Author Topic: Central boiler 1400 air channels  (Read 2701 times)
Offline overclocking
Re: Central boiler 1400 air channels
« Reply #20 on: September 12, 2017, 05:26:04 PM »
How do you get any stroke out of the sawzall? Doesn't it hit either the packed in creosote and or the back wall of the air channel?
In all honesty its pretty tricky! You have to use 3 inch bi-metal blades and just the right angle so the blade doesn't hit the back wall. It kicks out of the groove a lot and if you don't have patients it can be very frustrating. Its so much faster though once you get it moving. It zips right through the sheet metal. you have to angle it toward the center, and yes sometimes the creosote will make it pop out, but the bi-metal blade eats most of it. I attempted it with a regular blade for a few minutes today and it was much slower. I have to go tomorrow and get some more, as I broke two. When they pop out they bend and you can only bend them back so many times before they fatigue. Once you find the correct angle its worth it.
plasma cutter would be another good option, although I was hesitant to try one since its so close to the water jacket and its so thin.
A plasma would zip through it like butter, but you'll have a lot of burning creosote. Can get exciting, it ignites fast with that much heat. Been there. :)
Yea, it was starting to burn just using the cut off. I had to back out a few times!
Offline bobby s
  • Formerly Hockeyguy
« Reply #21 on: September 16, 2017, 12:43:04 PM »
Great info guys. Going to try to get this done on my 2300 before the heating season begins.
« Reply #22 on: September 30, 2017, 03:38:21 PM »
Ok, A little more progress.
Need opinions.
I am thinking I want to drill 6 1 inch holes on the top and 4 on the bottom. The reason for only 4 on the bottom is because its closer to the coal bed and I dont want it warping because theres too many holes. The material is stainless, about 1/4 inch thick.
Here are the plates after I cut them, they measure 31 inches long x 8 inches hieght
Once bolted they should sit nice and flush over the old channels
The red lines are where I will install the bolts, the other blue lines are where the holes will be drilled.
Any opinions on the hole quantity and position? 10 1 inch holes will give me 10 square inches of air flow. Where the channel in the back corner is there is approximately 4.5 inches per channel, so roughly 9 inches of air flow. That leaves a little play for build up before there's any restriction to the blower.
Offline PC-Urban-Sawyer
  • Been wasting time for sixty-eight years...
« Reply #23 on: October 01, 2017, 11:34:39 PM »
OC, ten one inch diameter holes will give you just 7.9 square inches of hole area. The area of a one inch diameter hole is .79 square inches, not 1 square inch...
Herb
Offline E Yoder
  • Heating with a HeatMaster GS100
« Reply #24 on: October 02, 2017, 08:58:04 AM »
I would make sure the bolt holes are slightly bigger than the bolts so the plate can expand to the rear as it heats up, (otherwise it can bulge and crack). And that there is a gap at the rear to accept that expansion. I think you are saying there is.
HeatMaster dealer support in VA.
GS100.
Offline DeerMeadowFarm
« Reply #25 on: October 02, 2017, 10:00:38 AM »
I finally got my warped plates cut out on Saturday. In all it took 3 hours and 15 cut-off wheels. Pictures to follow I need to but some material now to make my plates.
« Reply #26 on: October 02, 2017, 09:16:32 PM »
Herb
dadgum you, Charlie!
Thanks Herb your right.. A=Pi(r)^2 , not sure where my common sense was on that one. You would never know I aced calc. and discrete mathematics.
Good idea, I will do that. I am going to use 3/8th bolts to fasten it. If I had to guess, there's about a 1/4 gap maybe a bit more on each end. I was going to make the panel slide out, but after some thought I don't think it would ever seal, and chances are it would be faster buzzing off the bolts with my impact as opposed to chipping away chunks of creosote to be able to slide it up.
Out of curiosity what brand wheels did you use? I cut all this stainless with one dewalt 1/16th cut off wheel and it was the same one I used to do some of my panel removal. Can't wait to see the pics too.
« Reply #27 on: October 03, 2017, 07:57:43 AM »
I used 1/16th wheels but they were cheap ones. I still need to chip out all the baked in creosote. I'll take pictures in a couple of days; been busy lately.
How are you bolting the plates in?
« Reply #28 on: October 03, 2017, 06:04:34 PM »
i think what I might do is weld 2 inch strip plates in the middle recessed in the channel with a welded nut on the back. And for the ends I left some of the channel intact and will weld a nut on the back of that as well.
« Reply #29 on: October 04, 2017, 08:11:43 AM »
I plan to attach my plates differently. I'm concerned that using threaded fastening will just cause me grief after it gets heated so much.
My idea is to add a tab to the back end of the plate that will slip under the lip I left at the back end of the box. At the front end, I plan to use something like a gate latch to slide under the lip I left at the front of the box. The latch bolt will stick out through the plate. This will allow me to attach or remove the plate by whacking the sliding bolt with a hammer. I think it'll be clearer when I buy the plate and take pictures. How thick did you go with your plate?
Photos of the channels exposed are below. The right side was not nearly as packed with creosote as the left. I still need to chisel out the creosote. On the left side it is harder than cement and I think that is what really ate my cut-off wheels up.
Offline Roger2561
  • Love the outdoors
« Reply #30 on: October 05, 2017, 06:34:42 AM »
I've been following this thread with interest due to the need of having to remove the air channels on my 1400 too.  I'm still waiting on my welder/fabricator to get here to do it.  I can handle cutting out the channels, it's only I don't possess the welding skills to do any welding.  My thoughts of panel is to use stainless, I haven't decided on thickness yet.  I would make them similar to overclocking's but over size them a bit to allow a slot be cut in the panel that would then fit over tabs that would be welded to the firebox wall.  The tabs would have holes drilled in them to allow pegs to be inserted and tapped in place to make a tight seal.  When it came time to clean the channels, I would simply tap them out using a hammer.  In theory it sounds okay but in practice, who knows.  Roger
« Reply #31 on: October 16, 2017, 11:40:34 AM »
I finished one side this weekend. I welded a 1-1/2" angle on the back of the plate to act as a stiffener and a guide for my sliding locking bolts.
Here it is installed. The locking bolts slide into the portion of the air channel I didn't cut. The idea was to use something that I could remove easily for cleaning. I was afraid to bolt something in because I figured as soon as it heated up they'd never come out again. With this design I can whack the slides with a hammer, and theoretically they should slide and I can take the plates out. We'll see I guess...
« Reply #32 on: October 16, 2017, 06:31:39 PM »
Good to see you made some progress, I'm  still waiting to get my plates back from the shop to get the holes drilled. i am going to pick them up tonight.
I agree with the bolts being a pain, I most likely will end up doing something like that next year if it works good for you.
Looking good so far, does it seem to seal up well?
« Reply #33 on: October 16, 2017, 07:52:57 PM »
Seals much better than my warped original plates!
« Reply #34 on: October 23, 2017, 11:15:42 AM »
So here's the finished concept. My best friend took one for the team after I butchered drilling the bolt holes and he finished the install for me. Turned out really good.
Ran into a problem however on the test run, the plates already warped a little, I was shocked to see stainless do that, but I have a good and easy idea on how to remedy it and add adjustable airflow at the same time.
Offline Roger2561
  • Love the outdoors
« Reply #35 on: October 24, 2017, 05:49:56 AM »
Deermeadowfarm & overclocking - Both look great.  Unfortunately for me my welder/fabricator keeps pulling my chain and has every excuse for not showing up.  It's getting to the point of trying something myself or take a chance, leave it as it is and fire up the 1400.  Thankfully we've had some very nice weather here in NH this October.  Next week I have the week off from work and I will be firing her up for the winter with or without the new channels.  Anyway, they look great.  Please keep us posted on how the operate/hold up through the winter.  Thanks.   Roger
« Reply #36 on: October 24, 2017, 07:25:45 AM »
Roger, I wouldn't worry too much about it. My dealer told me that the units work the same with wide open air chambers so in worst case you could just cut your old plates out and run it as is. I'm not going to worry if the new plates I put in warp or not. I just want to be able to clean the creosote out.
« Reply #37 on: November 04, 2017, 10:58:36 PM »
So here is my update after a few weeks.
My plates warped a little so I removed them. I am pretty surprised 10Ga stainless warped, but anyhow I stole Deermeadows idea to reinforce them with the angle Iron. I will put a pic up tomorrow. The bolts came right out with no fuss which was nice. So far its working, but it's either not gassing anymore or I broke the temp gauge when cleaning it. I'm going to have to investigate that too. I have ran it without the plates installed with open channels and with the plates installed and am not breaking the 600 degree mark on the reaction chamber. I am wondering if I created too much air flow for the primary air.
Deermeadow, have you tested yours out yet? how are they working if so and have you looked at the reaction chamber temps?
Offline Roger2561
  • Love the outdoors
« Reply #38 on: November 05, 2017, 10:29:09 AM »
Well, my welder/fabricator never showed or returned my phone calls and it was getting to the point where I had to fire up the 1400.  It's been running for over a week now and it's running great (knocking on wood) so, I'm waiting until next year to do something about the channels; either I find someone else to do the work for me or I do it myself.  The great thing about this is I have all winter to read your updates and then decide how I should approach this problem.   ;D
overclocking; as for why yours is not gassing, I nothing to offer.  Perhaps it has nothing or everything to do with the channels having panels over them and the holes strategically placed to make it happen.  Roger
« Reply #39 on: November 06, 2017, 09:39:33 AM »
I just fired mine up yesterday. It started out slow. My water temp was way down and it seemed like it should have kicked into high burn but it wasn't. I kept futzing around with it but it seemed to act weird. Then, somewhat frustrated I left it alone to work on another project and when I got back to take a look it was at high burn and temps were 1,000 plus.
Got up this morning and the water temp was good. Before I left for work I opened it up. Lot of wood still in it but it kind of bridged so I knocked it all down, stirred the coals up and threw a couple of chunks in for good measure. No warping yet that I noticed but it's pretty dark when I leave in the morning so maybe I didn't see it? I'll have a light with me when I check it after work today.
Central Boiler Eclassic 1400
Started by holder73 on Firewood and Wood Heating
Last post April 01, 2013, 08:34:35 PM
by Ohiowood
Central Boiler E-Classic 1400 - opinions please
Started by Dean186 on Firewood and Wood Heating
Last post December 10, 2010, 09:35:58 PM
by Guitarjunkie37
Central Boiler E Classic 2400 / 1400 Creosote Problem
Started by ParadisePA on Firewood and Wood Heating
Last post April 02, 2013, 09:48:27 AM
by Logging logginglogging
Central Boiler Eclassic 1400 Reaction Chamber Door
Last post January 19, 2014, 12:08:14 PM
by holder73
