Arborwear
Author Topic: makita sharpener 9820-2  (Read 351 times)
Offline losttheplot
« on: September 26, 2017, 04:48:08 PM »
I have been using a makita wet stone sharpener on and off for a few days now and I just cant seem to get the planer knives sharp.
I have been getting a decent grind along the face of the knife and have removed a couple of nicks.
There isn't much of a burr on the back and I have been lapping it after on a diamond stone.
The ground face looks quite dull in appearance its far from a mirror finish.
I have been using the 1000 grit stone.
If anyone has some tips on how to get the knives sharp enough to shave the hair from your arm I am all ears right now  :(
Cheers
DON'T BELIEVE EVERYTHING YOU THINK !
Offline 21incher
Re: makita sharpener 9820-2
« Reply #1 on: September 26, 2017, 06:31:25 PM »
I have one that I used for years to sharpen my joiner and planer blades. It always did a great job, but the blades were not sharp enough to shave with. I think the angle of planer blades  keeps them from developing a razor edge that would most likely fracture off instantly when put to use. I never had a problem with the quality of cut after sharpening blades with it. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
Looking For a Green 120 Grit Sharpening Stone for a Makita 9820-2
Started by octam1 on Wanted
Last post July 17, 2015, 03:50:43 AM
by octam1
WM pro series sharpener and Cooks sharpener with pics.
Started by customsawyer on Sawmills and Milling
Last post May 29, 2012, 08:45:10 PM
by Chuck White
Makita 16-5/16
Started by ScottInCabot on Timber Framing/Log construction
Last post October 28, 2016, 05:30:40 PM
by Knocker of rocks
How are the Makita Chainsaws?
Started by idaho04 on Chainsaws
Last post December 25, 2009, 11:51:52 PM
by dmartin
