Arborwear
Author Topic: cheap tops for outside drying  (Read 1021 times)
Offline alanh
« on: September 20, 2017, 10:21:55 AM »
Seeing as how the day job throws out hundreds of these a year I figured I would share this. These snowmobile, atv, and side by side crate sides and tops make good covers for the stickered stacks. If there is a dealer near you I`m sure they`d be happy to get rid of some. Some of the side by side ones are 7 x 12 ft.
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
Re: cheap tops for outside drying
« Reply #1 on: September 20, 2017, 05:58:46 PM »
Those would be dandy!
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline GeneWengert-WoodDoc
« Reply #2 on: September 20, 2017, 11:16:32 PM »
Any top is highly subject to wind damage or getting blown off, so fasten them well.  A foot or so overhand is a good idea.
GENRALLY, they improve the quality of the top three to five layers by keeping rain off.  Financially, the are quite beneficial.
Offline alanh
« Reply #3 on: September 21, 2017, 09:30:12 AM »
Yup, the free part means I use enough for a 2-3 ft overhang, depending on what I`m covering I either screw them right to the pile or bungee them to a lower sticker
Offline starmac
« Reply #4 on: November 18, 2017, 12:14:33 PM »
I am not sure if they still use these,but several years I knew a guy that worked for a sign company. They used some pretty good and heavy material for billboards, that was a one time thing. He gave me several of these that were as big as the billboard they were covering, you can then cut them to any size you wanted. I used to see these laying under billboards at times, was why I ask about them. They would be perfect for covers and last just shy of forever if a guy could get his hands on a few of them.
Offline Gearbox
« Reply #5 on: November 18, 2017, 05:39:38 PM »
starmac google used billboard tarps .$ 50 14 x48
Offline mike_belben
  • Pulp Friction
« Reply #6 on: November 18, 2017, 07:02:48 PM »
How does a billboard tarp compare to say a cheap chinese fabric garage canvas?  Think itd hold up better or worse?
Offline starmac
« Reply #7 on: November 18, 2017, 07:38:13 PM »
Mike, I would think better, they were heavy duty and you could cut them any size you wanted, without fear of the edges unraveling. I truly belive the ones I had would have lasted for years making covers for air drying, longer than I will anyway.
Offline Gearbox
« Reply #8 on: November 18, 2017, 07:43:50 PM »
I get 3-5 years covering firewood .
Offline Randy88
« Reply #9 on: November 23, 2017, 09:41:40 PM »
I made pallets for both stacking lumber on and to cover the piles with, then screwed used tin to the tune of about 5 dollars per pallet and use a skid steer to put the pallet/tin roof on, should last decades as far as the used tin is concerned, for the pallets I built, it was all sawed lumber and stuff not good enough for anything but firewood, so I figure my time is about the only cost to those, most are 4 foot by 10 foot pallets, and the tin hangs over all sides depending on the lumber length I am covering.     The upside to to using 2x's and tin for covering, they are heavy enough to not need fastening down with anything, just set them on with the skid steer and don't look back.
Offline starmac
« Reply #10 on: November 23, 2017, 10:24:09 PM »
Randy, that is a permanent solution I have thought about, and just setting them on here would work, we don't get wind. I unloaded in Wasilla Monday and they would probably have blown away if they had a concrete barrier sitting on top of each one.
Offline Gearbox
« Reply #11 on: November 23, 2017, 10:27:53 PM »
I double stack my piles then cover with used steel roofing add 3 or 4 4x4s and put a big log on top for weight . Always get nice lumber to plane the next year .
drying wood slab table tops
Started by countryjonez on Drying and Processing
Last post December 28, 2010, 08:11:16 AM
by Just Me
Tops - Tops - Tops Everywhere
Started by caz on General Board
Last post November 14, 2009, 03:12:06 PM
by SwampDonkey
Ash tops
Started by petefrom bearswamp on Sawmills and Milling
Last post May 14, 2012, 07:51:33 AM
by ohsoloco
tops
Started by Jwinter on Forestry and Logging
Last post May 09, 2004, 02:17:33 PM
by Frickman
