Arborwear
Author Topic: taking the weight out of walnut  (Read 5908 times)
Offline tule peak timber
  • roborob
    • tule peak timber
Re: taking the weight out of walnut
« Reply #60 on: November 06, 2017, 05:38:57 PM »
 Final top coating, number two of three. Getting closer.... :)
  • roborob
    • tule peak timber
« Reply #61 on: November 15, 2017, 07:05:19 PM »
After three top coats and a day of fine buffing , we are ready to ship.Very hard to get a decent photo due to glare so below are some pics of the next two bartops in line and some natural edge trim going to another job.The bartops are White oak and the trim is Ponderosa pine. We use the lifts to hold while spraying, move to a drying area, then scoop up another set for finishing. Cheers  Rob
Offline Timbercreekfarm
« Reply #62 on: December 25, 2017, 04:25:16 PM »
Some awesome stuff!
Offline Brad_bb
    • My timberframe blog
« Reply #63 on: January 04, 2018, 09:53:36 AM »
Does the walnut lose it 's chocolate color over time and get lighter?  I've seen that before especially in a house where the wood was exposed to sunlight.  Will any of the top coats stop it?   Does the epoxy yellow over time?
  • roborob
    • tule peak timber
« Reply #64 on: January 04, 2018, 10:39:55 AM »
Brad, I don't have enough years experience to comment on the walnut losing color.Yes , generally epoxy will yellow in sunlight over time, depending. Yes there are top coats that will lessen or prevent sun caused deterioration.On this top we used AwlCraft 2000 to protect it as well as provide the best finish possible.  Rob
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #65 on: January 04, 2018, 12:30:24 PM »
It does not matter the wood species, type of finish, nor whether it is ever exposed to direct sunlight.
Here is a table top in our "sunroom" that never sees direct sunlight, only some ambient.  The center always has a centerpiece and the ring is obvious where the uncovered wood/finish has lightened during the past ~10 years.  The picture makes the center portion much redder than it actually is.  Now the question is whether the uncovered portion lightened or the covered portion darkened??
Offline Larry
« Reply #66 on: January 04, 2018, 02:07:44 PM »
Brad, I can tell you without doubt that walnut gets lighter with exposure to UV.  Under the same conditions cherry gets darker and a much richer color.  A lot of tropical woods go brown as does osage orange.  Dad was a woodworker and made walnut clocks...some were exposed to sunlight and others were in dark rooms.  That is my source of experience.
The last few years I've been using a lot of SW cab acrylic lacquer.  A couple of reasons.  It goes on crystal clear and does not yellow over time.  It also has UV absorber in it.  I've used it on osage orange, purple heart, bloodwood, and some other samples to test.  One sample is exposed to light while the other is in a envelope.  Only been a couple of years but it seems to slow the color change.  I think with enough time/UV the change is inevitable no matter what is used.
Larry
Nine out of ten trees recommend wood for your building project.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #67 on: January 04, 2018, 02:52:02 PM »
In my experience walnut logs gets much darker laying on the ground for years.
Love machine shop work
and Wood work shop work
And now a saw mill work
  • roborob
    • tule peak timber
« Reply #68 on: January 05, 2018, 09:39:38 PM »
well,,,, a parting pic from today, and I hope the final picture....The customer kicked this table back  to us two  weeks before Christmas and we have been wet sanding/polishing/ buffing since that day. The customer detected small imperfections in the finish and asked me to correct all to a  perfect finish.This has not been an easy or inexpensive thing to accomplish. Supposedly this UV resistant coating I am using here will withstand the test of time given the level of work in this piece. I have spent a GREAT deal of time and money trying to find the best coatings possible in the last year or two. Not an easy or inexpensive venture - we shall see .
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #69 on: January 05, 2018, 09:46:29 PM »
Kick it back to me....I'll take it. Beautiful work!
Where's the Spoon?
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #70 on: January 05, 2018, 11:57:32 PM »
When you say imperfections, are they tiny air bubbles or waves or ?  Seems like getting "perfection" in a wood finish would be an impossible task, especially after as much fastidious work as you guys have invested in it.
HobbyHardwoodAlabama.com
Offline PA_Walnut
« Reply #71 on: January 06, 2018, 07:05:50 AM »
Wow...*DanG customers!  :-\
Getting a "perfect" finish on a large table/slab is a dance of technique, patience and air quality control.
Outgassing of the wood also causes constant pin holes until you have it sealed. I've discovered that multiple, if not many, seal coats are necessary on a slab PRIOR to putting on a finish coat. ALL pinholes must be sealed first.
Having end-grain up on a semi ring-porous species would seem like a REAL difficult task in controlling the outgassing during finish. Have you tried spraying a fast-drying seal coat like shellac (both sides) prior to beginning your finish?
I'm not at expert on this, by any means...just spitballing with some things I've experienced.  8)
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline PA_Walnut
« Reply #72 on: January 06, 2018, 07:07:31 AM »
Oh, by the way...what a labor of love! Cool table.
Are you able to share hours invested and/or what a table like that fetches on the retail market?
I'm supposing if you actually got paid for the hours invested in would be an astounding cost!  :o
Nice work!
Offline Kbeitz
    • My Hobbies
« Reply #73 on: January 06, 2018, 08:32:52 AM »
The way I gey my best finishes is sanding sealer or cheap varnish.
I use the cheap stuff for the first 3-4 coats Then the good stuff for
the last coats. There is a big difference in price between the good
stuff and the cheap stuff.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #74 on: January 06, 2018, 09:27:31 AM »
I had a customer one time that wanted a super high gloss white conference table 12' long 6' wide. It was made out of corian. We spent more money on the stupid table than we made on the entire job. I hate high gloss finishes for that reason.
I knew what I thought I meant.
Offline 21incher
« Reply #75 on: January 06, 2018, 10:19:53 AM »
Looks like you have accomplished the impossible. Thanks for sharing.  smiley_clapping smiley_clapping smiley_clapping
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
  • roborob
    • tule peak timber
« Reply #76 on: January 06, 2018, 11:06:26 AM »
I don't know what the customer is getting for this piece on his resale end, but I do know we spent 6 months and in the end out of pocket about 2500$. Sometimes you get the peanut-sometimes you end up with the shell :D :D :D
« Reply #77 on: January 06, 2018, 06:26:30 PM »
 Sometimes you get the peanut.......
But this is Walnut.  :o
Where's the Spoon?
Offline customsawyer
    • The Custom Sawyer
« Reply #78 on: January 06, 2018, 07:25:20 PM »
Truly impressive work.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Vehicle weight and towing weight limits
Started by Keith_A on General Board
Last post May 13, 2002, 07:26:52 PM
by Gordon
Quick Question about Walnut? First walnut sawn. criticism wanted.
Started by strunk57 on Forestry and Logging
Last post June 15, 2014, 05:16:04 PM
by Oliver05262
was sawing some walnut and oak today - is walnut made of concrete???
Started by Andy B. on Sawmills and Milling
Last post September 15, 2013, 09:58:31 PM
by Gasawyer
question
Walnut or walnut sawdust to combat bamboo?
Started by Delawhere Jack on Ask The Forester
Last post April 24, 2013, 08:29:14 AM
by just_sawing
