 03:21:31 PM »
the umbrellas are the pole type used on patios
the pontoon is going to be used by my dad and me. he is 85 and I want to keep him shaded and cool
the pontoon has been put on hold for now. other projects have higher prioritys;
3000 feet of fence
3 lean-toos to add to the pole barn
chicken coop
Firewood
greenhouse = two harbor freight 10x12 placed end to end, with all mods and re-enforcement
http://www.forestryforum.com/board/index.php?topic=97497.msg1504967;topicseen#top
etc,etc,etc,etc,etc,
Online DanG
« Reply #6 on: September 18, 2017, 10:59:16 AM »
Since you're in Oregon, why not use redwood for your deck?  I would cover it with indoor-outdoor carpet for non-slip protection. Also, you will need some sort of membrane under it or water will spew up between the planks when underway.  If it was mine however, I would just use the non-cca plywood and put strips of rubber between it and the frame to avoid corrosion.
« Reply #7 on: September 18, 2017, 09:43:29 PM »
Underskinning with metal is popular for protecting the bottom. Popular belief is to not paint or seal the bottom of the plywood as it will not allow water that gets in from the top out
Offline DDW_OR
« Reply #8 on: October 30, 2017, 06:58:45 PM »
it does have a metal belly
Pontoon Boat
Started by LeeB on Wanted
Last post August 11, 2007, 12:09:27 AM
by LeeB
Pontoon boat
Started by DanG on The Outdoor Board
Last post July 19, 2009, 05:08:43 PM
by LeeB
OWB Build
Started by SPD748 on Firewood and Wood Heating
Last post January 21, 2018, 02:18:05 AM
by DDW_OR
FAO Build
Started by JD Picket on Sawmills and Milling
Last post April 15, 2017, 10:35:38 AM
by Ga Mtn Man
